Track Day Advice - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > Racing > Autocross / Road Course Racing
Old 01-17-2013, 05:33 AM   #1
ROGRSS
ROGRSS's Avatar
Default Track Day Advice
Hi Guys,
I'm from down under and looking at doing a couple of track days soon. Not a lot of VE's (G8's) get tracked down here and most of the ones that do are manual.
Mines an auto (standard apart from exhaust, brembo brakes up front, pedders springs and cai ) and I'm after some advice on what are the safety measures I can take for the car to be able to drive home again at the end of the day.
I think these cars are pretty tuff so all I was looking at was a larger transmission cooler to keep the tranny temps down.
Hope some of you guys on here that have track experience can help.
Cheers Paul
Holden VE SS A6
ROGRSS is offline   Reply With Quote
Old 01-17-2013, 09:18 AM   #2
GXPaycheck
GXPaycheck's Avatar
I assume that, like over here, you have to get an inspection done prior to track time. Good track pads on the brakes and new fluid is a must! Brakes on a road course are top priority. remember "slow in = fast out! (Turns, that is!)
RIP Charlie, The GRRRR8 One
2009 G8 GXP, #715 0f 1829 (one of 38 as optioned), Magnetic Silver, 6M, Sunroof, Onyx/Red
VCM, Magnaflow axle-backs, WAMS IWM/VIM, Back-up camera with JHP autoswitch, Homelink by Snakey, Pedders bushings
2014 Chevy SS, Mystic Green, roof. One of 144
Forum junkie at the G8Board and "The G8 Forum That Shall Not Be Named"!
GXPaycheck is offline   Reply With Quote
Old 01-17-2013, 10:08 AM   #3
brad02ss
brad02ss's Avatar
I've done 20min sessions manually shifting and driving the car hard and the trans is fine with that.
As mentioned above, make sure your brake pads are good, consider a higher temp brake fluid, check other fluids, tire pressure, etc.
Start slow, learn you and your car's limits on braking points, corner speed, etc and gradually get faster.
And of course, have fun!
35th Anniversary Edition Camaro SS garage queen
G8 SOLD to AlbertGT
http://www.g8board.com/forums/showth...=1#post1501177
brad02ss is offline   Reply With Quote
Old 01-17-2013, 10:36 AM   #4
DougHG8
Agreed with the other guys. I think your trans will be fine at your power levels. My first two days, I used Sport mode and let the car shift for me so I could pay more attention to driving; now I use manual mode so I control when torque changes to the wheels. Have fun!
2009 Hot White G8 GT, CTS-V v1 fronts, Camaro 20's, BMR Sways, Eibach Springs, Rear Cradle bushings. GXP FE3's, BMR rear susp. Kooks 1 7/8 LT headers, RCR custom 3 exhaust, ported LSA blower, 2.38 pulley; Ported heads and TB; LS7 MAF, Racetec pistons, Scat rods, CTS-V crank; FAST 85 injectors; RCR Lunati cam: 223/238 .615/.601, 116 +2 LSA. CTS-V pump/VaporWorx cntlr. Built trans, Methanol injection. Rick Crawford built and tuned. Best 1/4 9.90 @140, 1.45 60'.
DougHG8 is offline   Reply With Quote
Old 01-17-2013, 01:37 PM   #5
TCorzett
The first day or two on track YOU will be the "weak link". Take it slow and learn the driving line, how to keep your eyes-up, etc. As you get better/faster you'll start pushing the car more. Changing the brake fluid to one with higher boiling point and using track pads would be the next upgrade.
-Todd...
PS - I added a trans cooler, but it was because I went to taller gears.
TCorzett is offline   Reply With Quote
Old 01-17-2013, 03:29 PM   #6
r1owner
That's ME!
r1owner's Avatar
Be prepared for a hot oil light...
Scott
2010 IBM Cobalt SS GMS1
2009 PSM GXP A6 #1803/1829 sold
r1owner is offline   Reply With Quote
Old 01-17-2013, 04:42 PM   #7
ROGRSS
ROGRSS's Avatar
Thanks for the info guys.
Looks like i'll upgrade pads and brake fluid for the day. I should have the trans cooler on by then also, so i should be ready to get out there and have some fun.
Paul
Holden VE SS A6
