The difference between my 6.2 LS3 and the Corvette - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Community > G8 GXP Talk (V8)
Old 01-23-2013, 01:58 PM   #1
Ode2Joy
Ode2Joy's Avatar
Default The difference between my 6.2 LS3 and the Corvette
I was just wondering about the primary differences between the 6.2 LS3 engine in my GXP versus this same engine in the Corvette at that time. I know the GXP's version was "de-tuned" some. For example, the HP rating for the GXP is 415. What was the Corvette's with this same engine?
I apologize if this question has been asked before and is on here somewhere. Thank you!
2009 LR A6 G8 GXP
#986 of 1829 produced
#60 of 81 as optioned
Ode2Joy is offline   Reply With Quote
Old 01-23-2013, 02:00 PM   #2
Troy Trackbeast
Super Moderator
Troy Trackbeast's Avatar
same engine. Different exhaust set ups I think (manifolds, mids and mufflers) is what accounts for the difference in HP ratings I believe...
Troy Trackbeast is offline   Reply With Quote
Old 01-23-2013, 03:41 PM   #3
bracketracer
Approved Dealer
bracketracer's Avatar
I believe that the LS3 in the G8 GXP, Camaro SS, and Corvette is the same engine. The differences are with intake, exhaust, and factory rating. The intake and exhaust system on the Vette are from the factory are much less restrictive.
Joe Morgan, G8 GXP Registry Organizer, G.O.N.E. Organizer 2010-2013
'93 Sunbird SE 3.1/5-speed 14.869 @ 90.96
2009.5 G8 GXP WH 6M onyx/red no roof 12.921 @ 108.89 BONE STOCK! (then), 12.344 @ 110.92 with 1.688 60' at 766' DA, PB with new cam & tune - 12.191 @ 112.35 with 1.693 60' at 1319', 2:59 lap time at Road America on RS-As
VCM OTR CAI, HSRK, Heater Hose Relocate, custom street/dyno tune by oldskoolgp, Comp Cams 224/228 .581"/.588" 112 LSA cam, LS7 lifters, PAC 1219x springs, Monster LT1S (C7 Corvette) Clutch kit, Katech C6 Hvy Dty Master & Slave Cylinders, Camaro 1LE Diff with 3.91 gears, Kooks LTHs, Solo Hi-Flo Cats & Connector Pipes, Solo Mach Balanced Catback, BMR Toe Rods, Trailing Arms, Cradle & Diff Poly Bushings, DRs
1 of only 10 built in this combo (1 of 4 this combo with RS-As)& #1497 built of the 1829
bracketracer is offline   Reply With Quote
Old 01-23-2013, 03:57 PM   #4
Ode2Joy
Ode2Joy's Avatar
I get the biggest kick out of being able to say that my car has a Corvette engine. It's a great conversation starter
2009 LR A6 G8 GXP
Old 01-23-2013, 04:10 PM   #5
Roadcone
HeapBlaster
Intake and exhaust are different, everything inside is the same.
i hate when people say they have a corvette engine when talking about a GXP or TBSS or even a camaro...
2009 G8 GXP M6 - Katech LS9R Clutch, SLP LTs w/ !cat, Magnaflow X-pipe added, OBX-R axleback, VCM OTR Intake, Powerbond 25% UDP, Taylors 10.4mm wires, SLP 160* TSTAT
Roadcone is offline   Reply With Quote
Old 01-23-2013, 04:13 PM   #6
Troy Trackbeast
Super Moderator
why? they do... Even though the TBSS has the LS2 in it, but hey that was in the 06-07 C6's.
Old 01-23-2013, 04:17 PM   #7
Roadcone
HeapBlaster
Sounds like that corvette has a truck motor... sounds pretty silly huh.
Old 01-23-2013, 04:32 PM   #8
drewdog
drewdog's Avatar
i thought engine "crank" horsepower was independent of the exhaust? the exhaust and drivetrain are what made it lose power, so that's why you go by "wheel" power on the dyno ? if you wiki LS engines, it only mentions the engine itself when it says how much power it makes.
in any case, i thought the crank power was different on corvette because some internals were different than GXP's - but i may be mistaken.
'08 PBM GT
Roto-Fab CAI, SLP Headers, GXP Catback, Tuned
Pedders Street I, FE3 Struts
Tints, Sharkfin antenna, passenger seat mod
drewdog is offline   Reply With Quote
Old 01-23-2013, 04:44 PM   #9
Topher3134
I say corvette motor and I have both a camaro and a gxp. That's what it is. Ls3 was designed for the vette. Just like if they put the 5.8 from a gt500 in a 4door car it would have a gt500 motor in it.
Topher3134 is offline   Reply With Quote
Old 01-23-2013, 04:53 PM   #10
BigV8
BigV8's Avatar
To the op, I believe the vette was rated at 436? I just say its the LS3 thats in the corvette but only makes 415.
Sold and wish I hadn't.09 GXP SRM A6 w/sunroof. Mods:Livernois Maggie 2.3, 3.0" pulley, 160 stat, KB Bap. Rotofab,Corsa, Kooks 1 7/8 mids, BMR,Pedders supercar coilovers, all Brembos, CTS-V rims, Hids, halos, leather console lid. HSV gauges. 502rwhp,479tq#873 of 1829 and 1 of 169 in SRM.
BigV8 is offline   Reply With Quote
Old 01-23-2013, 05:25 PM   #11
Bo White
Bo White's Avatar
I have an overlay of my GXP and my buddys 08 Vette. Its redonculouse the difference at the wheels. The Vette has better manifolds, intake, 2.5" exhaust and more aggressive tune with a slightly more effecient rear. My car stock with a Rotofab and ported TB on the rollers compared to the bone stock 08 Vette:
Old 01-23-2013, 05:36 PM   #12
Bo White
Bo White's Avatar
BTW, this is the reason why Vettes dont respond as good as Camaros and GXPs with headers/intake/tune.
Old 01-23-2013, 05:42 PM   #13
BigV8
BigV8's Avatar
Thats a good comparo there Bo White.
Old 01-23-2013, 05:44 PM   #14
Bo White
Bo White's Avatar
You cant get any better on comparisons lol. Same day/same dyno(It was a dyno day).
BTW, the most my car made that day bone stock was 359 and it was a cold run. It made 354 warmed up.
Old 01-24-2013, 10:21 AM   #15
carsuperfreak
carsuperfreak's Avatar
Since an engine is effectively an air pump, power is a function of how much air you can push through it, and how efficiently. Induction restriction directly impacts how high of manifold pressure can be sucked in during the intake stroke, and exhaust backpressure/tuning directly impacts how efficiently the exhaust can be expelled from the chamber.
When we SAE certify, we are required to run the vehicle-intent induction and exhaust restriction, which is where the power disparity comes from from the LS3 in the Camaro, Corvette, and GXP.
carsuperfreak is offline   Reply With Quote
Old 01-24-2013, 05:35 PM   #16
AuggieDosta
IdontRe Member
AuggieDosta's Avatar
This bolded by Bo is dead on accurate as to the diff between the LS3 in the GXP and Corvette.
I was reading all the previous posts and couldn't get to the end fast enough.
PS, I also say, "it's got the LS3 engine in it; same engine as the vette."
'09.5 Pontiac G8 GXP, A6, Sunroof, SBM
#1,693 of 1,829 and #29 of 35 as optioned (1 of 56 SBM's)
'01 Chevy Silverado LT (4x4) 6" IFS lift, 35" tires
AuggieDosta is offline   Reply With Quote
Old 01-24-2013, 05:39 PM   #17
drewdog
drewdog's Avatar
intereseting, thanks - so does that mean if gxp ls3 and vette ls3 have exact same setup for SAE testing, they would yield same #s ?
'08 PBM GT
Old 01-24-2013, 05:55 PM   #18
Bo White
Bo White's Avatar
No, they are SAE cerified by the emissions/intake/exhaust/tune each vehicle will have.
So the testing for the Vette had Vette external parts on it and the same goes for the Camaro and GXP. Seperate certifications for each application.
Old 01-24-2013, 08:57 PM   #19
courtroom19
courtroom19's Avatar
He said "if" they had the same setup.
I suspect the answer would be yes, but I can't guarantee it.
Need Wheels or Tires? I can help.
09 MGM GT 1SD With Roof. Sold
09 PSM G8 GXP M6 (1 of 9)SOLD
courtroom19 is offline   Reply With Quote
Old 01-24-2013, 09:12 PM   #20
STAGEUP
I just ask this, why in the world did they use a 2.25" exhaust in the GXP???? A 2.50" exhaust wouldn't have been any louder imo.
PBM G8 GXP M6-Self tune,VCM cai, OBX LTs, Kooks axleback, Monster Stage 3 clutch, flex fuel 11.83@116.7 1,353 D.A
2007 TBSS-Self tune, bolt ons 13.06@106.7, 2,200 D.A
1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
STAGEUP is offline   Reply With Quote
