E85 now check engine light - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Intake/Fuel Tech
Intake/Fuel Tech CAI, TBI, Porting, Forced Induction, Nitrous Oxide...
Old 12-06-2012, 09:18 PM   #1
thebassbuilder
Default E85 now check engine light
i have an 09 gt and i put E85 in my car for the first time last night and before i could get home my egine light came on. My light will come on because the gas cap but checked it and it is ok. Can our cars run on E85 ok? Also I tried remote starting my car and it will not work now. what do you think?
thebassbuilder is offline   Reply With Quote
Old 12-06-2012, 09:20 PM   #2
orangeg8
Offshore Prositute
orangeg8's Avatar
I don't think our cars are flex fuel.
Don't complain about life, if you do, try death, nobody has complained yet.
I am no Challenger to this game, I don't go Chargering away, and it is more than just ponies in this beast.
orangeg8 is offline   Reply With Quote
Old 12-06-2012, 09:25 PM   #3
Zodiac
Sarcasm Personified
Car is not E85 compatible. There are few who run it with tunes and setups for it, but stock no.
2015 Mustang GT Auto, 3.55, recaro seats, spoiler delete, Solo catback, SVE Drift 19x9.5 w/ 275/40/19's.
2015 Jeep Cherokee Latitude V6
Zodiac is offline   Reply With Quote
Old 12-06-2012, 09:34 PM   #4
Slizzo
Slizzo's Avatar
Yup, stock the car isn't set up to run E85. The fuel lines and such are ok with it but the G8 lacks the programming to run it.
Also remote start is disabled any time you have a check engine light.
2011 Radiant Silver Metallic CTS-V Wagon - Corsa Axleback, AirAid Intake
2008 Panther Black Metallic G8 GT *Sold 6/11/14*
Slizzo is offline   Reply With Quote
Old 12-06-2012, 09:50 PM   #5
thebassbuilder
So I can run it if I want to live the engine light. I think the car runs stronger on it.
Old 12-06-2012, 10:06 PM   #6
Norm8332
G8 GT GUY
Norm8332's Avatar
I wouldn't. You need an ethanol sensor that our cars lack to run e85. Plus the tune doesn't support it stock. You could damage the engine running it lacking these things.
2008 G8 GT: Magnacharger TVS MP1900 @9psi, LS9 cam, 72# injectors,SLP Headers, Corsa catback
Norm8332 is offline   Reply With Quote
Old 12-06-2012, 10:16 PM   #7
thebassbuilder
Thanks norm. I will get normal gas back it then. I will tell you she pulls harder on this stuff.
Old 12-06-2012, 10:29 PM   #8
Joe'sFastG8
Joe'sFastG8's Avatar
I wouldn't be driving it at all with that in the tank. It's gotta be running dangerously lean and risking engine damage especially at WOT. Ethanol burns at a different air/fuel ratio and requires roughly 30% more fuel to burn at stoich compared to gasoline. This can be corrected with the proper tune, but otherwise get that stuff out of your tank! As stated, flex fuel cars have an alcohol sensor that determines the ethanol content and adjusts the air/fuel ratio accordingly. I'm willing to bet your check engine light is because it's running lean and your fuel trims are way out of whack.
Old 12-07-2012, 12:05 AM   #9
blkscooby
blkscooby's Avatar
Originally Posted by Joe'sFastG8 View Post
I wouldn't be driving it at all with that in the tank. It's gotta be running dangerously lean and risking engine damage. Ethanol burns at a different air/fuel ratio and requires roughly 30% more fuel to burn at stoich. This can be corrected with the proper tune, but otherwise get that stuff out of your tank! As stated, flex fuel cars have an alcohol sensor that determines the ethanol content and adjusts the air/fuel ratio accordingly. I'm willing to bet your check engine light is because it's running lean and your fuel trims are way out of whack.
This. I run E85 but i have a tune for it.
Sent from my DROID RAZR using AutoGuide.Com Free App
NEW- 2009 PSM GT- Vararam/ RCR 219/227 cam/ Kooks 1 7/8" LT/ 3" exhaust/ 3200 Yank/ 3.45 gears/ HSW Nitrous/ HPT self-tune
SOLD- 2008 LR G8 GT /
Intake / HPT self-tune / E85 / 160* stat / Kooks mids / Dynomax ST axlebacks / Xpipe / 219/233 Comp Cam
blkscooby is offline   Reply With Quote
Old 12-07-2012, 02:36 AM   #10
orangeg8
Offshore Prositute
orangeg8's Avatar
if you don't want to pump out the E85 start pumping in the highest octane you can get, and find some NOS octane booster (i think it brings up the octane level 5 real points so 93 becomes 98) and it might help you out.
Old 12-07-2012, 03:06 AM   #11
T-townGT
Crimson Cruiser
E85 is not just about the octane. Additives will not help. Higher octane gas will only dllute what you have. You are gambling right now and increasing chances of future problems.
SRM 2009 G8 GT/Premium/Sunroof/25% tint/Partial Debadge/HPtuned by Parkman/Spectre CAI
www.okg8club.com
T-townGT is offline   Reply With Quote
Old 12-07-2012, 03:19 AM   #12
frostopsy
frostopsy's Avatar
Time to drop the tank. At least it's not diesel.
frostopsy is offline   Reply With Quote
Old 12-07-2012, 08:50 AM   #13
Silver Bullet
Super Moderator
Silver Bullet's Avatar
Dropping the tank can be a big pain in the butt (so I've heard). If you were thinking about getting a tune anytime you might just wanna go that route and enjoy the extra horsepower.
Yes your car does probably feel a little faster right now because lean conditions usually make a little more power.....right before it goes boom!
-2009.5 MSM Premium GT-
Mods: Brembos, OBX Headers to Maxflows, VCM, RCR Intake, HSRK, LS7 Maf and tuned by Pat G.
In The Garage: Yank 2800 stall, SLP UDP, Pedders Coilovers
10.59 at 100.31 in the 1000.....8.33 at 88.13 in the 1/8....1.99 60 ft
Silver Bullet is offline   Reply With Quote
Old 12-07-2012, 09:05 AM   #14
zepcom
Flush system?
What are your fuel trims, and AFR? I wouldn't risk damaging the engine without proper flex-fuel tooling of the car and a corresponding tune for the engine.
There are those who DO run E85, but they're pushing big power already.
Your car stock op?
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Old 12-07-2012, 09:07 AM   #15
zepcom
Actually, I experienced this a week after owning the car.
The entire exhaust system needs to get dropped.
The entire rear cradle needs to be removed
then tank comes out from the bottom.
Definitely an involved task if you ask me.
Mine was the cause of a malfunctioning rollover valve, my tank replaced under warrantee.
I only run 93 top tier octane. I hope your engine is not getting damaged!
Old 12-07-2012, 09:21 AM   #16
Gordon0652
Wow, did I really just read this!
2000 Maple Red Metallic Trans Am A4, Grandfather Left It To Me
LME 440 LS7|TSP LXR 285cc LS7x|278/286 .718 .702 112+4|Becks 115mm|Direct Port|D&D T56 Mag|McLeod RXT
2009.5 Pontiac G8 GT SMR||KOOKs 1-7/8"|Corsa|VaraRam|223/231 .610/.617 115+4
Gordon0652 is offline   Reply With Quote
Old 12-07-2012, 09:39 AM   #17
zepcom
New Caprice PPV's have the L77 engine which is similar to the G8 GT's L76 powerplant except it is also flex fuel certified.
Might benefit you to start to research the differences in the fueling system and other bits from the PPV if you want to learn more about running Flex Fuel in your GT, OP.
Hopefully this is not a troll. Like the "I put sand in my intake to port it" golden interwebs thread from yesteryear.
Old 12-07-2012, 09:42 AM   #18
Silver Bullet
Super Moderator
Originally Posted by zepcom View Post
Flush system?
Your car stock op?
Would I benefit from running E85 with my bolt ons and a new tune to work with the E85. If there are gains to be had Im just an email and a tank of fuel away form picking up some more power.
Old 12-07-2012, 11:14 AM   #19
Silver Bullet
Super Moderator
Ok after a little looking into it I don't think the gains would be very much with my setup. I think I am going to go ahead and get an E85 tune just for trips to the track though.
Old 12-07-2012, 12:01 PM   #20
themanran2000
1FASTG8GT
themanran2000's Avatar
Im happy I saw this, was thinking of putting in e85 also.
1FASTG8GT
MODS: DEBAGDED, GXP DIFFUSER, HID, BLACK ROOF, TINT, STRAIGHT PIPE, ROTO-FAB, VMR-V710 20X9 SQUARED
FUTURE MODS: ADV.1 WHEELS AND TWIN TURBOS
themanran2000 is offline   Reply With Quote
