Tune Check - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > PCM Tuning / Dyno Results
Old 12-26-2012, 03:33 PM   #1
Silverado777
Silverado777's Avatar
Default Tune Check
Well I hope I uploaded the file correctly. If I did, can one of the tuning guru's check the tune on my car to see if anything needs to be changed. Just kind of curious how it stacks up. It was tuned using HP Tuners
05 Silver Birch Silverado- Blown 383 Stroker
504 RWHP 627 RWTQ (Sold)
08 IOM G8 GT -VCM CAI, e85 Tune, 3.27 gears, SLP UDP, HSRK, 1 7/8 LT, 3" X Pipe, SOLO Axle Backs, 07 CTS-V Brembos F&R, BMR Sways, BMR Diff, Rear Cradle & Radius Rod Bushings - Dynod 335hp 352tq on base tune, PB 12.99 in the 1/4 (Sold)
2010 Black Raven CTS-V. M6, Full Build, 771whp / 716wtq
09 Pearl Mirage White GSX-R 750, Micron Exhaust, K&N Intake, Power Commander 3, Geared
1/4 Mile - 10.3
Silverado777 is offline   Reply With Quote
Old 12-27-2012, 01:07 PM   #2
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Here are my .02 cents, the MAF was scaled by -12% all the way across, i doubt the MAF is actually tuned, so makes me wonder how the VE was tuned, it doesn't seem stock, also why modify the knock sensors transient/eq ratio ?, besides the tune, do you have part throttle fueling logs and WOT fueling logs with WB ?
Also in concept, E85 stoich is 9.7x, i don't know anybody using 9.7 because of the blends, the stioch is higher than that.
It seems a fairly basic tune with trans TM upshift disabled and some skipped corners in general.
Old 12-27-2012, 01:18 PM   #3
Silverado777
What did you call me? lol JK. I understood very little of what you said. I am very new to HP Tuners and even newer to tuning. I'm going to have to work on getting part throttle and WOT logs.
A buddy of mine was the one doing the tuning and unfortunately he is in Vegas and tuned it without looking at any logs. When I get the logs posted up hopefully i can do some of the adjustments myself.
I really appreciate you taking the time to take a look at it for me. I'll try to get those logs in the next couple of days.
1/4 Mile - 10.3
Old 12-27-2012, 02:13 PM   #4
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
I guess he just gave you a base tune then, which now make more sense because how the tune looks like. Good luck, hope to see your progress with this calibration.
Have fun.
Old 12-29-2012, 01:35 PM   #5
JESUSFREAK702
JESUSFREAK702's Avatar
Who's your buddy in Vegas?
Mods
Tuned by Frank @ Revolution Raceworks
Rotofab CAI
Pacesetter LTH 1 3/4
cat delete
Pypes Violators w/magnaflow x pipe
Staggered 20" STR101
245/35R20 and 275/30R20 Delinte D7
D2 Coilovers
5% tint
JESUSFREAK702 is offline   Reply With Quote
