First ticket in the G8 - THANKS A LOT "LIFT FOOT MODE"! - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Community > G8 GT Talk (V8)
Old 12-05-2012, 03:48 PM   #1
AliG8tr
No Member
AliG8tr's Avatar
Default First ticket in the G8 - THANKS A LOT "LIFT FOOT MODE"!
It's been a loong time since I've posted here but I had to share this irritating tidbit.
I was in sport mode, well... the car was in "sport mode", I was in "get the **** out of my way you idiot going 30 in a 50 mph zone" mode. I stepped on it to go around this dinosaur suburban and it "stuck" in 4th gear. I was going about 45 at that point and so I floored it (just for a second or two) to get it to shift. In that two seconds I went from 45 to 65. It still hadn't shifted to I just put it back in drive and slowed down. Next thing I know one of those infamous Lynnwood motorcycle cops was pulling me over and handing me a lovely little piece of paper.
I just sent in my mediation hearing explanation and figured maybe the judge will let me off since it clearly wasn't MY fault. *sigh* The worst part is I deferred a ticket 11 months before. @#%# $T%@ #$#$!!!
I haven't really researched the "lift foot mode" (I think that's what it's called) but it seems like it was hanging on way longer than I would expect. Is there an rpm point that it's supposed to shift?
2009 Liquid Red G8 GT - Premium, Sunroof
Cat-back H-pipe with Flowmaster Super 44s
20" Lorenzo WL021s
Partial Debadge
Clock Set
Stereo Programmed
Gas Added Frequently
AliG8tr is offline   Reply With Quote
Old 12-05-2012, 04:04 PM   #2
elephantrider
****cray
elephantrider's Avatar
yes, sport mode holds the lower gear so you can
stomp on it coming out of a corner when auto
crossing
jason
02 powerstroke - slightly modded
04 gto - stroked
elephantrider is offline   Reply With Quote
Old 12-05-2012, 05:02 PM   #3
Joe'sFastG8
Joe'sFastG8's Avatar
This doesn't sound like "lift foot" mode, it sounds like "crappy stock trans tune" mode. What I gather is that you wanted the car to downshift to pass a slower vehicle and it didn't so you punched it to initiate the downshift? Is this correct? If so this is just the poorly calibrated stock trans tune that never seems to find the gear you want. "lift foot" mode is after you punch it and pass the car then let off and it won't upshift to a higher gear.
Old 12-05-2012, 05:17 PM   #4
Agose25
Agose25's Avatar
Mode Overload!
Like others have said, SPORT holds gears longer. You cant blame the car for performing as it should be. Slow down and be more patient on the road way with folks. Then you wont get tickets or a gun pulled on you.
Old 12-05-2012, 05:40 PM   #5
Silver Bullet
Super Moderator
Silver Bullet's Avatar
Originally Posted by Joe'sFastG8 View Post
This doesn't sound like "lift foot" mode, it sounds like "crappy stock trans tune" mode. What I gather is that you wanted the car to downshift to pass a slower vehicle and didn't so you punched it to initiate the downshift? Is this correct? If so this is just the poorly calibrated stock trans tune that never seems to find the gear you want. "lift foot" mode is after you punch it and pass the car then let off and it won't upshift to a higher gear.
I think I have experienced both things the OP is referring to. I didnt lift foot mode was an actual thing though. THere have definitely been times that I punch it and let off and the trans just stays in 4th for a while then finally goes into 5th like 20-30 seconds later and on into 6th. Its like the car is saying "play time is over already.....are you suuuuuuuure" haha.
The other issue usually happens to me on my on ramp to work. Its like Im in 5th coming off the ramp and I start to ease down on it to go around some people so it goes into 4th but thats not quite enough so I ease down on it some more and all the sudden it jumps into 2nd at about 50 mph like its ready to rip someones head off.
-2009.5 MSM Premium GT-
Mods: Brembos, OBX Headers to Maxflows, VCM, RCR Intake, HSRK, LS7 Maf and tuned by Pat G.
In The Garage: Yank 2800 stall, SLP UDP, Pedders Coilovers
10.59 at 100.31 in the 1000.....8.33 at 88.13 in the 1/8....1.99 60 ft
Silver Bullet is offline   Reply With Quote
Old 12-05-2012, 06:10 PM   #6
AliG8tr
No Member
AliG8tr's Avatar
It's done the same thing one or two times before in the past three years. I looked it up on here and it seems to fit the "performance mode/lift foot mode" kind of, but it just.... gets stuck. To describe it further, I am speeding up and when it get's into fourth it stays. In the times it's happened I've tried taking my foot off the gas and slowing down; slowly and steadily increasing speed; stomping it; and once I even tried to upshift into fifth manually but every time it just revs the piss out of the engine (3000-4000rpms) and stays in fourth. It certainly doesn't feel like a performance feature but maybe I'm just being a wuss and it's supposed to shift at 4500 or something!
For those of you that have experience with performance/lift foot mode, at what point did it shift? When it happens I feel like I'm in some weird game of chicken or something.
20" Lorenzo WL021s
Partial Debadge
Clock Set
Stereo Programmed
Old 12-05-2012, 06:40 PM   #7
DRUMSBH
Super Moderator
DRUMSBH's Avatar
I've had the same thing happen... When it happens I just push the pedal down then let off right away and it then changes gears.
Sent from my EVO using AutoGuide App
08' Pontiac G8 GT PBM
11.323@121.66 Rock Falls Raceway 10-11-14
N/A RCR car.
DRUMSBH is offline   Reply With Quote
Old 12-05-2012, 07:17 PM   #8
elephantrider
****cray
it will fall out of sport mode if rpm's continue to go down,
and eventually shift.
jason
04 gto - stroked
Old 12-05-2012, 08:40 PM   #9
sweetair
I'm jealous. You have a transmission that is working right now.
sweetair is offline   Reply With Quote
Old 12-06-2012, 09:49 AM   #10
ColdFuzion
If anything the person 30 in a 50 should have been pulled over and ticketed. Its kind of sad when someone out of the norm on the road causes someone else to get a ticket trying to do the norm. Lets not try to make him look like the bad guy for wanting to pass a slow ass.
2009 White Hot GXP
2009 Stryker Blue GT
ColdFuzion is offline   Reply With Quote
Old 12-06-2012, 09:57 AM   #11
mlittleton
Mack
LOL awesome!!!
mlittleton is offline   Reply With Quote
Old 12-06-2012, 11:36 AM   #12
AliG8tr
No Member
AliG8tr's Avatar
Thank you. And it would be "her look like a bad guy" bad girl??? Bad guy sounds better.
20" Lorenzo WL021s
Partial Debadge
Clock Set
Stereo Programmed
Old 12-06-2012, 11:41 AM   #13
zepcom
yea, when that happens and I'm not thrashing it around, I slide right back over to "D" mode quickly and it fixes itself in a second or so, but hey, not sure if you had that much time to do the same if you did it right in front of the cop.
What's more fun is driving in manual mode and pre-selecting a higher RPM gear to advance to pass, and being in full control of RPM's / engine sound / speed. Still might have gotten the ticket if you were going too much faster than 50, but the sounds might have been quieter and might not have caught the cops attention.
That certainly is Performance Lift mode though. Only available in sport.
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Old 12-06-2012, 11:46 AM   #14
colby1035
colby1035's Avatar
Your car functioned as designed. The "lift/foot mode" Holds the gear for 20ish seconds. It is designed to keep you in the power band going around a corner, so as not to abrublty downshift half way through a corner and upset the balance of the car. If you think back, I bet the times it happened was always on a curve of some sort.
The car will shift in this mode - at redline. Or after the 20 or so seconds of easy driving. Or if you shift back into drive
09.1 White Hot, Sport/Premium
colby1035 is offline   Reply With Quote
Old 12-06-2012, 11:55 AM   #15
AliG8tr
No Member
AliG8tr's Avatar
That's what I was wondering, when it will shift. And yeah... it was a slight corner. So... thanks for the info. guys. Now I know what to expect. I wonder if the judge will have this info. It probably wouldn't help my hearing if he did.
20" Lorenzo WL021s
Partial Debadge
Clock Set
Stereo Programmed
Old 12-06-2012, 01:01 PM   #16
Silver Bullet
Super Moderator
Most likely the only argument that would help would be some kind of mode that would accelerate for you. Good luck anyway. Pesky popo always trying to ruin the fun!...haha
Old 12-06-2012, 05:30 PM   #17
MotorCityG8
MotorCityG8's Avatar
Yeah the OP could probably get out of the ticket by using the guilty with a reason and say you are guilty and explain what happened and just ask for no points. Thats what I would do
On a side note when Im in sport mode and do this I'll tap it up to up**** or just slide it back over to D with my tune it does the trick everytime.
13' Ford Focus ST2
2008 G8 GT PBM / No Roof - SOLD
Go: Livernois Stage 1 Cam / Circle D 3000 Stall / Ported TB & Intake / Roto-Fab CAI / Pat G Tune / SLP Powerflow Axlebacks / OBX 1 7/8 LT w/3in midpipe / LS7 MAF
Show: Avant Garde M310 / Eibach & Fe3 set up / Plasti Dipped Wheel and Kidney grills / Debadged / Tint (20% windshield, 5% sides, 20% on top of 5% on the rear) / Bathurst Stripes.
MotorCityG8 is offline   Reply With Quote
Old 12-21-2012, 11:55 AM   #18
KevlarDreams
KevlarDreams's Avatar
Slow down, you whiper-snapper!!! hahahaha
2008 IOM G8 GT
-Premium & Sport, Roof; New Era OTR CAI, Corsa Full Catback; 4/4 Camaro Brembos, Granatelli Slotted/Dimpled Rotors, Brembo Ferrado pads, Russell Stainless Lines, Super Blue; AR885's wrapped in Nitto NT-555, 20x8.5 245/35/ZR20 Frt, 20x10 285/30/ZR20 Rear, SV-6 Spoiler
Waiting to go on: Ported Mani & TB, SLP 25% UDP; Kooks 1 7/8" LT's
CURRENTLY FOR SALE http://www.g8board.com/forums/showthread.php?t=117226
KevlarDreams is offline   Reply With Quote
Old 12-21-2012, 12:21 PM   #19
Earl Flynn
Earl Flynn's Avatar
Red face
I NEVER use sport mode because the shifting is too wacky for my taste. I didn't have a sport mode in my G6 GXP and I lived by the auto shifter in that car, same for the G8 as soon as I got use to the RPM's
I live by the manual shift so that I can control the gears in instances like being watched or flanked by a police.
Only 1 ticket in the 3 years I had the G6 (should have been 2, got caught doing 120mph by state police.....)
So far none in the G8 but based that I drive this wayyyyy harder than that 6 makes me believe I'm just lucky
Earl Flynn is offline   Reply With Quote
