Pacesetter Install Problems - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 12-28-2012, 01:13 PM   #1
mtocrs1
Default Pacesetter Install Problems
So I am trying to install my setter long tubes. The driver side header is hitting the motor mount. I can tighten everything up but the header tube hits the notor mount? I do have the updated mounts, not sure if that is the issue but I believe the updated mounts were factory installed on the 2009.5 models. Anyone else have this issue?
2009 White Hot G8 GT
HPT Tuned-Bluegoat has been telling me what buttons to push
Vararam with Vector HSRK
Pacesetter Long Tubes
Partial Debadge
Window tint 20% back 35% on the sides
Camaro 20's.
Next mod-1.85 Rockers and LSA Blower
87 Buick T-Type-My fast car Gone
87 Buick Grand National
2005 Avalanche
2003 Impala- Winter Warrior
mtocrs1 is offline   Reply With Quote
Old 12-28-2012, 01:33 PM   #2
Slizzo
Slizzo's Avatar
Never heard of any such issue. Positive you received headers for a G8 and not another LS powered vehicle?
2011 Radiant Silver Metallic CTS-V Wagon - Corsa Axleback, AirAid Intake
2008 Panther Black Metallic G8 GT *Sold 6/11/14*
Slizzo is offline   Reply With Quote
Old 12-28-2012, 01:41 PM   #3
Bo White
Bo White's Avatar
By the way I understand it Pacesetter uses the same actual headers for the Camaro5 cars as the G8 just has different hardware and such. I have also not heard of a motor mount hitting on any G8 header. Ive heard of steering shaft and a collector turned up too much though.
Old 12-28-2012, 01:53 PM   #4
BLKG8
BLKG8's Avatar
Is it hitting the actual mount or the brace that the mount is attached to? I installed mine a few days ago and it's close but defiantly clears with no contact
BLKG8 is offline   Reply With Quote
Old 12-28-2012, 02:24 PM   #5
mtocrs1
It is hitting the brace.
Partial Debadge
Camaro 20's.
2005 Avalanche
Old 12-28-2012, 02:32 PM   #6
BLKG8
BLKG8's Avatar
Try loosening the bolts on the flange and see if there is any play in order to move it slightly up.
Old 12-28-2012, 02:33 PM   #7
mtocrs1
It has 70-2259 stamped on header. Those are correct!
Partial Debadge
Camaro 20's.
2005 Avalanche
Old 12-28-2012, 02:34 PM   #8
mtocrs1
I tried, I think I will just grind a little of the brace. What a pain in the A$$
Partial Debadge
Camaro 20's.
2005 Avalanche
Old 12-28-2012, 02:40 PM   #9
Bo White
Bo White's Avatar
Yes, correct #.
Old 12-28-2012, 04:36 PM   #10
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
Can you confirm that you removed the steering shaft?
Old: 353.8
New: 632/530 Mustang Dyno
Old 12-28-2012, 05:03 PM   #11
BLKG8
BLKG8's Avatar
I didnt have to remove the steering shaft on when I installed mine. He said hes rubbing the motor mount.
Old 12-28-2012, 05:12 PM   #12
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Crap, i wonder why it would hit the motor mount on that side. mine went it without disconnecting the steering shaft (both sides were installed from underneath), and then it was connected to the factory CB without any issues.
Old 12-28-2012, 05:57 PM   #13
mtocrs1
Well the passenger side went on with no issues. The babysitter called and my 7 month old was puking. Had to drop everything to pick her up. I will get back at it tonight when the fam is sleeping. I will provide update later.
Partial Debadge
Camaro 20's.
2005 Avalanche
Old 12-29-2012, 10:54 PM   #14
mtocrs1
Well I tried adjusting the driver side again and no luck. I removed the driver side and ground down the brace a bit. Maybe have an 1/8 of an inch clearance now. Now the next issue is the passenger side. The passenger side is really close to the floorboard at the flange where it connects to the midpipe. Anyone seen this? Its not hitting now but I bet under a hard accel it will hit the floorboard. I remember reading various posts with "easy install but I have a rattle from time to time, I will deal with later" Im not dealing with crap later. I only do things the correct way once.
I have tried adjusting the passenger side but there is not enough adjustment to get it far enough away from the floorboard. The only thing I can think is that the car is possibly twisted a bit on the jackstands causing the clearance issue. I am thinking of making some wheel cribs out of 2x4s to check the clearance in a "natural state". Good thing I have other vehicles to drive!
Partial Debadge
Camaro 20's.
2005 Avalanche
Old 12-29-2012, 11:07 PM   #15
mtocrs1
Oh and one more thing, the dipstick sucks. Were you guys ableto get the dipstick fully seated? How did you do it? Force?
Partial Debadge
Camaro 20's.
2005 Avalanche
Old 12-29-2012, 11:26 PM   #16
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Umm, makes me wonder if you got a set of the headers made late on Friday ?
You shouldn't have to fight the install like that, hopefully it'll be because of the jack stands as you mentioned.
If you go underneath and check where the disptick goes, you'll figure it must be locked in place by pressure, probably orings or something similar in shape ?, it seems you just have to line the end of the tube in the hole, and push it down, Lol, we're all used to this procedure ?
I didn't do the install myself, but watched the install, and i also checked how the disptick is positioned in place a couple of days ago when i was doing my oil change. The portion of the dipstick you grab with your finger to check the oil, won't clear the header primaries without a thick washer as well. something to keep in mind in case you get to bolt the items without any other issue.
If you bought them new, perhaps you should consider returning them and getting a new set, i know it sucks to be there, almost at the point you know you can get it to work, only to find it doesn't fit because the item is messed/bended or whatever.
Good luck dude.
Forgot to mention, the passenger side flange in mine, is closer to the floorboard compared to the driver side, not by much, but i noticed that too 2 days ago while changing the oil, there is no way the flange would hit the heat shield for example or anything aorund it, there is enough clearance for that, and the reason i always say this ****ers doesn't hang low compared to to other systems, i can try to take some pics for you tomorrow morning so you can have a better idea. (if it doesn't rain around here ), i can mount her in my dino ramps and snap some pics.
Old 12-29-2012, 11:33 PM   #17
MotorCityG8
MotorCityG8's Avatar
I never ran into those problems well besides the dipstick being a pain in the ass. That was a bitch and half to get back in.
13' Ford Focus ST2
2008 G8 GT PBM / No Roof - SOLD
Go: Livernois Stage 1 Cam / Circle D 3000 Stall / Ported TB & Intake / Roto-Fab CAI / Pat G Tune / SLP Powerflow Axlebacks / OBX 1 7/8 LT w/3in midpipe / LS7 MAF
Show: Avant Garde M310 / Eibach & Fe3 set up / Plasti Dipped Wheel and Kidney grills / Debadged / Tint (20% windshield, 5% sides, 20% on top of 5% on the rear) / Bathurst Stripes.
MotorCityG8 is offline   Reply With Quote
Old 12-30-2012, 12:10 AM   #18
mtocrs1
I would appreciate those pics if possible Bluegoat.
Yeah these must have been built before a long weekend or on a pissed employees last day.
Partial Debadge
Camaro 20's.
2005 Avalanche
Old 12-30-2012, 09:39 AM   #19
Bo White
Bo White's Avatar
Or monday morning.....
I have read about collector clearance.
Old 12-30-2012, 02:16 PM   #20
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Actually, both sides seem to be about the same, the lowest clerance with respect of the floorboard seems to be at the connecting pipe bracket level, there is about half finger space against the heatshield, it seems the guy who did my install, simple made an indentation close to the connecting pipe bracket, in the heatshields, on both sides.
I don't have rattles, and it doesn't seem to be hitting the heatshield, even though there is only half finger clearance, crazy. i launch this biatch at WOT every time i can when i wearing the DR's, and i don't think that portion is hitting anything.
Sorry for the phone pics, but hope it'll give you the idea.
This is the driver side, you'll notice the indentation in the heatshield, the gap between the heatshield and the connecting bracket is about half finger on both, driver and passenger side. the other pics are hard to see, but the gap is the same on both sides in this location.
Uploaded with ImageShack.us
And this are passenger side, with shield indentation
Passenger side, same indentation in the heatshield, just hard to see because of the pic.
