When is a bigger MAF needed? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Intake/Fuel Tech
Intake/Fuel Tech CAI, TBI, Porting, Forced Induction, Nitrous Oxide...
Old 01-02-2013, 04:23 PM   #1
vicious-peanut
Default When is a bigger MAF needed?
So I am finally getting to mod my car a bit. It is getting a CAI, it has axle-back exhaust and is also getting LTH's. I am thinking Rick's intake manifold would be good, but if I go with that, do I need the ported TB and a bigger (90mm) MAF too? It will be topped off with a PatG tune.
vicious-peanut is offline   Reply With Quote
Old 01-02-2013, 04:25 PM   #2
Troy Trackbeast
Super Moderator
Troy Trackbeast's Avatar
no you dont need it. it will run like a scalded dog fully bolted with rick's intake.
Troy Trackbeast is offline   Reply With Quote
Old 01-02-2013, 05:30 PM   #3
gr8lover
yea, you dont need a new Maf for along time.... only people pushing alot of air might need one.... ie... supercharger or turbo at high boost/flow... most will never need this..
09 Panther Black G8 GT
4L80/Procharged F1d/9"rear/430 lsx; 921rwhp; :Worlds Heaviest G8.. ... lol... --4350 lbs without driver VECTOR tune
(I work for GM-- all statements from me are opinions of my own and does not represent GM in any way.)
gr8lover is offline   Reply With Quote
Old 01-02-2013, 05:34 PM   #4
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
Pat G programmed Speed Density and MAF for my car. Runs great with my Procharger... stock MAF too.
Old: 353.8
New: 632/530 Mustang Dyno
Old 01-02-2013, 06:26 PM   #5
BLKG8
BLKG8's Avatar
Why is that I'll see it occasionally on some n/a g8?
BLKG8 is offline   Reply With Quote
Old 01-02-2013, 06:40 PM   #6
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
A bigger one is needed when the stock one limits have been reached whether by airflow (G/sec) or frequency (HZ).
Most people do whatever to increase power, including changing to a bigger MAF when the stocker can do the job, changing to a bigger MAF is not a plug and play thing, your PCM has to be calibrated to know working parameters from the new MAF. Normally the LS7 style is preferred because the parameters from the Z06 MAF are readily available.
You don't need one, Rick's ported intake would do wonders, and the stock MAF would be more than adequated.
Old 01-02-2013, 06:59 PM   #7
ExpLiciTSainT
As I'm ignorant in this, can't Speed Density take over in the higher limits where the MAF may max out?
I should ask Pat G that.
Old: 353.8
Old 01-02-2013, 07:00 PM   #8
ExpLiciTSainT
Probably physically bigger removing a slight airflow bottle neck maybe?
Old: 353.8
Old 01-02-2013, 08:57 PM   #9
gr8lover
you can just remove MAF is you do a full SD tune... if mixed or split.... not sure on that one but i would assume your right?......
Old 01-02-2013, 10:00 PM   #10
The Yeti
'Mod'erator
The Yeti's Avatar
You definitely don't need the bigger maf, But the LS7 maf responds better IMO. It makes the gas peddle touchier if that makes any sense.
Pat G Tune & DOD cam, RCR Intake & TB, 4IN MAF
Ported stock Heads, 2600 Stall, VCM, OBX, UDP
H&Rs, Konis, BMR, Brembos, Slotted/Drilled Rotors
3.27 Gears, ZL1 pump, LSA awaiting install
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.2 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
second gear pull
The Yeti is offline   Reply With Quote
Old 01-03-2013, 01:04 PM   #11
86cutlass350
i have a vararam cold air intake can i do this mod? if so where can i get the parts?
09 white hot g8 gt
86cutlass350 is offline   Reply With Quote
Old 01-06-2013, 02:36 PM   #12
joeygr8gt
joeygr8gt's Avatar
would a larger ls7 maf result in any gains for me? for 100 buck ill drop it in since im going for a new tune soon
kooks LT headers, hi flow cats, x pipe, corsa exhaust, Vararam CAI, ported TB/intake manifold, underdrive pulley, catch can, qtp electric cut outs, 160 t stat, HSRK, H&R lowering springs, BMR sway bar
12.6 @109-old tune
joeygr8gt is offline   Reply With Quote
Old 01-06-2013, 04:11 PM   #13
TyG8GXP
TyG8GXP's Avatar
I'm still running the stock MAF.....
2009 M6 G8 GXP - Sold
710rwhp/742rwtq
TyG8GXP is offline   Reply With Quote
Old 01-06-2013, 05:58 PM   #14
Daniel Linnett
Daniel Linnett's Avatar
When you run my setup
Sent from my iPhone using AutoGuide.com Free App
427 LSX Block, custom diamond nitrous pistons, Ultra Billet rods, Lunati Crank, Jessel Rockers, Solid Rollers, All Pro cathedral Heads, Mast 4500 Cathedral Intake, 6061 Elbow, Nitrous Outlet Stinger plate and much more!
Hunting 8s
Sponsors: East Texas Muscle Cars; Henson Racing Engines; FTI Converters and Transmissions; Comp Cams; Mast Motorsports; BMR Suspension; Nitrous Outlet; 6061.com
Daniel Linnett is offline   Reply With Quote
