dex-cool question - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > V6 Engine Tech (LY7)
Old 12-09-2012, 02:51 PM   #1
DavidMay
DavidMay's Avatar
Default dex-cool question
checked my dex-cool for the first time yesterday, the level is dead at the MIN line, im assuming thats not good, should i put some antifreeze in and how much should i fill it? and whats a good brand to put in? i never had to put in antifreeze before
DavidMay is offline   Reply With Quote
Old 12-09-2012, 03:02 PM   #2
BODYSHOPG8
BODYSHOPG8's Avatar
you can get a mix with any antifreeze or you can buy dex-cool
BODYSHOPG8 is offline   Reply With Quote
Old 12-09-2012, 03:23 PM   #3
DavidMay
DavidMay's Avatar
ahh ok, should it be filled up to the top line on the stick?
Old 12-09-2012, 04:02 PM   #4
tchr49
every village has one
tchr49's Avatar
There are several brands of the "Dex Cool" also. Carquest markets one, same stuff right down to the pretty orange color, and less expensive.
things are not as they appear to be.........
2009.5 LiquidRed/OnyxRed, Premium Package
Surprise Package
tchr49 is offline   Reply With Quote
Old 12-09-2012, 05:03 PM   #5
MeanGreenZ71
Any other brands that you know of? Mine is a little low and id rather not mix colors...
White Hot '09 G8 GT, Prem/Sport
Current: Pypes Violators, Magnaflow 12468 "Drone Killer" in midpipe, Spectre CAI, Cortex, UPR Catch Can, VG Sharkfin, LEDs, Smoked Bumper Lenses, Morimoto 4300K HIDs, V6 Taillights, Redline Armrest Cover, Rear Aux Cables, Autodim Mirror, Pontiac Trunk Mat
Future: Window Tint, Headers, GXP diffuser, Cam?
MeanGreenZ71 is offline   Reply With Quote
Old 12-09-2012, 05:10 PM   #6
DavidMay
DavidMay's Avatar
is it bad to mix colors?
Old 12-09-2012, 05:22 PM   #7
MeanGreenZ71
IDK if it is or not but id rather keep everything correct with this car. Im a little OCD. lol
My 95 GMC or my foxbody....no big deal but this car is only getting AC Delco or improved aftermarket parts. Not generic parts house stuff.
Old 12-09-2012, 05:59 PM   #8
BODYSHOPG8
BODYSHOPG8's Avatar
if it says dexcool on the jugs your looking at it should be orange
Old 12-09-2012, 06:53 PM   #9
wreckwriter
9 Second G8
wreckwriter's Avatar
Don't mix colors. Get DexCool or an approved substitute. Prestone has one as do others.
2011-13 G8 King
wreckwriter is offline   Reply With Quote
Old 12-09-2012, 08:07 PM   #10
Scorpious
G8 fiend
Scorpious's Avatar
u might jus be empty on the reserve tank but its full. i checked my levels and it was bone dry i put in maybe a 500ml and it was full again not sure how big the the tank is but its very odd
<a href=http://s98.photobucket.com/user/repozone/media/DSCN0298.jpg.html target=_blank><img src=http://i98.photobucket.com/albums/l259/repozone/DSCN0298.jpg border=0 alt= /></a>
Scorpious is offline   Reply With Quote
Old 12-09-2012, 08:29 PM   #11
wreckwriter
9 Second G8
You definitely need to open the radiator and see how much is in there. Don't open hot or you might get scalded.
2011-13 G8 King
Old 12-09-2012, 08:29 PM   #12
dogcat
dogcat's Avatar
I checked mine and the radiator was low and the reservoir was empty. It took 72 oz. My only advice would be don't buy it pre-mixed. It's a rip. Buy full strength and mix 50:50 with water.
GXP, 223/230 .634/.609 114+3, BTR .660 springs, BTR 7.425 rods, IWIS Pro Chain, Comp Rocker Trunions, VCM OTR CAI, Kooks 1 7/8 LTs, HF Cats, X pipe, Solo Axelbacks or Hooker Maxflows, Billet PCV catch can, CTS-V rear calipers. Updated GM trans mount, Camaro trans pan, HSRK w/ Omega 44005 Thermistor, BMR Rear Cradle bushings, BRM Trailing Arms, Pat G tune.
20% 3M CS tint, Kicker 8's, Rockford Fosgage T1D210 in sealed box, 1,000,000 uF Cap, Kicker 1000W amp, tons of Dynamat
dogcat is offline   Reply With Quote
Old 12-09-2012, 11:54 PM   #13
courtroom19
courtroom19's Avatar
Depending on the year of your car, you might be best off just getting it flushed. It's supposed to be flushed every 5 years regardless of mileage.
Need Wheels or Tires? I can help.
09 MGM GT 1SD With Roof. Sold
09 PSM G8 GXP M6 (1 of 9)SOLD
courtroom19 is offline   Reply With Quote
Old 12-10-2012, 12:07 PM   #14
wreckwriter
9 Second G8
That's very low. I'd guess you have a leak.
2011-13 G8 King
Old 12-10-2012, 12:15 PM   #15
MeanGreenZ71
My radiator was full but my reserve is empty. I havent filled it yet. I need to buy some dexcool first. Ill flush mine in another year or two. Mine only has 27K miles on it and its an 09....
Old 12-10-2012, 12:21 PM   #16
dogcat
dogcat's Avatar
Might be a leak. I have driven it another 1200 miles and the level is down two lines on the dipstick. It has to be internal as the engine is as clean as new...quite literally. I'm nervous it might be a head gasket. I'm going to go a little longer, then have an oil analysis done.
Old 12-10-2012, 12:59 PM   #17
wreckwriter
9 Second G8
Does your oil look ok on the dipstick? It will go milky if there's water. Check immediately after shutting down engine so it's well mixed.
2011-13 G8 King
Old 12-10-2012, 01:10 PM   #18
dogcat
dogcat's Avatar
The oil looks good. This is strange, exhaust looks and smells normal too.
I'm planning to do a cam swap next year, if I don't have it figured out by then, I'll probably just pull the heads and replace the gaskets at the same time.
Old 12-13-2012, 12:38 AM   #19
DavidMay
DavidMay's Avatar
Mine in an 08 and just rolled over the 50k mark a couple hundred miles ago
Old 12-13-2012, 09:42 AM   #20
dandragonrage
Plastidip is awful
Do not mix different types of antifreeze. Some types work fine together, but there are combinations that will result in massive amounts of precipitate and damage your engine.
Dex Cool is fine. The old green stuff is fine. The universal pink stuff is fine. Just don't mix them together, and make sure not to leave them in the engine longer than they should be. The old green stuff should be changed within 2-4 years and Dex Cool more like 5-6 (if you must).
And especially don't use anything meant for German cars (e.g. Pentosin) unless you do a full flush. German cars in particular often use fluids totally incompatible with what most other brands use. Not saying you should flush it and use it, but do especially avoid it otherwise. (Just FYI..)
dandragonrage is offline   Reply With Quote
