Next Step: Pulley - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-21-2012, 02:58 PM   #1
72GTOGUY
72GTOGUY's Avatar
Default Next Step: Pulley
Anyone run this pulley? did you see the estimated 12whp gain? did the car need another dyno tune or is it just a simple bolt on as they describe? Any difference in daily driving?
Thank you
http://www.texas-speed.com/p-143-pow...nk-pulley.aspx
72GTOGUY is offline   Reply With Quote
Old 11-21-2012, 03:05 PM   #2
Scorpious
G8 fiend
Scorpious's Avatar
many ppl have this quick install cheap small gains, eliminates ac belt slippage. i think the only down fall is the fans dont blow as high(i think)
im pretty sure u can find a better price though
i would also look into get the 160 thermostat
<a href=http://s98.photobucket.com/user/repozone/media/DSCN0298.jpg.html target=_blank><img src=http://i98.photobucket.com/albums/l259/repozone/DSCN0298.jpg border=0 alt= /></a>
Scorpious is offline   Reply With Quote
Old 11-21-2012, 03:18 PM   #3
MSU120
MSU120's Avatar
Thats the same pulley Im currenlty looking at.
SOLD--2009 G8 GT, Livernois "Mini Stroker" with 1C Cam
2300 Maggie, 1:1 Cog Drive, 60# Injectors, Roto-Fab Intake
Kooks 1 7/8 Mids with High Flow Cats, Borla Cat Back
ZL1 Fuel Pump, Kenne Bell BAP, 160 Degree T-stat
Camaro 3.27 Rear Diff, Livernois Tune
Monroe Sport GT Shocks/Struts with King Springs
BMR Front Sway Bar, BMR Strut Mounts and Bearings
Camaro Transmission Pan
Staggered Bretyon GTS-AV Wheels, Nitto NT05 Tires
605rwhp and 569rwtq
MSU120 is offline   Reply With Quote
Old 11-21-2012, 04:35 PM   #4
SEESEVEN
I run this pulley, I dont recomend it if you plan on revving past 6200. thats when i throw ac belts.
PBM 09 G8 GT premium, 226/234 PatG Cam, 2800 PI Stall, Pacesetter Headers, Full custom 3" exhaust, Fast 102, NW 102, ls7 maf, Treadstone Performance maf housing, HPTuners self-tuned. 442 RWHP with stock heads
SEESEVEN is offline   Reply With Quote
Old 11-21-2012, 04:54 PM   #5
1gr8ate
1gr8ate's Avatar
Im running the slp version had it for 35k miles never a problem make a decent gain butt dyno wise!
1gr8ate is offline   Reply With Quote
Old 11-22-2012, 07:57 PM   #6
72GTOGUY
72GTOGUY's Avatar
Thanks for the info, guys so I'm getting that it gets rid of AC belt slippage, but also in some cases, makes it worse? How can this be? the lower temp thermostat is a great idea to keep from overheating. I'm looking for cheap upgrades that make the most bang for their buck. It is out of the question if I have to pay another $400 for a dyno tune just to make 12whp
Old 11-25-2012, 12:57 PM   #7
BTWS6
BTWS6's Avatar
Don't forget a good set of tires. All the power in the world wont matter if you can't hook up. Last summer when we went to the track I was spinning the tires way past the 60' mark. Next season will be a different. I'm glad you posted about the pulleys because that was a thought I had also.
Sport package, performance package,
Vararam CAI,Kooks 1 7/8" headers, Magnaflow exhaust, Cat delete,electric dumps, Pat G. tune, 4D's 20" AO6 wheels, custom L.E.D. interior/exterior light package,Polk audio subs with Kicker door speakers,3,000 watt amps. Full HID light set up, 8" SS stripe set,
BTWS6 is offline   Reply With Quote
