Balancer wobble..... - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-19-2012, 01:23 PM   #1
MSU120
MSU120's Avatar
Default Balancer wobble.....
Well........looks like my balancer started wobbling. No strange noises but its clearly wobbling. To avoid any potential issues, Im gonna have it replaced with a Powerbond. Ive read other posts and there doesn't seem to be any issues with the accessories (AC, cooling, etc) not working properly.
If anyone knows otherwise.........please let me know.
SOLD--2009 G8 GT, Livernois "Mini Stroker" with 1C Cam
2300 Maggie, 1:1 Cog Drive, 60# Injectors, Roto-Fab Intake
Kooks 1 7/8 Mids with High Flow Cats, Borla Cat Back
ZL1 Fuel Pump, Kenne Bell BAP, 160 Degree T-stat
Camaro 3.27 Rear Diff, Livernois Tune
Monroe Sport GT Shocks/Struts with King Springs
BMR Front Sway Bar, BMR Strut Mounts and Bearings
Camaro Transmission Pan
Staggered Bretyon GTS-AV Wheels, Nitto NT05 Tires
605rwhp and 569rwtq
MSU120 is offline   Reply With Quote
Old 11-19-2012, 04:15 PM   #2
dandragonrage
Plastidip is awful
Many of us including myself have done the same swap for the same reasons. I went with the Powerbond 25%/10% (accessories/AC respectively) UDP with the updated Holden A/C bracket and all has been good for me. Everything else on the engine is stock so far except for my DC Power 270XP alternator, which still works very well with the UDP. My lights don't dim at all with it (they did with stock alt on stock HB) when my car audio system is on, though the 270XP was overkill for my system anyway which helps.
So yeah, all should be good with stock, unless you've got a system or otherwise want to pull a lot of current from the alternator at relatively low RPM.
Going to be trading in my G8 in January or February, 2013. It's been a good run. Thanks all. See you in the for-sale section soon as I pawn off some parts...
Car audio sale - now | Wheels & parts sale - soon
dandragonrage is offline   Reply With Quote
Old 11-19-2012, 06:33 PM   #3
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
I believe I have one, the crank bolt, and belt that I won't be using. I forget which name brand though, but it's a 25% UDP.
Old: 353.8
New: 632/530 Mustang Dyno
Old 11-19-2012, 07:54 PM   #4
Dfarnese518
Dfarnese518's Avatar
My balancer has a wobble and I'm considering the powerbond also. I plan on running around 1000 watts worth of stereo though, so it may not be the best decision for me.
Dfarnese518 is offline   Reply With Quote
Old 11-20-2012, 12:49 AM   #5
MSU120
MSU120's Avatar
Anyone know how hard this is to do yourself? Any instructions anywhere? Getting it done by the "pros" is WAY to expensive!!
605rwhp and 569rwtq
Old 11-20-2012, 02:00 AM   #6
hdt176
hdt176's Avatar
I just replaced one for a customer.
His car had 66000 km's and only symptom was wobble.
You do need the correct puller & new bolt.
You have to fit the new balancer with the old bolt, then remove the old bolt & fit new bolt for final tensioning.
There is no woodruff key, the balancer & crank are like a "cone" fit.
If you dont have the correct tools strongly recommend taking to reputable mechanic or dealer for repair.
You should only get charged one hours labour.....
L98 6 liter, VCM cam, valve springs & push rods, VCM OTR
X Force Headers, free flow cats, magnaflow cat back, powerbond u/drive. CHI heads.
G-Force Engine's (Australia) customised tune 438 rwhp
Exedy twin plate clutch.
Vertini 20x10 & 20x8 wheels 295 & 245 Michelin K1 tyres
11.90 @116.63 mph 1.73 60'
hdt176 is offline   Reply With Quote
Old 11-20-2012, 02:08 AM   #7
todds87ss
Car RamRod
todds87ss's Avatar
http://forum.***********/showthread.php?t=30435
and others...quick search will provide all of your answers.
If you do not have, or are unwilling to buy, the following - don't try this yourself.
3 jawed puller - a decent one. The HF ones tend to break
A way to hold the crank still - some use a screwdrive at the flexplate, some use other means. Read up on how others do it.
A longer metric bolt to start the new pulley on. As an alternative, you can heat the new pulley and press it on.
A new bolt is a must. These bolts are single use. Or get the ARP bolt, which is reuseable.
You can choose to be anything you want on the internet...why choose to be so stupid!
todds87ss is offline   Reply With Quote
Old 11-20-2012, 05:26 AM   #8
JCMG8
puller:
otc 6667 otc 6667
install: Hawk LS Series Harmonic Balancer Installation Tool
flywheel holder: kent-moore J-42386-A
those (or equal homebrew) will get the balancer off/on
9.5 RPM (Red Passion Metallic) Sport /Premium
ICOM 208H
"Experience is what you get when you didn't get what you wanted."- unknown
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. -red green
<img src=http://www.g8board.com/forums/signaturepics/sigpic9701_2.gif border=0 alt= />
JCMG8 is online now   Reply With Quote
Old 11-20-2012, 06:27 AM   #9
Yio110
Hey there guys!! I also have problem with the balancer it shakes very little. What should I do?
Yio110 is offline   Reply With Quote
Old 11-20-2012, 08:07 AM   #10
Silver Bullet
Super Moderator
Silver Bullet's Avatar
Replace it with the one mentioned in this thread. Or take it to the dealer for a stock replacement if you are still under warranty.
-2009.5 MSM Premium GT-
Mods: Brembos, OBX Headers to Maxflows, VCM, RCR Intake, HSRK, LS7 Maf and tuned by Pat G.
In The Garage: Yank 2800 stall, SLP UDP, Pedders Coilovers
10.59 at 100.31 in the 1000.....8.33 at 88.13 in the 1/8....1.99 60 ft
Silver Bullet is offline   Reply With Quote
Old 11-20-2012, 09:26 AM   #11
dandragonrage
Plastidip is awful
To pull the stock balancer, go to Autozone and get the HB puller that is labeled for use with Chrysler. It works VERY well for our balancers. They have it for their "loan a tool" program. No need to buy one. It looks pretty similar to the OTC linked above. I didn't use any specialty tool at all for installation.
Old 11-20-2012, 09:59 AM   #12
Yio110
What about the torque for the bolts? And do I need to buy new bolt?
Old 11-20-2012, 11:25 AM   #13
Monte8009G8GT
Monte8009G8GT's Avatar
Stay away from HF pullers had one that broke on me the other day and I almost lost an eye.
2009 G8GT:
364--forged rods/pistons stock crank.(Rick Crawford) Ported Heads,(Modified) Intake, TB. Vararam, Custom Cam, Kooks 1 3/4 LT, 2.5in custom exhaust, Yank 3000 TC, BMR SFC, H&R Springs. DDM HID's 8k-LB 3k-Fogs.
Dynoed 435whp 386wtrq with above setup 12.8@116 2.2 60ft BTTD.
Cam,Stall,LTH,CAI,Tune. Best time 12.7@110 1.9 60ft. Old Setup.
Dynoed 370whp 380wtrq
(w/LTH,CAI,Tune)Best time 13.1@105 Old Setup.
Monte8009G8GT is offline   Reply With Quote
Old 11-20-2012, 11:57 AM   #14
MSU120
MSU120's Avatar
They difinately didn't quote me on hours worth of labor!
605rwhp and 569rwtq
Old 11-21-2012, 01:46 AM   #15
todds87ss
Car RamRod
todds87ss's Avatar
One bolt only. Yes you need a new one (either a stock GM bolt, or the ARP 234-2503)
Torque specs are different. The stocker gets fully seated, then torqued to 37 ft-lbs. Then tightened an additional 140 degrees of rotation.
The APR bolt is torqued to 230 ft lbs.
