Help deciding between 19" and 20" Nurburgrings - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Wheels / Tires
Wheels / Tires Sponsored by: Discount Tire
Old 12-12-2012, 09:16 PM   #1
jasonvt
Default Help deciding between 19" and 20" Nurburgrings
I have 20" Camaro SS wheels now. Ive had them about 18 months and ready for a change. I love the looks, but want something different.
From what I have found, the 20" TSWs are 23 lb and 23 lb F/R. The 19s are 20.75 lbs. So, the 20s are 10 lbs more total. Most tires Ive looked up are another 8 lbs more or so for the 20s, so 18 lbs more than the 19s.
Im looking for opinions on whether you think the looks of the 20s is worth the extra weight. Cost is about the same because where the 20" wheels cost more, the 19" tires cost more.
If I go with 19s, Ill probably get 245s all the way around because 275/19s are a lot more $ than the 245 - not worth it.
If I go with 20s, Ill keep the same 245/275 size that I have now.
Feel free to correct me on the weights, Im going by what Ive read.
For those of you that went with the 19s, do you wish you had gotten the 20s?
2009.5 LR G8 GT Sport/Premium/Sunroof
Kooks Mids w/ HFCs / Solo Shorty / Roto-Fab / Pat G. Tune
FE3 / Eibach / Tint / GXP Diffuser / TRS HIDs / HID Fogs / Nurburgrings / LED Tails / Debadged
jasonvt is offline   Reply With Quote
Old 12-12-2012, 09:30 PM   #2
09G8GT09
THE1ONE
20's.. In the long run cheaper tires lol
Sold and missed 2008 G8 GT
JBA long tube headers X-pipe stock mufflers,SNL tuned with 93 octane, Rotofab intake RWHP:340, Pedder's Sway Bars, Breyton GTS 20x8.5 Front 20x10 Rear
New 2009.5 Red G8 GT Premium Package Vararam Intake w/ Cortex Tuner for now..
09G8GT09 is offline   Reply With Quote
Old 12-12-2012, 10:04 PM   #3
hazer396
Facebook Moderator
hazer396's Avatar
19s - more toward performance
20s - more towards show
BC Racing Coilovers/6;4 Brembos/Tons of BMR Goodies/One-off Hazerwerks Lights/GXP Bumper/Holden Spoiler/Forgestar F14s/Much more!
3.6 V6: Headers/Intake/Insulators/Exhaust/Tune 242whp 260wtq 15.3 @ 92
6.0 V8: Pypes Headers/Solo 3"/RCR Blower Cam/Adam Schwab Heads and Intake 409whp 389wtq 12.2 @ 114
6.0 LSA:
12.5psi/Wiseco Pistons/Compstar Rods/Meth Injection Numbers coming soon!
hazer396 is offline   Reply With Quote
Old 12-12-2012, 10:06 PM   #4
jasonvt
If I go with 19s, should I stick with the stock 245 size tires? Or do most peaoper go for a wider rear tire?
Old 12-12-2012, 11:06 PM   #5
Valtec1500
Valtec1500's Avatar
Im looking into the same swap on my new 09.. Seems harder to find a matching set of 19" tires with the right rear width
Valtec1500 is offline   Reply With Quote
Old 12-12-2012, 11:15 PM   #6
The Yeti
'Mod'erator
The Yeti's Avatar
I'm surprised that a tire for the 20in rim is so much heavier than a 19in rims tire. Shouldn't the outside diameter be the same? My 20in setup is several pounds lighter than stock. And I'm running a 285 on the back.
Your camaro wheels weigh a ton and you should see a performance gain even if you stick with 20s.
Pat G Tune & DOD cam, RCR Intake & TB, 4IN MAF
Ported stock Heads, 2600 Stall, VCM, OBX, UDP
H&Rs, Konis, BMR, Brembos, Slotted/Drilled Rotors
3.27 Gears, ZL1 pump, LSA awaiting install
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.2 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
second gear pull
The Yeti is online now   Reply With Quote
Old 12-13-2012, 02:28 AM   #7
hazer396
Facebook Moderator
hazer396's Avatar
do you want a staggered set up??
if so get wider wheels for the back as well
6.0 LSA:
Old 12-13-2012, 02:32 AM   #8
jasonvt
I dont have a preference. Just want the best mix of looks performance and price.
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 12-13-2012, 07:19 AM   #9
Eric_GT
Eric_GT's Avatar
19 or 20, for me getting a 275mm on the back is more important.
Eric_GT is offline   Reply With Quote
Old 12-13-2012, 08:25 AM   #10
JTW
You've got mail, YAAAAY!
JTW's Avatar
20" if you care about tire cost.
2009 GT: MSM, Sunroof Delete, Onyx/Red, Sport/Premium
Original owner and proud of it!
1987 Porsche 911 M491 Turbo Body Carrera Cabriolet
1971 Dodge Charger 500, 383 #s matching
Go:
Rotofab CAI, Solo Axle-Back
X-Pipe, Cortex 93 tune with Rotofab ad-on
Hawk performance brake pads
JTW is offline   Reply With Quote
Old 12-13-2012, 04:50 PM   #11
Bob the Noob
I've heard the "20s are cheaper" statement tossed around a few times on various forurms. Without threadjacking, can somebody give an example or two?
-Bob
2009 MSM G8 GT - Christine
Go:MJD Performance Tune, Kook's LTs 1 7/8", Chrome TVS2300, Little Lunati cam, etc, etc, etc...
Warm start/idle: https://www.youtube.com/watch?v=dCwZxC-2_1o
620 - RWHP
563 - RWTQ
Bob the Noob is offline   Reply With Quote
Old 12-13-2012, 05:34 PM   #12
Blakeg8gt
MRG82U
19s look better IMO but thats up to u
I have 19s and I went with 245 front and 275 back but I also have 9.5"wide rims in the back and 8.5" In the front
Blake Faucett 2009 White hot g8gt
just a 4door with a little boost
Blakeg8gt is offline   Reply With Quote
Old 12-13-2012, 05:41 PM   #13
Agose25
Agose25's Avatar
19's for GO, 20's for SHOW.
I'd recommend a 245 front 275 rear set up.
Old 12-13-2012, 06:15 PM   #14
jasonvt
I keep reading this. To what extent is it true. I did the math with weights from discount tire and the 19s are 7.3 lbs total lighter... 1.8 lb per corner. Is that noticeable?
Old 12-13-2012, 06:56 PM   #15
Enginerd
Enginerd's Avatar
1.8 lbs unsprung wt ~ 18 lbs of sprung wt (rule of thumb - 10:1 ratio)...x4 wheels...so it does add up to quite a bit. Also consider the rotational inertia difference between 19/20s...
FWIW I have the 19s (staggered/275s out back) and was quite surprised that I could feel/notice as much difference as I did relative to the stock wheels...though GXP wheels might be made of lead...
---------------GXP M6 #595/1829---------------
Enginerd is offline   Reply With Quote
Old 12-13-2012, 07:29 PM   #16
Agose25
Agose25's Avatar
^ Well put
Old 12-13-2012, 07:46 PM   #17
Jeff92se
Tire brand choice is going to make a bigger diff on rotational weight then merely the wheel size.
Jeff92se is offline   Reply With Quote
Old 12-13-2012, 07:57 PM   #18
jasonvt
I thought that too, but most of the ones I checked out are about the same for any given size. I looked at generals, falkens, Conti
Old 12-13-2012, 08:09 PM   #19
jasonvt
If that 7 lbs makes that much of a difference, wouldnt it be better to go with 4 19x8s with 4 245/40s? that would be 8 lbs lighter than the staggered 19s.
Old 12-13-2012, 08:18 PM   #20
Enginerd
Enginerd's Avatar
Technically yeah...but there's obviously a trade off between less weight/more tire contact in terms of handling/performance. A 245 combo may be lighter but it isn't going to outperform a 275 staggered combo for grip.
Ask me how I know lol
