Kooks Header Advice/Experiences - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 12-11-2012, 01:37 AM   #1
Skyview
Skyview's Avatar
Default Kooks Header Advice/Experiences
After a lot of reading, I think I've decided to go with Kooks Mids vs LT. My thoughts on this:
1. ~10hp difference is acceptable to me
2. Cost is way better than with LT and all the extra bits/work
3. Sound - A little louder is OK, a LOT is not unless only at WOT.
Some requirements for me:
1. Stay legal for NC emissions inspection - Someone please let me know
2. I have Solo Mach Catback and will be keeping it, so I want something that will mate right up. Can someone let me know if this assumption is correct or will I still need some kind of connection pipe? Was thinking the stock cats are just removed and replaced with the mids/HFC combo.
3. Internal engine sounds - Is this much more noticeable? I'm kind of picky about stuff like this and don't what to hear a lot of clattering valves, etc. Any input on this would be welcome.
If I keep this car long enough, I may turn it into a real beast (V8 supercar), but for the foreseeable future, need it to be a good DD as well, so nothing too extreme. I need to be able to do this in stages as $ permits like most I would imagine, so I want stuff that I do to carry over when I also get a cam later. Then I want the cam to carry over when and if I ever S/C the car. I know some will say LT if you ever plan on doing this stuff down the road, but from what I've read the mids will work just fine with cam and S/C but just might be leaving a bit on the table vs LT with same setup. So, any input on #3 up top and the 3 requirements would be appreciated so I know my assumptions are either correct or not. Thanks.
Daily Fun - 2009 PBM GT, Sport & Premium, VCM, SOLO Mach Catback, Tune, L76 Oil Cap, Visor & Arrowhead Decals, Planned Soon: Top End Build by RCR and a few other goodies
Weekend Fun - 2009.5 Pacific Slate Metallic GXP, A6, Sunroof - Stock (#960, 1 of 18 as optioned)
Daily Hauler - 2006 Chevrolet Avalanche - CAI, HID's, Sail Panel LED's, LOF, Plasma
Two Wheel Fun - 2005 Honda VTX1300C
Skyview is offline   Reply With Quote
Old 12-11-2012, 06:15 AM   #2
jasonvt
I have kooks mids with solo shorty and have passed nc emissions with it. It will mate rightup to the solo. As far as sound... it is a little louder inside and you can hear the bacon grilling sound but it isnt too bad.
Sent from my DROID RAZR using AutoGuide.Com Free App
2009.5 LR G8 GT Sport/Premium/Sunroof
Kooks Mids w/ HFCs / Solo Shorty / Roto-Fab / Pat G. Tune
FE3 / Eibach / Tint / GXP Diffuser / TRS HIDs / HID Fogs / Nurburgrings / LED Tails / Debadged
jasonvt is offline   Reply With Quote
Old 12-11-2012, 07:10 AM   #3
tchr49
every village has one
tchr49's Avatar
I switched from stock manifolds/Solo HFC's/Mach shorty to the Kooks mids/HFC's. Long range plan was to go FI. Didn't give the long tubes much thought because I didn't want clearance issues.
I haven't noticed any appreciable increase in under the hood noise at all.
I did notice that the AFM/DOD noise seemed to be more noticeable, but you can shut it off.
Someone else will have to chime in on how well the Cortex tune will work with/support that setup.
things are not as they appear to be.........
2009.5 LiquidRed/OnyxRed, Premium Package
Surprise Package
tchr49 is online now   Reply With Quote
Old 12-11-2012, 08:11 AM   #4
Agose25
Agose25's Avatar
I can attest that in my set up I did notice an increase in valve train noise inside the cabin. It's not ridiculous or overbearing by any means, but it's there.
Old 12-11-2012, 08:30 AM   #5
bostonf4$
I didn't go w/ kooks mids I got JBA 1-3/4" long tubes instead...price was also a factor for me and I already had a custom pieced together catback so I didn't want to have to hack that up and retrofit kooks LT's + connection..and the JBA's don't hang low at all as theyr'e not as "long".
I can tell you on my setup (mods in sig magnaflows) - with NO cats, it is louder from outside the car on cold startup but sounds good, at partial throttle (like 1/3 cruising style) it is no louder in the cabin if not quieter since I had AFM tuned out. At WOT it sounds meaner/better - louder? yeah I guess, but not terrible.
You will hear the pinging of the headers but it subides some as they warm up and is less noticeable from inside the cabin.
Get them you won't be disappointed. As far as HP increase...by the way guys talk on this forum LT's get you 40whp....from my experience this is simply not the case. On the dyno I got my mods tuned on stock G8 GT's put down between 280-290whp. After the mods in sig I'm at 344hp/356tq (mustang dyno). A dynojet would probably read 10hp higher at least. It is the cumulative effect of the mods you will notice, it isn't like headers are a 30-40hp boost in themselves, they need the intake/tune/catback to see full results.
Old 12-11-2012, 12:41 PM   #6
Skyview
Skyview's Avatar
Thanks for the input so far. Good to know this setup will pass inspection.
Keep the advice coming...I need to listen to a car with mids in person to determine if I can deal with the increase in internal engine noise.
Old 12-11-2012, 12:45 PM   #7
Skyview
Skyview's Avatar
Definitely won't be using that anymore (at least on the G8) after this work is done. Generally not a good idea to do so after headers or anything past that. Planning to get Rick C. to get the most out of the setup once I have the parts selected and purchased.
Old 12-11-2012, 02:55 PM   #8
bostonf4$
Its really not going to be that loud man, if you want the kooks mids get 'em. It'll be louder at initial startup and from outside the car, internal engine noise increase will be minimal and will sound sweet @ WOT.
Whatever "negatives" you may potentially incur by adding headers are far outweighed by all the benefits. I promise.
Also - in regards to inspection - even w/ my catless longtubes I can pass a "sniffer' emissions test @ idle, obviously I won't pass a visual test, but somehow or another my tuner is able to trick an emissions test into a pass even without cats
Old 12-13-2012, 02:42 AM   #9
Skyview
Skyview's Avatar
So what do you all think on coated vs. not?
I understand that they are not supposed to NEED it, but I know it will keep things cooler. I guess some do it so they don't get to looking bad after a while too. Just not really sure it's worth it or not.
Old 12-13-2012, 09:06 AM   #10
zepcom
Boston just did a thread with "coated or not" discussion and you might want to check it out.
I had my kooks dip-coated from Jet-Hot. They still "look new" after a year and a half (including winters, this is my daily driver) and the heat dissapation is amazing when they're coated. Since mine were dipped, it's a continuous layer of the ceramic coating, inside and out, completely. Others have done the spray-on-tan version, I do not have experience with this. The insides of the exhaust system after a little while will start to "carbon up" so benefits of coating the inside as well as the outside, donno.
I have heard reports for people who attempt the cheaper means of "coating headers" that sometimes that method flakes off due to the flexing of the stainless steel underneith with the normal heat cycles. I can confirm first hand that the dipped method does not flake unless you physically damage a section with a hammer or road debris or something like that.
Check out Boston's discussion from last week on coat-or-not-to-coat.
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Old 12-13-2012, 10:11 AM   #11
elephantrider
****cray
elephantrider's Avatar
i run kooks mids and have very little valve train noise
increase. im used to my h/c'd gto, which is loud, so
i may be biased.
jason
96 ford powerjoke - bone stock
04 gto - not stock
15 ss - in the works
elephantrider is offline   Reply With Quote
Old 12-13-2012, 03:40 PM   #12
MarylandSpeed
Site Sponsor
MarylandSpeed's Avatar
Just remember to buy them from MarylandSpeed
Call Us @ 443-730-9428 for Orders or Technical Support
Check Out Our Sale on Kooks Headers!
Vist us @ www.MarylandSpeed.com for LOW Prices and Hassle Free buying!
MarylandSpeed is offline   Reply With Quote
Old 12-13-2012, 03:47 PM   #13
Agose25
Agose25's Avatar
MarylandSpeed,
Not sure if you know this off the top of your head, but what would be the measurement difference for the Kooks off road (non catted) xpipe if you were to attempt to mate it with a Kooks Mids/HFCs set up?
Old 12-13-2012, 04:00 PM   #14
Skyview
Skyview's Avatar
Thanks. I'll look it up.
Was planning to...I hear you can give great prices over the phone, but I just ordered something from you guys the other day so I better wait a bit so as to not call undue attention to my purchases lol!
Old 12-13-2012, 04:28 PM   #15
camoeto
I had Kooks 1-3/4 long tubes mated up with Kooks catted connection pipes to a Corsa cat-back on my GT. A combo I got from Maryland Speed back in 2009. I ran this setup for > 1 year before I sold the car, and had no issues with it at all. It was of course pretty loud but IMO no drone unless DoD kicked in.
I am pretty sensitive to drone as my 1st exhaust mod was a set of Pypes axle-backs mated to the stock system that droned noticeably and I had take them off after 2 weeks.
Also, I don't see a point int the Kooks mids. They really look more like shorties and all other things being equal, including a tune, your gains would likely be only about 10 WHP.
Current:
09' G8 GXP M6 - LR, Onyx/Red, Roof, 162/1829, stock for now
08' Tuono 1000R
Last 3:
07' E90 335i 6-speed - SOLD
08' G8 GT - PBM, Kooks 1-3/4 LTH, Catted connections, Corsa, Vararam, Sellers Atari gauges, 6000k HIDs - SOLD
03' E39 530i 5-speed - SOLD
camoeto is offline   Reply With Quote
Old 12-13-2012, 04:34 PM   #16
Agose25
Agose25's Avatar
Wow, the Mids just keep going down and down in #s don't they? Pretty soon people will be saying they yield ZERO hp gains.
This is a false statement. I dyno'd around ~30 hp increase with the addition of the Kooks Mids to my set up. Not to mention a brand new handful of high end torque. Maryland Speed can chime in on their great results with the Mids on their GXP as well.
It's not just a Shorty header, it's a Shorty + Elbow Flange + HFCs.
Old 12-13-2012, 06:26 PM   #17
camoeto
Did you get a tune before your baseline or after?
My car was already tuned with CAI prior to doing any exhaust work and I gained a total of 25 WHP after doing Kooks 1-3/4 LTH, their connection pipe with high flow cats, the Corsa cat-back and a re-tune after all that. The car went from 332 WHP to 357 WHP. Somehow I doubt you got 30WHP from just the shorties taking the tune out of the equation.
Current:
08' Tuono 1000R
Last 3:
Old 12-13-2012, 06:51 PM   #18
Zodiac
Sarcasm Personified
1. Yes legal, I passed here with them
2. Cost wasn't bad, I think they had a price increase since I ordered them though, and they mate to all catbacks with no modifications needed.
3. I don't remember if you heard mine or not. It was increased a bit at startup and idle, sounded almost cammed. The WOT was impressive to say the least. I had the mach shorty though so a bit louder than your setup would be.
They will leave a little on the table if you do go supercharged or cammed or both, but there are quite a few G8's doing fine with all of the above.
My .02 on this setup was I absolutely loved it if you want to keep your exhaust from being cut up this is your best option. I can answer most questions you have PM me if you have to. Shame I still don't have the car so you can drive it and hear it.
My recommendations to get would also be a set of wire socks to protect your spark plug wires from the headers. I burnt one of mine and got them after learning the hard way.
2015 Mustang GT Auto, 3.55, recaro seats, spoiler delete, Solo catback, SVE Drift 19x9.5 w/ 275/40/19's.
2015 Jeep Cherokee Latitude V6
Zodiac is online now   Reply With Quote
Old 12-13-2012, 07:01 PM   #19
SpeedRacerX
Now it's a Party
SpeedRacerX's Avatar
Impossible. After listening to at least 100 people over the last 3+ years describe their experiences with Kooks Mids, this low of a number was never even remotely mentioned. There'd be a lot of vocal, complaining people if that was the case.
I'm at 368 to the wheels with Vararam, Borla, Kooks Mids and Dyno Tune. You think the Kooks Mids only contributed 10 rwhp to the nearly 70 rwhp difference from stock?
OP: another nice reason is you get a little bit of extra ground clearance with the Mids versus the LTs.
Also, I'm not saying I wouldn't prefer the LTs but I already paid good money for a Borla and didn't want to hack it up or sell it for an extra 10 rwhp or so. If the LTs could have yielded me 30-40 rwhp more over the Mids, then yes, the Borla would have been gone.
2009 GT, Kooks 1-7/8 Mids, RPM Tune, Borla, Vararam, HSRK, P&P TB, UPR CCan, Mobil 1, Speedhut Gauges, FE3, Whiteline, Pedders, Summer MRR on 255/295, Winter Beyern on 245, CTS-V Fr Brembos, SS Rotors, Akebono Pads, Rolled/Pulled Fndrs, BMR Sways, Spohn Links & Arms, Sprt Pedals, Pont Shifter, Camaro Trans Pan, Pont Mats, Glove Box Light, MSM Lower Grills, CF Tail, GXP Diff, VG Fin, 20% Tint, 6000K HIDs, LED Fogs, GrafxWerks, Black Trim/Mirrors/Grills, Diffusr Lens/Amber Lens/Lowr Tails Tint
SpeedRacerX is offline   Reply With Quote
Old 12-13-2012, 07:20 PM   #20
Agose25
Agose25's Avatar
I base lined at 323 rwhp with a VMS tune, exhaust, and CAI. I dyno'd after the install of the Mids at 351 rwhp. That's 28 hp. I did also tweak my VMS tune some per the advice of the local tuner who dyno'd me. So what % of the 28 hp was tune/headers is anyone's guess.
I see your point about the tuning.
