Plastidip experts.... how to get clean edges?? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Appearance / Detailing
Old 11-27-2012, 08:22 PM   #1
cstmg8
cstmg8's Avatar
Default Plastidip experts.... how to get clean edges??
Every time i try to remove my tape from a large surface, it peels the pd with it. I've tried several methods, what am I missing?
Shaun
Sent from my DROID RAZR using AutoGuide App
09 panther black G8 GT
Show:19x9.5's rear w/rolled fenders, 18x9.5's front, 20% tint, trim/lense tint in progress, sub rewire, amp adj, VIM w/ dvd in gb, interior blackout in progress.
Go: spectre, hsrk, lpm, pacesetter LTs, full 2.5" cat/mid/res delete, flowmaster ABs, INTENSE tune.
97 Red GP GTP- ECM, headers, custom exhaust, ported blower, heads, TB, CAI, etc....... sold
91 GP GTP- L67 swap, tranny, headers, exhaust, ECM, and a few more.... ;-) sold
cstmg8 is offline   Reply With Quote
Old 11-27-2012, 08:33 PM   #2
DavesWhiteHot
DavesWhiteHot's Avatar
Razor blade at the tape line as you are pulling the tape up.
New: '12 Mustang GT 5.0 6MT (SR lowering springs, Borla Touring axle back, CAI, Bama tune, 3" O/R H pipe)
***SOLD :"( ***
'09 White Hot G8 GT, Pat G cam (.634"/.608", 223/230, 112 + 2), Pat G tune, HSRK, Rotofab CAI, Magnaflow Catback, DT Tri-Y LT's, Rick Crawford intake, throttle body, and ported/milled heads, stock gears & stock stall, H & R springs, Lovells poly strut mounts, VMR V710 wheels, 11.86 @ 120.32 mph (1.94 60')
DavesWhiteHot is offline   Reply With Quote
Old 11-27-2012, 08:36 PM   #3
cstmg8
cstmg8's Avatar
Hmm, ok. I was worried about scoring my paint.
Old 11-27-2012, 09:07 PM   #4
Blitz
Blitz's Avatar
What exactly are you trip to PlastiDip?
Blitz is offline   Reply With Quote
Old 11-27-2012, 09:12 PM   #5
cstmg8
cstmg8's Avatar
My hood. Kinda like a reverse firehawk, matte on sides, shiny center. I'm covering up some bad paint untill spring when i can get a new hood.
Old 11-27-2012, 09:22 PM   #6
Blitz
Blitz's Avatar
A good quality tape and pull the tape edge up and away as you remove it.
Old 11-27-2012, 09:30 PM   #7
deezomaxima
MUSCLE Biotch!
deezomaxima's Avatar
I pull the tape up while it's wet.
97 Nissan Maxima - Engine croaked at 396K - Replacement 13,000 mile engine install and clean as hell inside
2008 White Hot G8 GT - SC 91 and Roto Tune
Morimoto - Pennzoil Pure Plus NG Syn - Mobile 1 Filters - Harbor Freight - 3M - Spectre - Superchips Flashpaq - SuperBrightLED - Cooper Tires - Camaro SS Pan
deezomaxima is offline   Reply With Quote
Old 11-27-2012, 09:33 PM   #8
Agose25
Agose25's Avatar
Hmm... Usually folks are doing accessory items, wheels, or trim...something with texture. Not saying it cant be done, but definitely a challenge. If there is any wax on the car I dont know how it would possibly adhere?
Old 11-27-2012, 09:43 PM   #9
joeygr8gt
joeygr8gt's Avatar
The only best and neat way to have a perfect line it to pull tape as soon as u spray it. As soon as it dries it forms the seal to the tape and cutting is not best way.
kooks LT headers, hi flow cats, x pipe, corsa exhaust, Vararam CAI, ported TB/intake manifold, underdrive pulley, catch can, qtp electric cut outs, 160 t stat, HSRK, H&R lowering springs, BMR sway bar
12.6 @109-old tune
joeygr8gt is offline   Reply With Quote
Old 11-27-2012, 10:15 PM   #10
deezomaxima
MUSCLE Biotch!
I don't think wax is an issue but there can't be any type of grease on the paint. It won't adhere properly.
Old 11-27-2012, 10:36 PM   #11
viperguy212
Edges are hard, best way is to spray fast and peal once you have a solid build up. This is how I did my front bumper and it turned out great. Razor blades can cause a lot of damage if you aren't careful.
Check out http://www.youtube.com/user/DipYourCarcom for more insight, this guy has pretty much dipped everything automotive wise.
viperguy212 is offline   Reply With Quote
Old 11-27-2012, 11:14 PM   #12
SmokeyBear911
SmokeyBear911's Avatar
Pull it wet...
And or the razor on the tape edge...
Liquid Red GXP, Sun and stick !
#611 of 1829
SmokeyBear911 is offline   Reply With Quote
Old 11-28-2012, 07:10 AM   #13
Back in a Pontiac
Back in a Pontiac's Avatar
People are doing whole cars with it now, at a car show there was a guy handing out plastidip cards, he has made a business of it.
When i spray heavy coatings on boats the key is to remove the tape when its wet. Mask your surface off and leave the tape that is going up against the dip for last this way you can pull it and not have to deal with the rest of the masking potentially falling into your work. Use quality tape too
Back in a Pontiac is offline   Reply With Quote
Old 11-28-2012, 08:50 AM   #14
DavesWhiteHot
I agree if you can take the tape off while the Plasti-dip is wet, that's the best way to do it. But......I typically do 3-4 coats of the stuff and let it dry 20-30 min between coats. So I normally just use the razor blade. But it's true, you have to be very careful as to not scar the paint in the process.
I guess if you just did one initial really heavy coat and then immediately took the tape off that would work, as long as you didn't miss any spots.
***SOLD :"( ***
Old 11-28-2012, 09:45 AM   #15
1gr8ate
1gr8ate's Avatar
Does it come off in drive threw car washes or how do you wash you car with it on? Im asking cause im thinking of doing my whole ws6 in plasti-dip.
1gr8ate is offline   Reply With Quote
Old 11-28-2012, 10:19 AM   #16
f3racer
ive never had an issue with it peeling in car washes
f3racer is offline   Reply With Quote
Old 11-28-2012, 02:02 PM   #17
SmokeyBear911
This stuff doesn't come off @ all...
I even pressure washed it... Not really close with the nozzle, but I cleaned it...
#611 of 1829
Old 11-28-2012, 02:04 PM   #18
Agose25
Agose25's Avatar
+1
My Plasti Dipped front grill looks like I sprayed it yesterday. I did it 3 years ago and it has survived many a hot summer in Dallas.
Old 11-28-2012, 03:07 PM   #19
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
This thing is the shiat I'm doing my front grills, right as type this, just finished the 3rd coat. Do i have to wait 4 hours before putting them back ? (the can says to wait 4 hours dry time before use ?
Old 11-28-2012, 03:19 PM   #20
Youngbuck
How do you get the front grills out? I would like to do it.
Youngbuck is offline   Reply With Quote
