100,000 kms - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 19 (permalink) Old 02-12-2016, 05:31 PM Thread Starter
norton13's Avatar
100,000 kms
My car is finally going to 100,000 km's(62,000 miles)this weekend. Car still runs like a champ. Looks almost brand new & runs great. I know other people probably have way more km's (miles) than I do. How is your V6 holding up.
[SIGPIC][/SIGPIC]K&N CAI, Pypes headers, Solo HFC's,Solo axle backs, Custom tune, FE3 Struts & Shocks, White line bushings & bearings, Rear Cradle inserts, Moog end links.Little lunati cam,SLP 25 %UDP, AC tensioner upgrade.15% tint.12" sub woofer with amp.Future upgrade Power slot rotors & posi quiet pads.
V6 Spectre CAI, Original Overkill tune,FE3 Struts & Shocks, White line bushings & bearings, BMR Rear Cradle inserts, Moog end links.12" sub woofer with amp.
norton13 is offline
post #2 of 19 (permalink) Old 02-12-2016, 06:35 PM
Superior Surveyor
Steven's Avatar
Originally Posted by norton13 View Post
My car is finally going to 100,000 km's(62,000 miles)this weekend. Car still runs like a champ. Looks almost brand new & runs great. I know other people probably have way more km's (miles) than I do. Hw is your V6 holding up.
I am right behind you ! 98,600! Only thing that has failed is the strut mounts and LCA's! Got a few maintenance things done here and there (Diff/Tran fluid changes), but runs great!
JOIN US @ WWW.OGOC.CA
09' V6 SRM, Rotofab CAI + Rad Cover, Custom Amp Rack, Rockford Fosgate R600x5 Amp, Audiocontrol LC7i Audio Processor, Kicker CS (6.5 Component and Coaxial) door speakers, 2 8" Rockford Fosgate P2D4 Series subs in factory location, Dynamatted doors & trunk lid, Wireless Screen Mirroring, Reverse Camera W/JHP Vim & Autoswitch, Bluetooth (Onstar), LED interior lights & Sidemarkers & License Plate, Morimoto 4500K HIDS in DRL, XML2 Fogs, Wireless Charging
Steven is offline
post #3 of 19 (permalink) Old 02-12-2016, 06:54 PM
OGOC member
Will M.'s Avatar
Ditto - strut mounts and LCA's- now at 147,000 km - My check engine light comes on occasionally and briefly- code relates to valve timing - Still enjoying the car every day!
2009 V6 Panther Black
Will M. is offline
post #4 of 19 (permalink) Old 02-12-2016, 08:14 PM Thread Starter
norton13's Avatar
My LCA' s where done before I bought it.FE3 Struts & Shocks White line bushings, bearings, BMR Rear Cradle inserts, Moog end links where done last year. Other than the driver door actuator, passenger seat trim zip tie fix & actuator on the fuel door. Car has been pretty good.The fuel door I have not even bothered with the it. The suspension was still okay but I wanted to stiffen it up.
norton13 is offline
post #5 of 19 (permalink) Old 02-12-2016, 10:56 PM
At 169,988km tonight when I parked her.
Runs great, looks great, though the stinkin 401 is taking its toll on it.
Feels like it needs brakes, get the suspension looked at, love to get a set of 19 inch GT rims for it otherwise....stinkin 401....
post #6 of 19 (permalink) Old 02-13-2016, 01:47 AM Thread Starter
norton13's Avatar
I have not done that that yet trans & diff fluid I will change it at 120,000 km's.
My GT still has not hit 75,000 km's yet.
norton13 is offline
post #7 of 19 (permalink) Old 02-13-2016, 02:02 AM Thread Starter
norton13's Avatar
You have not had a problem with your timing chain yet. I am doing 8000 km's oil intervals now I might bring them down to 6 or 7000 km,s
norton13 is offline
post #8 of 19 (permalink) Old 02-13-2016, 09:05 AM
No. Can't worry about those things, start it, drive it, deal with whatever happens.
But as you say regular maintenance is the key, I'm off this week will let my son take it into the GM dealership he works at and change oil take a look see at everything, starting to shudder under heavy braking so probably looking at getting those done.
post #9 of 19 (permalink) Old 02-13-2016, 11:47 AM
Superior Surveyor
Steven's Avatar
If you replace brakes (Provided thats the cause) let me know what you end up getting. I am in the market myself.
Steven is offline
post #10 of 19 (permalink) Old 02-14-2016, 03:26 AM
Im at 169,000 kms. It runs better now than ever.
post #11 of 19 (permalink) Old 02-14-2016, 04:37 AM Thread Starter
norton13's Avatar
It is good to know that these cars go the distance.
norton13 is offline
post #12 of 19 (permalink) Old 02-14-2016, 07:44 AM
Maintenance is the BIGGEST Thing to keep these going.
post #13 of 19 (permalink) Old 02-14-2016, 06:35 PM Thread Starter
norton13's Avatar
Anything new on the V6 tune with will?
norton13 is offline
post #14 of 19 (permalink) Old 02-15-2016, 05:36 AM
Not since the fall,Last thing was the larger throttle body.
We are researching a couple of things.
Just the cost factor at the moment. Have some home maintenance to do.
Im hopefully going to paint my rims before Lakeview . I have a copule things in mind for them.
post #15 of 19 (permalink) Old 02-15-2016, 03:20 PM
mrathell's Avatar
198,500 miles and still drives like the day it drove off the lot.
Absolutely no issues at all, nor has it ever had any issues. Never had a check engine light on.
No major work has ever been done. Only the regular maintenance (oil changes, tune ups, coolant flush..), although I did just replace the strut mount lat summer.
original timing chain.
2008 G8 V6: Eibach lowering springs, 18" staggered rims, K&N CAI, Series 4400 Flow Master axle backs with FlowMaster tips, radiator cover, tinted tails, silhouette of G8 third brake light.
mrathell is offline
post #16 of 19 (permalink) Old 02-15-2016, 09:21 PM
KNTRDR's Avatar
Yeah the 401 is not kind to any car. I know your pain lol
In response to the original poster, sitting at about 149,100km right now, probably about half-to-three quarters of the way through its second set of brakes, a little salty, needs a wash, and I've been trying to track down a phantom coolant leak that I can't see but I could smell, but I think thanks to some dye I've finally narrowed it down to being the pressure cap. Waiting for one to come in...no dealership in Canada had it so it's being shipped in from Tenessee. Go figure. Also, the driver's side dashboard knee panel started falling off recently and I had to fight it to get it back together. It is now reasonably secure. Mechanically sound in all other respects.
Adam (KNTRDR)
Burlington, ON
2009 G8 V6
KNTRDR is offline
post #17 of 19 (permalink) Old 02-17-2016, 03:57 PM
Will go with AC Delco parts thru dealership, use my kids discount.
Had the car in today, brakes had lots of life left in them, had them cleaned up and was told: Gee Dad....maybe if you slowed down.....
Oil changed today at 170,006km with Mobil 1 5W30 synthetic, oil had 7500km on, it was good for another 2500km according to the car but I had time today.
Had tranny fluid level checked, had to replace the drain plug that was siezed.
Replaced 2 burned out marker lights.
Good to go for another 7500km.
Next major expence new Michelin's probably A/S'3.
post #18 of 19 (permalink) Old 02-17-2016, 04:10 PM
I had the same problem with an off/on coolant leak, could smell it but couldn't see it. Once and awhile found a puddle of coolant on garage floor.
Check right rear of engine where coolant lines go over valve cover, my lines rubbed against the valve cover causing a pin hole leak in one line.
New lines have a bend in them routing off the valve cover.
If problem persists after changing pressure cap check this.
Good luck
post #19 of 19 (permalink) Old 02-19-2016, 09:57 PM
KNTRDR's Avatar
Good luck
I will, thanks. So far it seems like the cap is doing its job. One day I did find 2 drips but they were under where the front of the engine would be. I had remembered your post about the friction damaging those hoses and so I put UV dye in and checked them first (I think maybe mine are a revised version?) and then all around the engine and the engine compartment from both above and below (using a proper UV light and all) - nothing.
The only reason I found what I found around the radiator cap is because I had spilled some dye when I was putting it in (then I tried to rinse it away, forgetting what the dye was for, and made a huuuuuge green lake in my work parking lot) and later on I took it all to a wash bay and completely rinsed it down. Two days later, I was still smelling coolant but not seeing anything anywhere, so I did another UV light search and found nothing again...but then I noticed that around the cap (where I had been careful to completely hose away all traces of the dye) were more traces of the dye itself with no coolant left (had all burnt off, hence the odour I'm sure) leaving some crusty red stains.
I ordered a new cap (had to come from Tennessee...not one dealership in Canada had it, per the parts guy at Leggat Chev in Burlington) and when I put it on, I noticed that both the rubber seals on the old one looked very flattened out or squished; and also, there was a large amount of coolant present in the outer shell of the cap where it shouldn't ever get (the spinning part that threads onto the water outlet, but is above where the seals are so it never sees coolant). It seems reasonable that a radiator cap would start to crap out after 7 years...I seem to recall the old-fashioned ones would need replacing periodically, so why not these apparently rare, fancy-pants ones as well? LOL
It's been a few days now and I'm not noticing anything so far. There's no odour of coolant (I could smell it when I was exiting the driver's door, didn't even have to be close) unless I get right up near to coolant components and put my nose within inches of them (i.e. hoses, pressure cap, the overflow tank) and even at that range it is extremely faint; so, I'm THINKING I got it right. I'm going to go another few weeks and see how it goes. Then I have to decide if I want to flush the system for the second time within 15,000km (wish this happened BEFORE I had the coolant flushed) to get the dye out.
Adam (KNTRDR)
Burlington, ON
2009 G8 V6
KNTRDR is offline
