3.5" tips install - Pontiac G8 Forum: G8 Forums - G8Board.com
Solo Performance
post #1 of 3 (permalink) Old 06-14-2012, 10:45 AM Thread Starter
dmarple80's Avatar
3.5" tips install
I'll be installing the 3.5" tips on my Solo CB this wknd, along w/ the GXP diffuser.
Since these tips slide over the tailpipe and then you clamp down or weld on, you can determine how much of the tip sticks out of the diffuser or is recessed into the difuser.
What do people feel looks best and then how do you create that look? I was think I need to put tips on, slide back and forth to get the look I like, clamp down and then take whole J-pipe section off and take to shop to get welded into place.
Any better ideas?
2008 LR GT
Pat G tune, LS7 MAF, RCR P/P/Milled LS3 Heads & valve job, ported AirRam Intake / TB & Little Lunati cam, Pypes LT's, Solo CB, Spectre CAI, Powerbond UDP
BMR rear cradle bushings, BMR F&R Swaybars, Teins & FE3's
dmarple80 is offline
post #2 of 3 (permalink) Old 06-14-2012, 10:52 AM
you could consider having an exhaust shop "tack" it into place where you like it, and skilled welders shouldn't need to remove the rear sections to fully weld the tips where you need them.
Even with tack welding it and having to remove them to fully weld them, they won't be moving from the tack procedure.
Livernois tune, VCM, FE3's, full Holden blue gauges conversion, iphone on display. Daily Driver FTW
Bought 3/30/2009, retired 7/18/2017 at 136k miles, still strong. Been a great ride, she will be missed!
post #3 of 3 (permalink) Old 06-14-2012, 03:21 PM Thread Starter
dmarple80's Avatar
Thanks Zep, I think I'll clamp them down to my liking and then drive to a shop and have them add a couple of "tacks" to each tip for strength w/o taking the whole J-pipe off.
2008 LR GT
