Springs for 1.85 rockers - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 12-25-2012, 04:54 PM   #1
dblaron
Super Moderator
dblaron's Avatar
Default Springs for 1.85 rockers
Thanks to an awesome wife and a suggestion from an abominable friend, I ended up with a set of 1.85 rockers for Christmas! I ordered the 1.450 pushrods already. My question to the guru's out there. I picked up a new set of ls3 springs from a member on here, these should be fine for the rockers, correct? I still have the stock cam installed, I believe I should be ok but I wanted to hear from some experts. Thanks
2009 GT Prem. Sport. Sun Roof.
Paddle Shifters, BMR Sways, Eibachs, Koni's, Brembos, 3.45s, LS2 cam, 918 springs, 1.85 rockers, Spectre CAI, Rick C Intake/TB/heads , LS7 MAF, Custom Axle Backs, JBA LT's,
Currently Installing RCR 215/223 .609. 615 114+1
Pat G Tuned.
12.23 @ 113.7 mph 1.98 60' 1,000' DA
20X9-35 TSW Nurburings 255/35 Cooper RS3-S
dblaron is offline   Reply With Quote
Old 12-25-2012, 05:01 PM   #2
jackalope
jackalope's Avatar
You need to know at what lift the springs will bind at. Then just do the math and see if the 1.85 rockers would put you over what the springs will bind at. Its always best to leave a little room to play as well, say the springs bind at 700 lift then try to keep the actual lift at the valve no more then 680 that way you never come close to making the springs bind.
Old 12-25-2012, 06:23 PM   #3
dblaron
Super Moderator
dblaron's Avatar
From the GMPP catalog
12586484
Valve Springs (not shown)
• Beehive style springs • Standard LS6/LS3 springs
• Use cap P/N 10166344 • 1.250" @ 295 lbs. pressure
• 1.800" installed height • Max lift .570"
@ 90 lbs. pressure
I was thinking that because they are good to .570 lift that I am good.
This is quoted from another board. I hope he doesn't mind.
"The test engine was a 2009.5 G8 GT with a 6.0L L76 engine with active fuel management (DOD). All AFM motors are saddled with a very small 200/208 .472/.474" 116LSA camshaft. The 1.85 rockers would effectively increase the lift at the valve from .472 to .514". This small but noticeable increase in lift will get the large intake valve further away from the cylinder wall plus into a position where it flows more air. Effectively my engine now has a 200/208 .514/.516" cam."
Anybody see any reason they wont work?
Pat G Tuned.
Old 12-25-2012, 07:40 PM   #4
Patrick G
I'm not sure if the LS3 springs will be stout enough. The L92 heads have heavier intake valves and will have a higher demand on the springs than LS3 heads running the lighter valves. I would recommend some PAC 1218 or 1518 springs for peace of mind.
Patrick G is offline   Reply With Quote
Old 12-25-2012, 08:32 PM   #5
joeygr8gt
joeygr8gt's Avatar
doi need springs and everything or wll 1.85 rockers work alone?
kooks LT headers, hi flow cats, x pipe, corsa exhaust, Vararam CAI, ported TB/intake manifold, underdrive pulley, catch can, qtp electric cut outs, 160 t stat, HSRK, H&R lowering springs, BMR sway bar
12.6 @109-old tune
joeygr8gt is offline   Reply With Quote
Old 12-25-2012, 08:59 PM   #6
dblaron
Super Moderator
dblaron's Avatar
That's exactly what I was looking for. Thanks Pat. I guess I will have some springs for sale if you are telling me they won't work. Would those springs you recommend work for a future cam upgrade? (Yeti cam)?
Pat G Tuned.
Old 12-25-2012, 11:33 PM   #7
The Yeti
'Mod'erator
The Yeti's Avatar
yes they will work for a cam like mine. Here is the springs Pat Recommended for my cam...
Recommended valve spring: PAC 1518 or Comp 26918 beehive.
Remember, he recommended those springs to me with the fact that I was retaining DOD and using the stock valves....
Pat G Tune & DOD cam, RCR Intake & TB, 4IN MAF
Ported stock Heads, 2600 Stall, VCM, OBX, UDP
H&Rs, Konis, BMR, Brembos, Slotted/Drilled Rotors
3.27 Gears, ZL1 pump, LSA awaiting install
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.2 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
second gear pull
The Yeti is offline   Reply With Quote
Old 12-26-2012, 11:38 AM   #8
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
Yes. I ran mine with stock springs and valves with no issues. If you are worried, you can shim the LS3 springs .030-.050" when you install them. Even shimmed .050 still gives you .005" from max lift range on the spring.
2009 G8 GT- Rick Crawford
1.50 60ft, 10.41 @ 131.4 Comp 234/243 111+0 6.4 N/A
1.53 60ft, 10.59@ 129.7 ALL MOTOR!!! N/A G8 Record Holder
G8-4-Speed is offline   Reply With Quote
Old 12-28-2012, 04:21 PM   #9
joeygr8gt
joeygr8gt's Avatar
Found rockers so my question is wht would happen if I just change the rockers and nothing else? Trying to avoi d the springs since they are a pain
12.6 @109-old tune
Old 12-28-2012, 04:34 PM   #10
GT Drew
Stock or LS3 springs are fine for the .514" lift. The LS3 cam has more lift anyway.
Old 12-28-2012, 04:48 PM   #11
joeygr8gt
joeygr8gt's Avatar
So I can just order the rockers correct?
12.6 @109-old tune
Old 12-28-2012, 05:11 PM   #12
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
I would recommend rockers and 7.450" pushrods.
Old 12-28-2012, 05:54 PM   #13
joeygr8gt
joeygr8gt's Avatar
Pushrods easy to change?
12.6 @109-old tune
Old 12-28-2012, 07:00 PM   #14
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
Yep. Pull out as soon as you take off the rockers.
Old 12-28-2012, 10:11 PM   #15
The Yeti
'Mod'erator
The Yeti's Avatar
Install your new push rods by putting them in there where the old ones came out.
After Stall
Zex 125shot
second gear pull
Old 12-28-2012, 10:57 PM   #16
djerickd
G8/LSX n00b
so sticking with stock springs might allow for a little more HP over a heavier spring? u just *might* float a valve under extreme conditions??
09.1 G8 GT, 20x9.5/10 RD Sport RS-5's, 255/30 & 275/30 sumitomos, magnaflow catback, Kooks mids w/cats, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP front bumper, GXP rear diffuser, BMR strut bushings/cradle inserts/sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel, Klearz corners, HSV map lights, CHenry splitters/tuned
djerickd is offline   Reply With Quote
Old 12-28-2012, 11:15 PM   #17
The Yeti
'Mod'erator
The Yeti's Avatar
Basically. Valve float can cause issues that are not cheap to fix. For the peace of mind I would sacrifice a negligible amount of HP for peace of mind.
After Stall
Zex 125shot
second gear pull
Old 12-28-2012, 11:36 PM   #18
djerickd
G8/LSX n00b
I hear ya, thanks again Yeti
Old 12-30-2012, 09:49 AM   #19
todds87ss
Car RamRod
todds87ss's Avatar
I used LS6 springs with my 1.85s for a year. I would not use stockers. LS3 and LS6 springs are an inexpensive alternative, and I spun mine to 6200rpm regularly.
You can choose to be anything you want on the internet...why choose to be so stupid!
todds87ss is offline   Reply With Quote
Old 12-30-2012, 12:09 PM   #20
djerickd
G8/LSX n00b
There's an idea thank you!
