ls3 camshaft - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 12-06-2012, 10:20 AM   #1
alabushal
alabushal's Avatar
Default ls3 camshaft
hi all
what is the best ls3 camshaft for daily use thx
i have a G8 GXP 2009 ls3
alabushal is offline   Reply With Quote
Old 12-06-2012, 10:42 AM   #2
Joe'sFastG8
Joe'sFastG8's Avatar
Originally Posted by alabushal View Post
hi all
Well it all depends on what your looking for. What cam would be "best" is very subjective. There are many people here that can help you pick a cam if you provide a little more info about what you plan on doing with the car. Are you looking for max power? Is street-ability a concern are you only headed to the track?
Edit: Sorry I see you already stated it's a daily driver. There are several threads on this topic. I'm sure if you search around a little bit you can find some good recommendations.
Old 12-06-2012, 10:56 AM   #3
alabushal
alabushal's Avatar
about 40hp i don't like it to be with hi loop big sound because i use the car for
daily use
THX
Old 12-06-2012, 11:24 AM   #4
Nothin_But_Tail_Lights
Nothin_But_Tail_Lights's Avatar
Livernois stage 1c, I used it with just bolt on's in my daily driver with stock converter and it had great driveability. It made 436 rwhp. There's other good ones out there too, that's just my personal favorite. But make sure and get a good tune as that will play a very large role in how good of a daily driver it makes. Good luck!
2008 Black G8 GT - R.I.P (Totaled May 2012)
New ERA OTR Intake, Kooks LT Headers, Koxks X-pipe & Axel Back, Tein suspension
2009 Red G8 GT - Daily driver
Maggie 2300 @ 9 psi with rear 1:1 cog drive, KB BAP, Livernois Stage 1 Cam Kit, 3 Bar Map, Milled Heads, Ported TB & Intake, Doug Thorley LT headers, Borla exhaust, Roto Fab CAI, Eibach lowering Springs, BMR Trailing Arms, BMR Toe Rods, GXP Front Fascia and Rear Diffuser, Tuned by Livernois Motorsports...
592rwhp & 544rwtq
Nothin_But_Tail_Lights is offline   Reply With Quote
Old 12-06-2012, 06:58 PM   #5
gr8t gt
gr8t gt's Avatar
The LS9 cam should be worth 30-40hp NA. New from GM it's a little over $100.00, idles like a stocker, still has good low end, and pulls to 6500rpm.
I would also suggest using LS9 spark plugs #41-104 which are the colder than any other LS plug and get another deg or 2 of timing for more power.
Rare '09 MGM GT7 ONYX/RED
TVS1900 @ 6.5psi, Kooks LT, Cats, SLP Powerflow Mufflers, Swiss cheese stock air box, LS9 Cam and Injectors, BAP
516 rwhp-462 rwtq (time for larger injectors and more boost)
'11 Silverdo LTZ DuraMax
Stock (for now)
'12 Mustang GT/CS
Loud Ass Flowmaster's (wife's car)
gr8t gt is offline   Reply With Quote
Old 12-06-2012, 07:14 PM   #6
Todasi
Todasi's Avatar
Question I just thought about is, could he run the LS9 cam with 1.85 roller rockers for a little extra umphf?
-Chad H.
09 G8 GT, White Hot
Suspension: VMR 19" V701 255/40/19, 285/35/19 Conti DW's
Eibach, Koni, Lovells, BMR
Brakes: Brembos Black/White
Engine: VCM OTR, RCR TB/Intake/Heads,
223/231 .625 .622 111+0, RCR tuned
Kook's
Coan Triple-Disk 3100, 3.45 fd
11.770 @ 118.11 mph 4130 lbs
Todasi is offline   Reply With Quote
Old 12-06-2012, 07:23 PM   #7
gr8t gt
gr8t gt's Avatar
Lift with 1.85 rockers would be .612 intake, .606 exhaust.
Stock (for now)
'12 Mustang GT/CS
Old 12-06-2012, 10:45 PM   #8
bostonf4$
hi all
Uhh, call me crazy but probably the one that was engineered for it and that it came with.
Sorry. Had to.
Old 12-07-2012, 08:45 AM   #9
alabushal
alabushal's Avatar
this is what i have on my g8 gxp
CR8 393 RWHP 387 ft V8 6.2L A6; Magna Flow 3 ''COMPETITION SERIES; DUAL SPLIT REAR EXIT Part Number 16857 REAR TIRE Conti Sport Contact3 295/30/19 9.5 FRONT tire Hankook Ventus S1 Evo K107 245/35/19 8.0 KOOKS Headers 1 7/8 VCM OTR Intake Air Filter SLP pulley Eibach PRO-KIT stage 1 Springs AEM WIDEBAND
Old 12-07-2012, 09:03 AM   #10
Silver Bullet
Super Moderator
Silver Bullet's Avatar
Has anyone else made numbers like that from the 1c cam? Those are the highest numbers I have seen for a stock heads stock stall cam/ bolt-on car.
-2009.5 MSM Premium GT-
Mods: Brembos, OBX Headers to Maxflows, VCM, RCR Intake, HSRK, LS7 Maf and tuned by Pat G.
In The Garage: Yank 2800 stall, SLP UDP, Pedders Coilovers
10.59 at 100.31 in the 1000.....8.33 at 88.13 in the 1/8....1.99 60 ft
Silver Bullet is offline   Reply With Quote
Old 12-07-2012, 09:11 AM   #11
MotorCityG8
MotorCityG8's Avatar
Yeah those numbers are huge for a GT. IF you had a GXP then that would make more sense.
13' Ford Focus ST2
2008 G8 GT PBM / No Roof - SOLD
Go: Livernois Stage 1 Cam / Circle D 3000 Stall / Ported TB & Intake / Roto-Fab CAI / Pat G Tune / SLP Powerflow Axlebacks / OBX 1 7/8 LT w/3in midpipe / LS7 MAF
Show: Avant Garde M310 / Eibach & Fe3 set up / Plasti Dipped Wheel and Kidney grills / Debadged / Tint (20% windshield, 5% sides, 20% on top of 5% on the rear) / Bathurst Stripes.
MotorCityG8 is offline   Reply With Quote
Old 12-07-2012, 09:21 AM   #12
There's a video of it doing it on livernois website. Go to video's, then more videos at the bottom, then scroll down and it's listed as Ryan's G8 or something like that. It was the former owner, I had the maggie put on by them and they have a video of the dyno for my current setup, they just haven't posted it yet. It's a GT, and those are the real #'s from a dynojet. It also has ported intake & TB, but that wouldn't account for the difference in "huge" #'s. It's really all about the tune, and they do a great job!
592rwhp & 544rwtq
Old 12-07-2012, 09:27 AM   #13
Here's a link
It's listed as a 2008, but it's really a 2009. Also, i've since changed the wheels.
592rwhp & 544rwtq
Old 12-07-2012, 09:44 AM   #14
MotorCityG8
Here's a link http://www.youtube.com/watch?v=lBlN54nkdAs It's listed as a 2008, but it's really a 2009. Also, i've since changed the wheels.
That's a stage 1 cam not a 1C. Which makes sense its basically the exact set up I have...
13' Ford Focus ST2
Old 12-07-2012, 09:50 AM   #15
I was wondering what all the fuss was about, that was a mistype in my original post. That's my bad, sorry for the confusion. Although the 1c would probably be best suited for him if he doesn't want lope, as the 1c is the "stealth" cam.
592rwhp & 544rwtq
Old 12-07-2012, 09:55 AM   #16
MotorCityG8
True and since he has a GXP it would put him around that 440rwhp range.
13' Ford Focus ST2
Old 12-07-2012, 12:57 PM   #17
Silver Bullet
Super Moderator
Oh I wasn't trying to imply that you were providing false info I just havent seen a stock stall sized cam produce those kind of numbers before. Usually stock stall cams are like 410 at the wheels and a bigger stall cam is where you get into the 425-440 wheels hp range. Impressive.
Old 12-07-2012, 01:05 PM   #18
RamJet
RamJet's Avatar
Gr8t GT, you would recommend the LS-9 cam for a non FI setup? I have been pondering this as it is super cost effective.
2008 G8 GT PBM, DOD Delete, Pat G Spec'd Cam, 7.4 Hardened Pushrods, Comp Trunion Kit, PAC 1518 Springs, ARH 1 7/8" LT Headers Catted Exhaust, Spectre CAI, Pat G Tune.
412.198hp/396.828tq at the Wheels - Mustang Dyno
1/4 Mile, Very First Run, Stock: 13.66 @ 102.74 w/ a 2.067 60'
1/4 modified 12.49 @ 114
2008 G8 GT MGM, Leather w/ Red Inserts, Sun Roof, 18" Bremmer Wheels
1/4 mile 14.0278 @ 101.49 w/ a 2.2658 60'
DA 2260, Best Run for Lynda
RamJet is offline   Reply With Quote
Old 12-07-2012, 01:57 PM   #19
Terp4life
Its cost effective if you do the work yourself. To spend a couple thousand only to save $300 on a cam seems silly. Maybe that's just me.
Terp4life is offline   Reply With Quote
Old 12-07-2012, 02:34 PM   #20
Silver Bullet
Super Moderator
I have seen some decent results from people using the ls9 cam in FI applications but I really dont think it would make a very good cam for non FI. I doubt the gains would be worth the money spent.
