LCA Replacement - DIY or dealer? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 02-25-2013, 10:02 AM   #1
davefr
Default LCA Replacement - DIY or dealer?
I'm curious if LCA replacement is a typical DIY job or if it's best done at the dealer.
(the reason is I see special tools listed in the TSB)
Has anyone done it themselves?
'08 G8 GT - Black
davefr is offline   Reply With Quote
Old 02-25-2013, 10:10 AM   #2
drewdog
drewdog's Avatar
if you choose to have it done professionally, i would buy the kit from pace and have a good mechanic do it and not the stealership. save a bunch that way.
'08 PBM GT
Roto-Fab CAI, SLP Headers, GXP Catback, Tuned
Pedders Street I, FE3 Struts
Tints, Sharkfin antenna, passenger seat mod
drewdog is offline   Reply With Quote
Old 02-25-2013, 10:17 AM   #3
JCGG8GT
JCGG8GT's Avatar
Dealership just quoted me $1,200 to do the job!!!!!
2009 G8GT Black on Black, Sport/Premium, ....Just like I like it!
JCGG8GT is offline   Reply With Quote
Old 02-25-2013, 10:23 AM   #4
bostonf4$
Is the "front control arm kit" the LCA replacement parts on Pace's website? Unfortunately I think mine are finally starting to go again - 70,000 miles on them
Old 02-25-2013, 10:57 AM   #5
SRG963
Its Good To Be Tha King
SRG963's Avatar
^Yes, and the kit comes with everything you need.
Install is about an hour.
$1200 is outrageous! Cost me around $350 total.
Trigger - Fully Loaded 2008 Stealth Blue Pontiac G8 GT
Rotofab/Cortex/BMR/Pedders/VMR/
Adams/OBX/Nitto
PRAISE THE LOWERED
SRG963 is offline   Reply With Quote
Old 02-25-2013, 11:03 AM   #6
davefr
Thanks but are specialized GM tools needed? Did you need anything special other then common mechanics tools?
The manual shows this tool as needed:
Is there an alternative?
'08 G8 GT - Black
Old 02-25-2013, 11:18 AM   #7
drewdog
drewdog's Avatar
yeah right. that's 10 hours ! it's a 3 hr job, if that.
'08 PBM GT
Old 02-25-2013, 12:03 PM   #8
Rob@WretchedMS
Suspension Guru
other than sockets and normal tools, the only thing you need is a hammer to hit the side of the knuckle where the ball stud goes through to release the tension that holds it.
Rob@WretchedMS is offline   Reply With Quote
Old 02-25-2013, 12:24 PM   #9
BigZub
BigZub's Avatar
I had the ball joint separator tool you show. It didn't work. A hammer did.
Do it yourself, it's not that difficult. If you decide to do it, take the 10 minutes per side to remove the inner fenderwells first. Makes getting at the forward bolt a lot easier.
Also, remember that proper procedure typically calls for putting it back together with the bolts almost tight, putting the wheels on, lowering the car so there's weight on it, then tightening the bolts with it on the ground (which is another reason to remove the inner fenderwells). Then, jack it back up, pull the wheels again, and replace the inner fenderwell covers.
Good luck.
'09 Pontiac G8 GXP, A6, Sunroof, MGM, #1664 of 1829
GMM RAMJET OTR CAI, Livernois E/TCM Tune, Kooks 1-7/8" LTs, catted mid-pipe, Hooker Polished SS MaxFlow mufflers - 394RWHP/386RWT
BMR Rear LCA's, stabilizer bars, end links, front LCA bushings, rear toe links and trailing arms, Pedders Street II kit, including subframe and diff bushings.
Hawk Ceramic pads, Brake Performance slotted and dimpled rotors, Russell stainless lines, Super Blue fluid.
Best 1/4 time - 12.52 @ 114.47, 1.94 60ft.
BigZub is offline   Reply With Quote
Old 02-25-2013, 12:55 PM   #10
JASCIN
The hardest part for me was getting a wrench lined up with the bolt heads to perform the final tightening (after dropping the car from the jack-stands.) BigZub hit the nail on the head with his recommendation for pulling the fenderwell (and hammer for the ball-joint).
2009 G8 GXP - White Hot, A6, Red/Onyx Interior
Exhaust, intake, suspension, CTS-V Brembos, widened factory wheels, etc.
JASCIN is offline   Reply With Quote
Old 02-25-2013, 02:25 PM   #11
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
Good year quoted me like 80 bucks per arm, per sway bar for install.
Old: 353.8
New: 632/530 Mustang Dyno
Old 02-25-2013, 03:31 PM   #12
Rob@WretchedMS
Suspension Guru
sounds about right, 80-100 per arm
Old 02-25-2013, 03:52 PM   #13
I12XLR8
Proud OGOC member!
I12XLR8's Avatar
Good to read this thread. I'll be tackling it myself if my front end clunk is the LCA again. Are the only options OEM and Spohn?
"I have dreamed a dream, and now that dream has gone from me" - Morpheus of the Nebuchadnezzar, and Grant of I12XLR8.
'Luskville is a cool experience, Calabogie is incredible, Mosport is life altering'
I12XLR8 is offline   Reply With Quote
Old 02-25-2013, 03:54 PM   #14
jspayne66
jspayne66's Avatar
Moog appears to be having something coming out soon.
jspayne66
2009 Liquid Red G8 GT - Sport & Premium
jspayne66 is offline   Reply With Quote
Old 02-25-2013, 03:59 PM   #15
Rob@WretchedMS
Suspension Guru
Only options are:
OE
Pedders
Moog (soon)
any not listed are not something that i consider safe.
Old 02-25-2013, 04:07 PM   #16
I12XLR8
Proud OGOC member!
I12XLR8's Avatar
Any idea if the MOOG part is going to be marketed as an upgraded piece? $350 sounds fairly good to me for stock stuff...
Old 02-25-2013, 04:09 PM   #17
I12XLR8
Proud OGOC member!
I12XLR8's Avatar
Originally Posted by Rob@WretchedMS View Post
Only options are:
OE
Pedders
Moog (soon)
I tried to check on the Pedders pricing but someones site is down ;-(
Old 02-25-2013, 04:22 PM   #18
ExpLiciTSainT
I'd wait if it is new. GM isn't the only company to release LCAs that fail extremely quick.
Old: 353.8
Old 02-25-2013, 04:23 PM   #19
ExpLiciTSainT
Only options are:
OE
Pedders
Moog (soon)
Hey Rob - how much are the Pedders LCAs?
Old: 353.8
Old 02-25-2013, 04:24 PM   #20
Rob@WretchedMS
Suspension Guru
website is up, not sure if there was an issue or not.
pedders arms with bushings are 1093 shipped
