steering wheel shake discovery - don't know what it means - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 02-12-2013, 08:16 PM   #1
ldnmark
ldnmark's Avatar
Default steering wheel shake discovery - don't know what it means
I've been steering wheel shake free (mostly) since my last tire balance however something strange occured the other day. Left a parking lot to merge on to the highway and the stability control kicked in a bit. accelerated to 90-100KMh and the dreaded steering wheel shake was back, all the way back in to town. haven't experienced it since at highway speeds.
Does that just add to the conundrum?
ldnmark is offline   Reply With Quote
Old 02-12-2013, 09:33 PM   #2
SMSO966
Supercharged Moderator
SMSO966's Avatar
Radius rod bushings need to be replaced.
DD: 08 White Hot G8 GT Best E.T. 12.698 @ 109.1 MPH
VMR 20's 4 Wheel 04 CTS-V Brembo's
FE3 & Eibach,
Roto Fab,Doug Thorley LTs Magnaflow
1 of 1,086 2008 White Hot Pontiac G8 GT's
Garage Queen:
09 Stryker Blue G8 GT (No ET Under construction)
TVS1900, GXP 19's, 4 Wheel 09 CTS-V Brembo's
Rotofab, Solo, More to come soon!
Sold!
SMSO966 is offline   Reply With Quote
Old 02-12-2013, 09:34 PM   #3
SMSO966
SMSO966's Avatar
Don't go back with stock either, get some poly pressed in to your stock radius rods, or buy new radius rods, press out the new bushings, and press in a poly bushings.
FE3 & Eibach,
Garage Queen:
Sold!
Old 02-17-2013, 10:34 PM   #4
Kirkinsb
Kirkinsb's Avatar
SMS0966, did you get rid of your front end shake during hard braking with these bushings?
2009 Switchblade Silver G8 GT. Cortex Rotofab 91 tune, BBS wheels, V8 & V badging. MagnaFlow Axlebacks, Black Colgan Front Bra, Spectre CAI, 12" JL Powerwedge Sub in truck with 375watts & Infinity Kappa 62.9i in all doors, GXP Rear Diffuser, M&P 40c w/viridian laser/light for protection.
Kirkinsb is offline   Reply With Quote
Old 02-21-2013, 02:21 AM   #5
BMV
What is the radius rod? Anyone have a picture possibly?
2008 MGM G8 GT
BMV is offline   Reply With Quote
Old 02-21-2013, 12:48 PM   #6
GT Drew
Radius rods are the bent ones. #7
GT Drew is online now   Reply With Quote
Old 02-23-2013, 01:34 PM   #7
BMV
I'll have to check that for play...it looks like the bushing is a separate piece all together so I'll just buy some poly bushings like someone else said! Where should I get them? Bmr?
2008 MGM G8 GT
Old 02-23-2013, 03:50 PM   #8
SMSO966
SMSO966's Avatar
Wheel shaking under braking is caused from warped rotors. Wheel shaking while under power or coasting could be a myriad of other issues. The most common being wheel out of balance, or with these cars, radius rod bushings.
Yes, my wheel shake under power was completely cured with new radius rod bushings.
FE3 & Eibach,
Garage Queen:
Sold!
Old 02-23-2013, 03:52 PM   #9
SMSO966
SMSO966's Avatar
Yea, and the bushings that need to be replaced with poly are #8.
FE3 & Eibach,
Garage Queen:
Sold!
Old 02-25-2013, 08:31 PM   #10
srt/gtx
srt/gtx's Avatar
What if the wheel vibrates at speeds about 75mph?
srt/gtx is offline   Reply With Quote
Old 02-26-2013, 01:48 PM   #11
zepcom
If it's not what is described above, then maybe this?
http://www.g8board.com/forums/showthread.php?t=27943
Mine turned out to be badly balanced tires from the factory, Goodyear RS-A's. After upgrading to better rubber and having them all 4 road force balanced, all shakes and shimmys went away and she's smooth as a bird. On both sets of rims.
That's just what worked for me, difficult to "chase" sometimes, best is to gather up your symptoms and see if possibly tire rotation (position rotation, not just spinning the wheels, lol) might help mitigate the issue, as if a slightly-out-of-balance rim is on the front, you tend to feel it more in the steering wheel. At least that could point you to the road force balance which is a cheap solution to try and fix the problem. I had all 4 wheels, tires, tpms, mounted, rfbalanced for 40 total, when I bought new tires, which resolved the issue.
Still could be something else, so check out that TSB link above and do your research.
--zep
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Old 02-26-2013, 01:55 PM   #12
SRG963
Its Good To Be Tha King
SRG963's Avatar
Ensure balanced tire pressure.
Trigger - Fully Loaded 2008 Stealth Blue Pontiac G8 GT
Rotofab/Cortex/BMR/Pedders/VMR/
Adams/OBX/Nitto
PRAISE THE LOWERED
SRG963 is offline   Reply With Quote
Old 02-26-2013, 04:43 PM   #13
srt/gtx
srt/gtx's Avatar
I know i have 1 bent rim in the front and one in the back, but its weird how thr car only starts vibrating at apeeds above 75? Im hoping its only bc of the bent rims?
Old 02-26-2013, 06:35 PM   #14
DURAMAXDAVE
DURAMAXDAVE's Avatar
Had issues with Steering wheel shake, mine was a bad balance.
09 G8 GT White Hot
06 G6 GT
98 TA
DURAMAXDAVE is offline   Reply With Quote
Old 02-26-2013, 06:53 PM   #15
zepcom
move both bents to the rear, see if it improves. Then replace rims if you really want the back (bent) ones to be rounder and therefore hopefully trouble-free / vibration free.
If a bent rim is on the front, you will probably feel driveline vibration moreso.
