P0008 - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 6 (permalink) Old 11-16-2015, 07:55 PM Thread Starter
P0008
Hello Guys,
Newbie here with the dreaded P0008 and P0019.
After a lot of reading I know the P0008 is the timing chains. I have bought all of the chains, sprockets, tensioner and guides. Along with a new water pump and two CPS. As well as gaskets.
What I don't understand is in some readings they say to rotate the motor 115 degrees when installing the last chain. If that is so, how far is 115 degrees?
Any help would be appreciated,
David
g8pmd is offline
post #2 of 6 (permalink) Old 11-17-2015, 01:04 AM
Well 180 degrees is half a turn so. At little more than a quarter turn. Not sure if this helps at all.
post #3 of 6 (permalink) Old 11-18-2015, 05:58 PM Thread Starter
P0008
Can someone recommend what to use to seal the timing cover to the block ??
Thanks, David
g8pmd is offline
post #4 of 6 (permalink) Old 11-19-2015, 03:13 AM
Hey Dave, welcome to the board first off.
With the timing chain kit did you get a gasket? If not you can use a thin coat of RTV silicone.
post #5 of 6 (permalink) Old 11-28-2015, 08:00 PM
They say to not use rtv on these cars there is a proper sealant that you can get from gm That I have been told that should be used for these motors. I would look into it. I was told this by the person who just did my chains and everything you are doing and he does allot of these chains so I trust him.
Jrokx is offline
post #6 of 6 (permalink) Old 11-29-2015, 08:14 AM
Use loctite 5900
"Opinions expressed are solely my own and do not express the views or opinions of my employer."
2009 G8 GT - Self Built - Kooks 1 7/8" LT, Catted connection Pipes, Corsa Cat Back Exhaust, VCM OTR, LS7 MAF, Custom Cam w/ DoD Delete, Ferrea L92 Hollow Stem Intake Valves, PSI 1511ML Valve Springs, LS7 Lifters, Cometic .040" Head Gaskets, Cloyes Hex-a-Just timing gear, 7.350" Comp Cams Magnum Pushrods, Flycut Pistons, 11.45:1 Compression, HP/TQ TBD, Pat G tuned.
G8One2 is offline
