Holden shifter in a G8 - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Drivetrain Tech
Drivetrain Tech 5L40 A5 / 6L80 A6 / TR6060 M6 / ZF Rear Diff
Old 01-01-2013, 04:36 PM   #1
rcpepper
rcpepper's Avatar
Default Holden shifter in a G8
Bought a Holden Commodore shifter off Ebay Australia for $230 American shipped just to see if it would work. Had to transfer the column lock micro switch and splice it to ground since the ground is shared with the LEDs and the circuit board and had to be cut. Works like a champ. Decided to leave the brake pedal shifter interlock solenoid out, though it could be transferred with little problem as the shifter bases are exact mirror images of each other. The actual lock lever connected to the solenoid is lhd only. There's a spot for a rhd version, good luck sourcing that part. Here's a few pics after install.
Rob
2009 SRM GT-Traded in with $4800 worth of hail damage
2013 GMC Sierra SLE Crew Cab-new ride
1992 Chevy Sport Truck-14.74 @ 93.4 254RWHP/316RWTQ
You can have all the horsepower in the world, but if you don't have the torque to back it up, all you're doing is making noise.
rcpepper is offline   Reply With Quote
Old 01-01-2013, 04:38 PM   #2
rcpepper
rcpepper's Avatar
Don't know how to do multiple pics in one post.
Old 01-01-2013, 05:06 PM   #3
mlittleton
Mack
Flat out awesome man! Can you elaborate on the column lock micro switch? I have no idea what your talking about and would love to do this mod.
2008 Pontiac G8 GT: 10.928 @ 125.840 MPH 1.52 60' - Fayetteville Motorsports Park, NC
2008 MGM G8 GT | 20" Forgestar CF5's | 20x9 et.38F/20x10 et.45R | NT555 265/35/20F | NT05 305/30/20R | SOLO Mach Balanced | Kooks LT/SOLO HFC Connections
Rick Crawford Racing 6.6L stroker build | RCR Spec'd Lunati Cam @223/232 .615/.598 | RCR Heads TB/Intake/Tune | VCM Intake | Camaro 3.45's | LS7 MAF | Coan 3200
mlittleton is offline   Reply With Quote
Old 01-01-2013, 05:13 PM   #4
rcpepper
rcpepper's Avatar
On the left forward side of the shifter base there is a small microswitch that disengages when you press the shifter button. It is depressed once the button in released by a roll pin in the shifter shaft. Should have taken a picture before I put it back together. It is kinda hidden by the lock lever that attaches to the shift interlock solenoid.
Rob
Old 01-01-2013, 09:14 PM   #5
zepcom
This is really cool for those who just can't get used to the bass-ackwards layout of the US-spec cars.
Do you have any wiring pinouts or color info about the shift column interlock you describe? I guess if you're splicing it to ground, that is easy to understand, but which wire gets spliced to ground, and where?
Did it take you long to get used to the new aussie shifter style?
Does it feel wierd, sliding towards you to go into sport mode? That would get me for a while I would think!
Well done OP.
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Old 01-01-2013, 10:13 PM   #6
supermikey
eat.sleep.detail.
You think theres any chance of flipping the up shift and down shift, Ive always felt like it needed to be the opposite of stock
I am all that is big and fluffy!
[B]2009 G8 GT
supermikey is offline   Reply With Quote
Old 01-01-2013, 10:52 PM   #7
mlittleton
Mack
Press the shifter button??
Old 01-02-2013, 12:25 AM   #8
rcpepper
rcpepper's Avatar
Took a little getting used too. Have pushed the wrong way once downshifting instead of upshifting. The movement toward the driver has a more natural feel than the stock shifter. It drops right in the palm of your hand, like I 1-2 shift position in a manual.
Has a black wire and white wire for the shift interlock solenoid. Has a black wire and a blue wire for the column interrupt microswitch. Shift interlock, LEDs, microswitch, and circuit board all share the ground(black).
Old 01-02-2013, 12:42 AM   #9
rcpepper
rcpepper's Avatar
The button you press to pull it out of park. Microswitch attaches to these two pins behind the interlock lever and the roll pin opens and closes as it moves up and down, locking and unlocking the steering column. Will try to get a pic of the switch tomorrow on the new shifter.
Old 01-02-2013, 12:44 AM   #10
nemesis350
nemesis350's Avatar
Too cool! Although I hate the inverted up n downshift...my wifes mazda3 is like that n I couldnt get used to it
nemesis350 is offline   Reply With Quote
Old 01-02-2013, 01:01 AM   #11
rcpepper
rcpepper's Avatar
Here's the microswitch mounted to the right side of the holden shifter. Transferred from the stock shifter.
Old 01-02-2013, 01:29 PM   #12
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Why is it that you guys feel the shifter is reversed?, Pull the shifter down to downshift, push it up to upshift, can't get any easier, it'd feel weird to do the opposite way , but good too see there are options for those who want something different, or perhaps i'm one of the weirdos for liking it the way it is, either way, good find.
Old 01-03-2013, 03:18 PM   #13
hivoltagedriver
hivoltagedriver's Avatar
This seems to be a pretty popular topic lately. I guess none of you guys grew up driving old muscle cars. They are always forward to upshift and back to downshift - like our stock shifter - unless you had a reverse valve body. Seems perfectly normal to me.
'09 PSM G8 GT w/ Premium & Sport packages.
Go: TSP 403 stroker, Kooks 1 7/8" LTs, Corsa, VCM OTRCAI, RCR AirRam intake, ported TB, and 223/235 cam, 100mm LS7 MAF, 3.27 gears, Circle-D 3200 stall. Tuned by Me. 11.33 @ 121
Whoa!: CTS-V/ Camaro 4-piston Brembos, Hawk pads, DBA rotors, full Zeta II front and rear suspension swap w/ BMR goodies and BC coil-overs.
Show: 4300K TRS HIDs, LED fogs, VG Sharkfin, GXP diffuser, 10% tint, de-badged, polished CTS-V wheels.
hivoltagedriver is offline   Reply With Quote
Old 01-03-2013, 08:33 PM   #14
benfocused
Default That's plain sick
That's totally the way to go. I've seen the posting here where someone took apart the factory setup and rewired it, but I like this solution better. Plus you get the shifter nice and close to you for more comfortable shifting I imagine.
benfocused is offline   Reply With Quote
Old 01-04-2013, 01:31 AM   #15
rcpepper
rcpepper's Avatar
Shifter position in manual mode is much more comfortable than before. Haven't measured but probably close to 4 inches closer than the factory setup.
Rob
Old 01-04-2013, 01:37 AM   #16
rcpepper
rcpepper's Avatar
I'm 36 and have this is my second auto floor shift car. Heck, 75% or more of my cars have been manuals including my Chevy truck. Just can't figure out how to make the auto shifter go up and down to upshift lol. I like it better this way.
Rob
Old 01-04-2013, 08:29 AM   #17
zepcom
Having driven 90% of my hours in the daily driver in "manualomatic mode" since new in March 09, I humbily believe that I've gotten used to the standard layout of the shifter and never mix them up (and over rev or hit the rev limiter) when I'm tromping or playing around. It's become second nature to me.
But I applaud those who it didn't make sense for and who want to make the switch themselves. That's awesome inginuity. I think re-learning to slide LEFT to shift to sport mode would have me going crazy after the first day... but hey that's just me!
Old 01-20-2013, 02:06 PM   #18
pkstang
suprised no one makes a true bolt in kit
'09 G8 GT
(daily driver: VCM OTR, Kooks LT Headers & Cats)
'90 Turbo Mustang
(712rwhp 715rwtq)
pkstang is offline   Reply With Quote
Old 02-06-2013, 10:00 AM   #19
rcpepper
rcpepper's Avatar
It's bolts right in, just about 5 minutes to address the column lock switch and about 30 minutes to swap it in the car. It's identical, just backwards. Now that I'm getting accustomed to it. I like it much better. Especially being close to 4 inches closer to me than the Pontiac manual position.
Rob
Old 10-27-2013, 09:47 PM   #20
fullcircle
fullcircle's Avatar
So has anyone been able to reverse the manual shift +/- on the Aussie shifter to be the same as our cars.
G8 GXP A6
fullcircle is offline   Reply With Quote
