Goodyear Gatorbacks... Worth it? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Community > G8 GT Talk (V8)
Old 12-05-2012, 02:35 PM   #1
KevlarDreams
KevlarDreams's Avatar
Default Goodyear Gatorbacks... Worth it?
I recently changed over from my stock belts to Goodyear Gatorbacks, due to constant tearing of belts. I have since torn one of the Gatorbacks and had to replace it. Is this due to anything in particular? I use an SLP 25% crank pulley currently. Maybe that has something to due with it? Or, are the Gatorbacks just a gimmick?
2008 IOM G8 GT
-Premium & Sport, Roof; New Era OTR CAI, Corsa Full Catback; 4/4 Camaro Brembos, Granatelli Slotted/Dimpled Rotors, Brembo Ferrado pads, Russell Stainless Lines, Super Blue; AR885's wrapped in Nitto NT-555, 20x8.5 245/35/ZR20 Frt, 20x10 285/30/ZR20 Rear, SV-6 Spoiler
Waiting to go on: Ported Mani & TB, SLP 25% UDP; Kooks 1 7/8" LT's
CURRENTLY FOR SALE http://www.g8board.com/forums/showthread.php?t=117226
KevlarDreams is offline   Reply With Quote
Old 12-05-2012, 04:08 PM   #2
lonewolfz28
Master Sheep Hurdler
lonewolfz28's Avatar
The Gatorbacks eliminated an annoying squeak under my hood. But, that's not saying a set of new stock belts wouldn't have done the same thing.
They were installed ~5000 miles ago. So far, so good. FWIW, I still have the stock pulleys with ~80,000 miles on them.
'08 G8 GT- White/Premium 395 of 888
Mods: Superchips Cortex tune; Modded New Era OTR CAI; HSRK; Custom intake heat shield; Baer Front BBK; BMR Adjustable Rear LCA's, Toe Rods, Trailing Arms, Sway Bars/Sway Bar Links & Poly Strut Mounts; Pedders Front LCA's, Shocks and Poly Rear Sub-frame, Rear Upper Arm & Differential Bushings; Bridgestone Potenza RE-11 265/40-18 tires.
lonewolfz28 is offline   Reply With Quote
Old 12-05-2012, 04:53 PM   #3
GOPHERIT
My take on this is, if the damage is showing up first at the outer edges and migrating inward slowly over time, that you have one or more belt pulleys out of true alignment. I would think that (that) would start carving up the belt outer edges pretty quickly. If its the backside of the belt showing the problem (smooth side starting to scrape through), then you should check all the idler and tension-er pulleys (smooth surfaced free spinning) for proper operation and surface condition.
Old 12-05-2012, 04:56 PM   #4
KevlarDreams
I think I need to make a rephrase, as where I used the word torn. My belts have snapped right apart. I'm not outputting tons of HP, so I don't understand. It's happened 3 times with stock belts and once, so far, with GB's.
2008 IOM G8 GT
Old 12-05-2012, 05:07 PM   #5
GOPHERIT
Then you best take that big serpentine belt off, an perform an in-depth check of all the rotating pulleys (ribbed and smooth) as needed. I think Gatorbacks are a very good brand of belts. Sounds like something is very scarred up or is binding when under its normal tension load.
Old 12-05-2012, 06:32 PM   #6
Norm8332
G8 GT GUY
Norm8332's Avatar
I run gatorbacks on all of my cars, they have been great - and quiet. I installed a 1 size shorter GB on my AC after throwing the stock belt and it hasn't come off since. And no issues with slippage on my supercharger. I highly recommend them. Like said above look for pulley issues. Something must be misaligned.
2008 G8 GT: Magnacharger TVS MP1900 @9psi, LS9 cam, 72# injectors,SLP Headers, Corsa catback
Norm8332 is offline   Reply With Quote
Old 12-05-2012, 06:42 PM   #7
KevlarDreams
Not serpentine, it's the comp belt. I work at a GM dealership, left my car in the shop for entire work days more than a few times. Nothing chunky on pulleys, no misalignment. It's a mystery. The only thing that has ever been suggested to me is that my tourqe converter may be snapping into action so hard, that the belt may be stretching to the point of snapping before it gets the chance to start rotating. But, we haven't found any clear evidence of that, being that there is no real way to test and detect that with the human eye.
2008 IOM G8 GT
Old 12-05-2012, 06:44 PM   #8
KevlarDreams
Also, I'm just not outputting enough tourqe to make that happen.
2008 IOM G8 GT
Old 12-05-2012, 08:24 PM   #9
Norm8332
G8 GT GUY
Norm8332's Avatar
This is a somewhat common issue. Check and see if the balancer is wobbly. If it is that could be the problem, some have needed it replaced. This has happened to others that were totally stock.
The belt is most likely comming off and then getting shredded. I replaced mine with a slightly shorter than stock GB part # 4040425. There is also an upgraded pulley solution available for this issue.
Old 12-05-2012, 08:35 PM   #10
KevlarDreams
I've been toying with the idea of the upgraded pulley as of late. Will definitely try the shorter belt though. Thank you for the advice!
2008 IOM G8 GT
Old 12-05-2012, 08:46 PM   #11
AlbertGT
AlbertGT's Avatar
Post some pics after the belt snapping of the breaking point.
Have you noticed the driving condition just prior to when they snap?
I have been using GB belts for over 10 years, for both drive and timing belts and have never had an issue with any car after installed. I cant even recall the last one that actually wore out or started cracking...
Albert
2008 G8 GT tastefully modded, dyno 370 HP 390 TQ
R.I.P. 2008 G8 GT, all stock
AlbertGT is offline   Reply With Quote
Old 12-05-2012, 08:49 PM   #12
KevlarDreams
It's a clean pull and snap. Happened only those few times at launch.
2008 IOM G8 GT
Old 12-06-2012, 12:17 AM   #13
GOPHERIT
Now that I'm back home, I see I was in error. My bad!! I read nothing in posts 1 and 4 to indicate to me that you were referring to *only* the AC compressor belt. I see other posts have assisted you in that area.
Old 12-06-2012, 12:38 AM   #14
courtroom19
courtroom19's Avatar
If your working at the dealership, check out the recent TSB on the A/C belt coming off, I know that's not what you're saying the problem currently is, but the revised tensioner couldn't hurt. Think the TSB was released in around october sometime.
Need Wheels or Tires? I can help.
09 MGM GT 1SD With Roof. Sold
09 PSM G8 GXP M6 (1 of 9)SOLD
courtroom19 is offline   Reply With Quote
Old 12-08-2012, 08:09 AM   #15
Eric_GT
Eric_GT's Avatar
Funny, I thought this thread was about the tires.
Anyone remember them? I had them on my '86 Trans Am.
Eric_GT is offline   Reply With Quote
Old 12-21-2012, 11:48 AM   #16
KevlarDreams
Update!
Turns out that, since I started using the shorter belt, it has not been happening at all. I've been dogging it out at PBIR and having no problems at all. You're a lifesaver, Norm, thank you for the advice and part#.
2008 IOM G8 GT
Old 12-21-2012, 11:49 AM   #17
KevlarDreams
Thank you everyone else for the insightful advice you gave, also. I very much appreciate the help.
2008 IOM G8 GT
