12 volt power outlet ground? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Stereo / Electronics
Old 12-07-2012, 09:03 AM   #1
cstmg8
cstmg8's Avatar
Default 12 volt power outlet ground?
I have already securely grounded the cigarette lighter outlet, but I am still getting some feedback when I watch video on my head unit. I think I have possibly traced it down to a bad ground connection on my adapter, which is the ground, the end of the adapter or the springs on the sides?
Sent from my DROID RAZR using AutoGuide App
09 panther black G8 GT
Show:19x9.5's rear w/rolled fenders, 18x9.5's front, 20% tint, trim/lense tint in progress, sub rewire, amp adj, VIM w/ dvd in gb, interior blackout in progress.
Go: spectre, hsrk, lpm, pacesetter LTs, full 2.5" cat/mid/res delete, flowmaster ABs, INTENSE tune.
97 Red GP GTP- ECM, headers, custom exhaust, ported blower, heads, TB, CAI, etc....... sold
91 GP GTP- L67 swap, tranny, headers, exhaust, ECM, and a few more.... ;-) sold
cstmg8 is offline   Reply With Quote
Old 12-07-2012, 09:51 AM   #2
amfarthing
The sides. Or you can use nearly any exposed (non-painted) metal surface as the ground.
'09 G8 GT, Liquid Red, Premium, Sport
amfarthing is offline   Reply With Quote
Old 12-07-2012, 11:34 AM   #3
zepcom
There's a bolt that's already being used as a ground on the right hand side of the center stack behind the passenger side triangle trim piece. You can loosen that up, slip your ground wire in, and tighten back down for a solid ground. Or put a grommit on your wire and loop it around the bolt.
Ground Loop Isolator circuits on the RCA side sometimes fix the alternator whine also.
good luck!
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
