Kooks LTs to Corsa with catted connection question - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 12-05-2012, 06:02 PM   #1
Link112
Link112's Avatar
Default Kooks LTs to Corsa with catted connection question
Those with this setup, did the kooks cat connection for the Corsa system fit together nicely? Mine was a tight fit and really had to be muscled to get them to line up when attached to the Corsa x pipe. With one side attached the other was off by about 2"-3". My concern is that this pressure will over time affect the headers. Does this sound normal?
Thx!!
'09 G8 GXP / M6 / MSM / Onyx / Roof / #806 of 1829
Dominator 2 cam and custom tune, 468 RWHP, Kooks LTH, Corsa HFC & Exhaust, MGM Shifter, Rotofab CAI.
'08 Bullitt Mustang #765 (gone)
Link112 is offline   Reply With Quote
Old 12-05-2012, 07:53 PM   #2
BODYSHOPG8
BODYSHOPG8's Avatar
I would try to loosen everything up again and start over and see what that does
BODYSHOPG8 is offline   Reply With Quote
Old 12-06-2012, 01:43 AM   #3
G8One2
There are left and right sides to the Corsa catback pipes. If they got mixed & match or just plain put on the wrong side, it wont fit together correctly. One side of the exhaust is a tad longer then the other. If you have your instructions still, you can reference that and the part numbers on the pipes themselves to get them on the correct sides. Also, when clamping the exhaust, you don't need to shove the pipe all the way into the connecting pipe, just need it to slip past the slot in the pipe.
G8One2 is online now   Reply With Quote
Old 12-07-2012, 10:04 AM   #4
Link112
Link112's Avatar
Thanks! I thought I had it all right from the beginning, but I will climb back under and give it a shot.
