Caster Correction Needed? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 01-11-2013, 10:47 AM   #1
Stevesm943
Stevesm943's Avatar
Default Caster Correction Needed?
I'm wondering if caster correction is needed when you lower the vehicle? Does anybody know you can get the caster to on a lowered car with stock alignment bolts?
2009.5 GT liquid red
Kooks 1-7/8" lt ,Vararam, UDP
404 Stroker
231/239 111+0 .622/.629 Crawford heads & intake, Coan 3000 stall, no cats, Solo 3"
BMR rear suspension goodies, eibach lowering springs, FE3 suspension, VMR 701's
Comp trunion upgrade, camaro trans pan, 3.45's
Rick Crawford tune 11.35@123 4-25-15
Stevesm943 is offline   Reply With Quote
Old 01-11-2013, 11:56 AM   #2
greggy
The caster does not change enough to worry about when lowering. They are not ajustable without buying parts anyway. If you want a little more dynamic camber or increased steering resistance and return, then you can get a front caster kit from bmr, pedders, kollar, etc.
greggy is offline   Reply With Quote
Old 01-11-2013, 12:04 PM   #3
Stevesm943
Stevesm943's Avatar
Thanks greggy. Do you happen to know what happens when the rubber bushings aren't timed when you lower the car? I'm going to time the front when I get off work & then it's getting lined up today using BMR's specs. Hope everything works out! The car drives fine until about 70 mph then it doesn't seem to track straight, feels like the back end is wandering.? Kind of scary! It drove fine until I added the cradle bushings & lowered it, might just be a bad alignment? I wasn't given any specs on the alignment also my steering wheel is off a little bit & it wasn't before.
404 Stroker
Old 01-11-2013, 12:48 PM   #4
greggy
You only need to time rubber bushings that were loosened when the wheels were off the ground. If you don't the car may sit high and not ride/handle right.
The rear having toe-out due to lowering is what probably feels weird in the back.
Old 01-12-2013, 11:05 PM   #5
hayabusa160
It's good practice to time the bushings on a lowered car to extend the life of the bushings
http://www.g8board.com/forums/signaturepics/sigpic4288_1.gif
Kooks long tubes, Kooks axle backs, rotofab cai, ported tb, koni yellow shocks, h&r springs, bmr bushings kit, rear toe and traction arms. Bmr sway bars. forgestar f10 20x9.5 35 offset 275/30/20, 20x10.5 42 offset 285/30/20
hayabusa160 is offline   Reply With Quote
Old 01-16-2013, 04:34 PM   #6
BMR Sales
Site Sponsor
BMR Sales's Avatar
From all the testing we have done here at BMR we have found that people make timing the bushings a much bigger deal then it really is (timing the bushings is super popular with the new Camaro crowd). We have found that there really is no difference in performance when timing the bushings but it does help with the finalized ride height (within .25” or so). The only time you really need to time the bushings is when you are dealing with factory rubber bushings because the inner sleeve doesn’t rotate freely inside the bushing and the rubber bushings deflect so much.
From everything we have talked about through e-mails, PMs, and over the phone I really think the alignment is a bit off which is making the rear end feel like it is wandering. Without knowing the current alignment specs we really can't do anything besides speculate. I would get it over to a reputable alignment shop and throw it up on the alignment rack and see what specs you car is currently aligned at.
T.C. Davis
BMR G8/5th Gen Camaro Specialist, Muscle Car Tech, Road Racer
tc@bmrsuspension.com
www.bmrsuspension.com
Like us on Facebook!
BMR Sales is offline   Reply With Quote
Old 01-16-2013, 06:07 PM   #7
Bo White
Bo White's Avatar
When you lower a vehicle it usually increases caster but does it evenly on both sides. Its not an issue since the increased caster also helps in handling.
Old 01-16-2013, 08:08 PM   #8
Stevesm943
Stevesm943's Avatar
My rear end was toed out slightly. I'm guessing that was what was wrong, won't really know until I get the snow tires off.
404 Stroker
Old 01-16-2013, 11:29 PM   #9
Bo White
Bo White's Avatar
Yes, thats another thing that happens when you lower a vehicle(depending on weither its forward mount tierods or rear) is it toes out before realignment.
Old 01-17-2013, 12:58 PM   #10
BMR Sales
Site Sponsor
BMR Sales's Avatar
That could definitely be an issue depending on how far out it is. Let us know how everything goes once you get the car realigned.
T.C. Davis
