Hardened pushrods - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 12-27-2012, 04:27 PM   #1
phoenixZRO
phoenixZRO's Avatar
Default Hardened pushrods
Are they necessary for DOD delete/cam swap? And if so what size? I see 7.4" and 7.425" on sigs. Thanks!
2008 G8 GT #868 0f 888 (Sold)
Vector Motorsports 91 octane tune, VCM OTR CAI, VMS HSRK, 20" Breyton GTS matte black
2009 G8 GT
Completed: Livernois 91 octane tune, carbon fiber Rotofab CAI, SLP headers and catback, Flowmaster exhaust, AC Delco MAF, BFG g-Force Sport Comp 2 tires on black Camaro 19s, partial chrome delete, complete badge delete, RF 1000.1bd amp w/ 2 RF P3D4 subs
Coming Soon: Cam/DOD delete
Saving For: CTS-V
http://www.facebook.com/#!/lsx.reapers?fref=ts
phoenixZRO is offline   Reply With Quote
Old 12-28-2012, 11:32 AM   #2
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
7.400 if milling the heads. No milling, 7.425. Procharger setup is going to be 7.425".
2009 G8 GT- Rick Crawford
1.50 60ft, 10.41 @ 131.4 Comp 234/243 111+0 6.4 N/A
1.53 60ft, 10.59@ 129.7 ALL MOTOR!!! N/A G8 Record Holder
G8-4-Speed is offline   Reply With Quote
Old 12-28-2012, 12:43 PM   #3
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
****, would 7.400 be to short for stock heads ? i said 7.400 when i ordered my DOD delete kit today with a 229/236 cam, i'm not doing anything to my heads, and thought 7.400 were ideal, i'd be doing the rocker trunions as well, so should i change to 7.425's, or the 7.400's would be fine ?
Old 12-28-2012, 01:49 PM   #4
phoenixZRO
phoenixZRO's Avatar
^ That's a good question. Also Rick, if I'm not Procharging for a year or so would it be best just to go with 7.4 for now since your milling and porting LS3 heads for me then switch to 7.425 when it's time?
2009 G8 GT
Saving For: CTS-V
Old 12-28-2012, 03:39 PM   #5
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
Interesting, I thought they had to be measured for your setup. I had mine custom measured from the machine shop. I'll have to ask the length.
Old: 353.8
New: 632/530 Mustang Dyno
Old 12-28-2012, 04:00 PM   #6
Monte8009G8GT
Monte8009G8GT's Avatar
I had 7.425s with my cam swap and no milling. 226/236. ^ It is best to check.
2009 G8GT:
364--forged rods/pistons stock crank.(Rick Crawford) Ported Heads,(Modified) Intake, TB. Vararam, Custom Cam, Kooks 1 3/4 LT, 2.5in custom exhaust, Yank 3000 TC, BMR SFC, H&R Springs. DDM HID's 8k-LB 3k-Fogs.
Dynoed 435whp 386wtrq with above setup 12.8@116 2.2 60ft BTTD.
Cam,Stall,LTH,CAI,Tune. Best time 12.7@110 1.9 60ft. Old Setup.
Dynoed 370whp 380wtrq
(w/LTH,CAI,Tune)Best time 13.1@105 Old Setup.
Monte8009G8GT is offline   Reply With Quote
Old 12-28-2012, 05:18 PM   #7
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
7.400 is going to be too short. You can't mill the heads with that cam unless you run valve reliefs.
Pheonix, at the most they will just get a clean-up cut for a good sealing surface. You need the compression to stay where it is. If you are going boost, it isn't worth it. If you really want to bump it, get thinner Cometic gaskets. .040-.032" for a compression bump. That way you can go back to .051" with boost. Plus thinner head gaskets give a tighter quench for better knock resistance with pump gas.
Old 12-28-2012, 06:31 PM   #8
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Thanks a lot guys, i sent an email to Texas Speed.
Old 12-28-2012, 07:11 PM   #9
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Found this pic online, along with a description that says that if LS7 lifters are used, the pushrod has to be 0.50 shorter ? I ordered 16 Ls7 lifters, and that's why i thought 7.40 was ideal, don't know if the stock lifters are the same lenght or shape as the LS7's.
LS7 lifter on the left, LS1 lifter on the right.
http://i143.photobucket.com/albums/r...2/DSCF4015.jpg
Old 12-29-2012, 09:39 PM   #10
glanzergtx
glanzergtx's Avatar
X2. I'm going to be ordering my dod delete soon and will have ls7 lifters makes e also wonder what length pushrods will be neeced
Your normal 600whp+ 4dr family car
glanzergtx is offline   Reply With Quote
Old 12-29-2012, 09:45 PM   #11
phoenixZRO
phoenixZRO's Avatar
7.425" but depending on cam from what I gather
2009 G8 GT
Saving For: CTS-V
Old 12-29-2012, 09:46 PM   #12
iisme13
iisme13's Avatar
Yea I had to rethink my hole build because of the cam I got. I got the tsp 231/236 cam. And I dont wanna fly cut.
So im doing a 402 stroker build with ported heads and ricks ported manifold
Sent from my SAMSUNG-SGH-I747 using AutoGuide App
09 VE SS-V
Performance:
404ci Lunati Crank and Rods, Wiseco Pistons,TSP 235/239,Dallas performance LSA Heads, Yank 3600SS Stall
Appearance: SS-V conversion/ Brembo's/ XXR 522's/tein springs/ HSV gauges
Old Numbers 378hp/365tq
New numbers 501rwhp\467rwtq
iisme13 is offline   Reply With Quote
Old 01-03-2013, 11:17 AM   #13
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
I just emailed TSP this morning, and hopefully i'll be able to change my order, and get 7.425's instead.
Old 01-03-2013, 11:45 AM   #14
phoenixZRO
phoenixZRO's Avatar
Sounds good. Glad thread helped. Here's a thread I posted on some good info I compiled while planning my next mods. Check it out:
http://www.g8board.com/forums/showthread.php?t=66208
2009 G8 GT
Saving For: CTS-V
Old 01-03-2013, 12:26 PM   #15
RamJet
RamJet's Avatar
Pat G spec'd my cam out and also stated to get hardened 7.4 pushrods. My cam isn't radical though, and my heads are stock.
2008 G8 GT PBM, DOD Delete, Pat G Spec'd Cam, 7.4 Hardened Pushrods, Comp Trunion Kit, PAC 1518 Springs, ARH 1 7/8" LT Headers Catted Exhaust, Spectre CAI, Pat G Tune.
412.198hp/396.828tq at the Wheels - Mustang Dyno
1/4 Mile, Very First Run, Stock: 13.66 @ 102.74 w/ a 2.067 60'
1/4 modified 12.49 @ 114
2008 G8 GT MGM, Leather w/ Red Inserts, Sun Roof, 18" Bremmer Wheels
1/4 mile 14.0278 @ 101.49 w/ a 2.2658 60'
DA 2260, Best Run for Lynda
RamJet is offline   Reply With Quote
Old 01-03-2013, 12:47 PM   #16
phoenixZRO
phoenixZRO's Avatar
What's your cam spec? I'm getting a 218/230 Pat G cam but going 7.425"
2009 G8 GT
Saving For: CTS-V
Old 01-04-2013, 12:35 PM   #17
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
TSP confirmed this morning the change to 7.425's. Thanks Rick and everybody for the recommendation.
Old 01-04-2013, 04:28 PM   #18
ExpLiciTSainT
Talked to my machinist today and he mentioned you want to get a proper measurement. Mine ended up being 7.450 due to the cam. I have no lifter tick at all, even with LS7 lifters. He mentioned you need to check pre-load and that even the same cams can be different depending on how they are ground. He said to use an adjustable rod to figure out the correct length and preload.
Old: 353.8
Tags
cam swap , dod delete , hardened pushrods
