I just justified cam swap/dod delete...or at least tuning out afm - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Community > G8 GT Talk (V8)
Old 11-18-2012, 03:21 PM   #1
Dfarnese518
Dfarnese518's Avatar
Default I just justified cam swap/dod delete...or at least tuning out afm
Ok so I am still new here, I've only had my car for about 3 weeks. It's an 08 GT with about 50k miles. I didn't notice it when i bought the car (because I was just excited as hell about the car) or maybe it just started happening, but i get a nasty vibration from about 1100-1350rpm. It has never happened in first or second gear, but right around 40mph on my local roads makes it very noticeable.
At first I figured this was a problem with the balancer. Even when I bought the car I noticed the balancer is plagued with a wobble, as I've seen all over on these boards. I figured no big deal, I'll slap an sfi rated balancer on there and call it a day (which is still the plan).
Well i was out driving today and realized that if I put in in manual mode, theres no vibration in any gears. Guess that rules out the balancer and means its the afm? Hopefully someone here can shed some light on the issue.
I would not mind doing a cam swap, and actually look forward to it, but I can't fund it right now.
I guess my question is- do you guys think it is in fact a problem with the afm, and do you think its doing any damage as it runs this way?
I know its hard to diagnose anyone else's problems through a computer, but any info would be appreciated!
Dfarnese518 is offline   Reply With Quote
Old 11-18-2012, 03:27 PM   #2
768MPH
768MPH's Avatar
This is normal. You'll feel a slight vibration when the AFM kicks in, AFM does not engage in manual mode.
2014 SS "Houston Stock"
Rotofab
RCR Intake/RCR TB
LS7 MAF
SW LTs-3" catted X
Corsa Mufflers
Pat G Tune
12.08@114.45 (stock tires suck)
768MPH is offline   Reply With Quote
Old 11-18-2012, 03:34 PM   #3
Dfarnese518
I guess i could have explained a little better. Lets say I'm cruising at 40mph, if I keep my rpm between 1100 to about 1350, I will have a steady vibration that does not go away until I give more throttle and exit that rpm range. The vibration is even noticeable to the girlfriend (who doesn't know jack **** about cars).
Old 11-18-2012, 03:35 PM   #4
PSMG8GT
PSMG8GT's Avatar
Have them replace the motor mounts with the newer ones
MODS:
CORSA CATBACK EXHAUST
DBA 4000 SLOTTED ROTORS W/ HAWK CERAMIC PADS
GXP DIFFUSER
FULLY DEBADGED
TSW NURBURGRING 20X8.5/9.5 WITH NITTO INVO 255/35 285/30
PSMG8GT is offline   Reply With Quote
Old 11-18-2012, 04:11 PM   #5
orangeg8
Offshore Prositute
orangeg8's Avatar
AFM does give an abnormal amount of vibratation as 768mph said. I noticed it on my car when cruising too.
Don't complain about life, if you do, try death, nobody has complained yet.
I am no Challenger to this game, I don't go Chargering away, and it is more than just ponies in this beast.
orangeg8 is offline   Reply With Quote
Old 11-18-2012, 04:45 PM   #6
Dfarnese518
I have read a few guys complaining about the old mounts. I don't think that is the problem in this case (could be wrong) but it sure couldn't hurt. Anything I should tell them to make them cooperate and do the swap?
Old 11-18-2012, 09:31 PM   #7
Joe'sFastG8
Joe'sFastG8's Avatar
Definitely the motor mounts. That's the first thing I had replaced under warranty after I bought the car. The updated mounts eliminated 80% of the vibration. You can still tell when it kicks in, but much less noticeable. AFM will always cause vibration as it changes the balance of the engine. The updated mounts are designed to absorb more of it.
Sent from my iPhone using AutoGuide.com Free App
Old 11-19-2012, 05:55 AM   #8
SeeD65
Senior Member Mike
SeeD65's Avatar
I thought the TSB on this issue stated that the dealer should replace the Transmission mount, not the motor mounts. I had the same issue....vibration and then a moaning sound....and the new tranny mount cured it.
2009 G8 GT - Premium and Sport Packages
Mods - Roto-Fab Intake, BMR Front and Rear Sway Bars, BMR RTAs, BMR Steering Rack Bushing, BMR Rear Cradle Bushing Inserts, and Cortex Tune. Summer set-up - 18x9.5 TSWs - Cooper 275/40/18 RS3-S, squared, LS3 Cam, Kooks Mids....and others.
SeeD65 is offline   Reply With Quote
Old 11-19-2012, 07:31 AM   #9
Dfarnese518
Wow ok, good info. Thanks! Was it hard convincing them to swap mounts?
Old 11-19-2012, 07:34 AM   #10
Dfarnese518
Thanks! Good info, and I guess it couldn't hurt to have the motor and tranny mounts swapped! Only a few months left on the 5 year, so better now then later!
I guess you guys have successfully disproved my AFM theory......
I still want a bigger cam though!
Old 11-19-2012, 01:28 PM   #11
GXPaycheck
GXPaycheck's Avatar
Do the motor mounts. You can use the engineering mode to see when the AFM is operating when using normal mode.
RIP Charlie, The GRRRR8 One
2009 G8 GXP, #715 0f 1829 (one of 38 as optioned), Magnetic Silver, 6M, Sunroof, Onyx/Red
VCM, Magnaflow axle-backs, WAMS IWM/VIM, Back-up camera with JHP autoswitch, Homelink by Snakey, Pedders bushings
2014 Chevy SS, Mystic Green, roof. One of 144
Forum junkie at the G8Board and "The G8 Forum That Shall Not Be Named"!
GXPaycheck is offline   Reply With Quote
Old 11-19-2012, 02:28 PM   #12
Joe'sFastG8
Not too bad. With any vibration they are gonna try and tell you to do a road force balance on the tires. Just be persistent and explain what is going on. Best way to tell for sure is to drive in sports mode until the vibration starts(make sure it's in 6th gear), then tap the shifter up to engage manual mode. There will be no gear change since your already in 6th, so the only thing that changes is AFM will be disabled. If the vibration stops then you have found the issue. Explain to them what you did and the results and they should fix it. Good luck!
Old 11-19-2012, 04:08 PM   #13
GMCustomerService
GMCustomerService's Avatar
Thanks for that information, Joe’sFastG8. As I’ve told many members, I’m not a technician by any means and you helped me to understand the vibration from the AFM more.
Happy Thanksgiving!
Michelle, GM Customer Service
Have you checked into GM Owner Center? You can maintain service history, check on warranty or recall information, and more. Visit my.gm.com!
GMCustomerService is online now   Reply With Quote
Old 11-19-2012, 05:04 PM   #14
Joe'sFastG8
I wasn't trying to disprove, I actually agree with you that the AFM is causing the vibration, but there is no way to eliminate the root cause without disabling or deleting it. The updated motor mounts simply absorb more of the vibration so not so much makes it into the cabin.
Old 11-19-2012, 05:35 PM   #15
Joe'sFastG8
Just to clarify as I think there is some misunderstanding now that I read through the thread again. The updated motor mounts ARE the fix for excessive AFM vibration. You can't eliminate the cause of the vibration, that is normal, you can only make it less noticeable.
Old 11-19-2012, 07:11 PM   #16
Dfarnese518
Thanks again joe, and I did understand what you meant. It makes perfect sense. Guess I need to get her to the dealer!
Old 11-19-2012, 07:24 PM   #17
Joe'sFastG8
Glad to help! Like I said I had the same issue and the first thing they pointed out was the aftermarket wheels and wanted to do a road force balance. That's when I explained that it stops immediately when switching to manual mode(without a gear change) which disables AFM and showed them the TSB for it. I told them I was positive it was from the AFM. They agreed and ordered the mounts. Maybe bring a copy of the TSB with you just in case.
Old 11-19-2012, 07:39 PM   #18
Dfarnese518
Yeah I actually already printed it out haha! My tires are pretty worn, so I expect to hear that as the diagnosis, but I think going in armed with all this info, I'll do just fine.
I love this board! It's becoming a new addiction.....
Old 11-20-2012, 12:39 PM   #19
Dfarnese518
Alright so she goes to the dealer Friday. The guy I talked to seemed to understand my problem and told me to just bring it in and they'll take care of it. Seemed pretty simple, so we'll see what happens.
Old 01-13-2013, 08:17 PM   #20
Dfarnese518
Just as an update I did finally get the motor mounts done! After brining my car in for the first appointment, they confirmed my problem was the motor mounts and agreed to fix them. They ordered the parts and told me they'd call me in a few days once they were in. Well the holidays came and I couldn't get my car over there, but I finally made it and the job is done.
The new mounts absolutely dampen the vibration better, now the AFM can only be felt in the gas pedal.
Thanks to the guys at Granite run Buick and GMC!
She is parked for the winter now, but come spring time, the next step is long tube headers, CAI and tune. Cam within the next year hopefully!
Tags
afm engine vibration cam
