GXP rear diff. fluid change - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Drivetrain Tech
Drivetrain Tech 5L40 A5 / 6L80 A6 / TR6060 M6 / ZF Rear Diff
Old 11-30-2012, 07:20 PM   #1
Bo White
Bo White's Avatar
Default GXP rear diff. fluid change
Changed mine today(just shy of 30k miles) and went with 1.3qts of Mobil 1 75w90. So far so good, really noticed a difference- seems smoother now. Mine was pretty quiet to begin with, reason I changed the fluid is to keep it that way.
Old 11-30-2012, 11:00 PM   #2
TryMe
QWIK
TryMe's Avatar
Is it recommended to change diff fluid based solely on mileage or time as well?
99 Trans Am WS-6 6 speed convertible w/a few mods
2011 CTS-V sedan in Evolution Green:
Borla, intake/pulley/tune
579 whp/603 lb feet ***SOLD***
09 GXP M6 MSM, Onyx/Red, roof,
415 miles 4/1/12...4200 miles 6/1/14
Solo Exhaust, Cammed & Tuned, RotoFab, Kooks LTH
14 Corvette Stingray, M7, Z51
AFe CAI, Weapon X TB, Kooks LTH's
TryMe is offline   Reply With Quote
Old 11-30-2012, 11:31 PM   #3
courtroom19
courtroom19's Avatar
There is no official service interval for changing the rear diff fluid on the G8 in our owners manual. However, the "Severe service" interval for Camaros is 80,000 km / 50,000 Miles. There is no time interval.
Need Wheels or Tires? I can help.
09 MGM GT 1SD With Roof. Sold
09 PSM G8 GXP M6 (1 of 9)SOLD
courtroom19 is offline   Reply With Quote
Old 12-01-2012, 12:15 AM   #4
JCMG8
Might want to do more research on the oil used. Our G8 diffs are not the same as the camaro as far as fluid requirements. The G8 spec calls for a specific oil with a carbon additive. Head to the other board and search on Castrol SAF Carbon Mod+. Based on info from that board, there is not a cross reference to another supplier. It may be dated info, but it may be worth looking into. The carbon additive is not the same as the friction modifier that can be added for generic LSD's.
9.5 RPM (Red Passion Metallic) Sport /Premium
ICOM 208H
"Experience is what you get when you didn't get what you wanted."- unknown
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. -red green
<img src=http://www.g8board.com/forums/signaturepics/sigpic9701_2.gif border=0 alt= />
JCMG8 is offline   Reply With Quote
Old 12-01-2012, 12:28 AM   #5
courtroom19
I realize that, I was just using the Camaro for a mileage comparison as an earliest imaginable mileage interval, since there isn't a recommended interval for the G8.
Old 12-01-2012, 09:40 AM   #6
Bo White
Bo White's Avatar
There are quite a few G8 owners that have aftermarket synthetic 75w90 lubes in theirs. I think it actually calls for a 75w85 if Im not badly mistaken.
Old 12-01-2012, 10:46 AM   #7
JCMG8
here is a clip from the GM ESi (courtesy of CP)
FWIW, I looked in GM ESi owners manual and service manual, the only reference to diff lube was above. No weight specification given.
Not saying other oil won't work, it's just not specified by GM. I do suspect, GM would not fill the diff with this expensive stuff if not needed.
As a foot note, while looking, I did see where GM recommends brake fluid flush every two years.
ICOM 208H
Old 12-01-2012, 10:54 AM   #8
AlbertGT
AlbertGT's Avatar
On Alldata it shows for fluid type:
Differential Lubricant Castrol SAF Carbon Mod
IMPORTANT: Both LSD and Non-LSD Differentials use the same fluid.
1.32 QTs
And for the interval:
It does not show anything for the interval in normal and severe service scheduals
Albert
2008 G8 GT tastefully modded, dyno 370 HP 390 TQ
R.I.P. 2008 G8 GT, all stock
AlbertGT is offline   Reply With Quote
Old 12-01-2012, 10:57 AM   #9
AlbertGT
AlbertGT's Avatar
What about Holden, do they have a recomendation for the Com.?
Albert
Old 12-01-2012, 12:30 PM   #10
Got 8?
They say it's "lubed for life" like the tranny...
'09 SBM G8 GT - GT7 (Sport and Premium packages w/ Sunroof), Lovells Eliminator Super Low Combo, Pedders Street 1 , BMR sways...
Got 8? is offline   Reply With Quote
Old 12-01-2012, 02:10 PM   #11
courtroom19
I was trying to find this last night. In North America, you can get a PDF owners manual online from just about any manufacturer. But I could not seem to trace one down for the Commodore.
Old 12-01-2012, 03:05 PM   #12
I12XLR8
Proud OGOC member!
I12XLR8's Avatar
Using 75W90 will work fine in most cases but the dealer can void your warranty on the part for using the wrong fluid. Toyota does it all the time in their trucks...
"I have dreamed a dream, and now that dream has gone from me" - Morpheus of the Nebuchadnezzar, and Grant of I12XLR8.
'Luskville is a cool experience, Calabogie is incredible, Mosport is life altering'
I12XLR8 is offline   Reply With Quote
Old 12-01-2012, 05:40 PM   #13
JCMG8
FWIW, here is the labels of the GM recommended lube. Note the reference towards diffs with carbon linings:
ICOM 208H
Old 12-01-2012, 07:19 PM   #14
Got 8?
So just use this w/o the LSD additive ???
Old 12-01-2012, 08:05 PM   #15
JCMG8
^ correct
ICOM 208H
Old 12-01-2012, 08:50 PM   #16
Got 8?
^ correct
Cool...thanks !!!
Old 12-02-2012, 12:25 PM   #17
Bo White
Bo White's Avatar
Same with Mobil 1, just put it in. Took 1.3qrt dead on the money almost. Mine is smooth as silk.
