SLP Headers/Corsa catback - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 01-17-2013, 02:06 AM   #1
gtomark71
gtomark71's Avatar
Default SLP Headers/Corsa catback
I'm not a gear head, and need a little advise.
I've decided to go with the SLP 30210 Headers and a Corsa catback exhaust system.
My question is:
Do these two systems mate together or do they need some sort of custom installation or special connection pipes to be ordered as well?
BTW-I will be having them installed professionally.
Also, after reading through these forums, I need someone to explain to me what WOT and AFM mean?
Thanks in advance.
2009.5 GXP #571 of 1829
PBM M6 red/onyx sunroof 1 of 70
SLP longtube headers w/high flow cats
JHP VCM OTR CAI
HSRK
Holden HSV engine cover
Holden rear VE SS/SS-V trunk lid spoiler
DBA slotted rotors
Hawk ceramic brake pads
rear Camaro calipers/rotors
Squash rear caliper brackets
Custom E-brake shoes
SLP 160 degree thermostat
SLP skip shift eliminator
Custom Dyno tune by Doug from ECS
426 RWFT 423 RWHP
gtomark71 is offline   Reply With Quote
Old 01-17-2013, 05:17 AM   #2
Scorpious
G8 fiend
Scorpious's Avatar
on some sites you will see if they are compatible or not or if u need an extra piece to fit them together. i looked on various sites and jus look at the inlet/outlet if there the same they should fit or u will be an extra bracket but the site should tell u
<a href=http://s98.photobucket.com/user/repozone/media/DSCN0298.jpg.html target=_blank><img src=http://i98.photobucket.com/albums/l259/repozone/DSCN0298.jpg border=0 alt= /></a>
Scorpious is offline   Reply With Quote
Old 01-17-2013, 06:12 AM   #3
G8ITRGH
WOT= wide open throttle
AFM = active fuel management
G8ITRGH is offline   Reply With Quote
Old 01-17-2013, 08:31 AM   #4
Norm8332
G8 GT GUY
Norm8332's Avatar
Yes it fits.
2008 G8 GT: Magnacharger TVS MP1900 @9psi, LS9 cam, 72# injectors,SLP Headers, Corsa catback
Norm8332 is offline   Reply With Quote
Old 01-17-2013, 11:37 AM   #5
drewdog
drewdog's Avatar
i believe slp is the only header that will bolt right on, correct me if i'm wrong.
awesome setup!
'08 PBM GT
Roto-Fab CAI, SLP Headers, GXP Catback, Tuned
Pedders Street I, FE3 Struts
Tints, Sharkfin antenna, passenger seat mod
drewdog is offline   Reply With Quote
Old 01-17-2013, 11:41 AM   #6
Agose25
Agose25's Avatar
SLP even being a "LT" header is the same length as the OEM manifolds, so yes it should bolt right up to the Corsa system. SLP LT's and Kooks Mids are the only two headers that bolt up directly to the OEM and Aftermarket catbacks.
Old 01-17-2013, 12:13 PM   #7
2lazy4agoodname
2lazy4agoodname's Avatar
And doug thorleys.
09 PBM G8 GT -
Built By Rick Crawford Racing
404 Stroker / Ported LSA Blower / 2" Headers / Built Trans / Alky Methanol
RCR Heads & Cam / Built 6l80 / TPIS TB / ATI Balancer / Vaporworks & V Pump
Solo / CTS-V Brembos / BMR / VMR V701 / H&R Coilovers / Holden SSV Conversion
9.89 @ 138.8
09 WH GXP M6 (#1827 of 1829)
Roto-Fab / Solo Mach Shorty
2lazy4agoodname is offline   Reply With Quote
Old 01-17-2013, 12:19 PM   #8
Jeff92se
Don't the SLP's high flow cats neck down(at the outlets) to the small oem inlet size?
Jeff92se is offline   Reply With Quote
Old 01-17-2013, 01:37 PM   #9
Agose25
Agose25's Avatar
Originally Posted by 2lazy4agoodname View Post
And doug thorleys.
That's right, I always forget about the Thorleys...These would be the only catless direct bolt on header available.
Old 01-17-2013, 05:38 PM   #10
gtomark71
gtomark71's Avatar
Thanks for the replies.
Just to clarify, the SLP has the high flow cats attached to them.
Is this still OK to to mate with the Corsa catback system?
JHP VCM OTR CAI
HSRK
DBA slotted rotors
426 RWFT 423 RWHP
Old 01-18-2013, 10:55 AM   #11
drewdog
drewdog's Avatar
yep - be sure to take some vids after the install, i've always wanted a corsa setup.
'08 PBM GT
