Noise when shutting engine off - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 13 (permalink) Old 11-23-2014, 12:13 PM Thread Starter
I'm experiencing a brief high pitch squeak like noise when turning car off. Anyone experienced this that can shed light? Could it be tied into the current ignition recall? A starter issue? Although does not seem to do it when turning car over. It seems to be coming from within firewall or right in steering column.
TAMan is offline
post #2 of 13 (permalink) Old 11-23-2014, 01:45 PM
'Mod'erator
The Yeti's Avatar
Can you try to capture the audio so we can get a better idea of the sound you are hearing. Use your remote start if possible. The remote start will only work with the hood down I believe.
LSA, Pat G DOD cam, RCR TB, 4.5IN Intake/MAF,
CNC LS3 Heads, OBX,
H&Rs, Konis, BMR, Brembos, Slotted/Drilled Rotors
3.27 Gears, 2600 Stall, ZL1 pump, Ice tank
Tuned By Pat G and Luis at RPM Speed Center
Bolt ons Street tires
[email protected] 60ft 1.96 Da 700ft
Cam no stall Street tires
[email protected] 60ft 1.75 Da -200
Stall
[email protected] 60ft 1.66 DA 400ft
Zex 125shot
[email protected] 60ft 1.83 DA 2000ft
second gear launch
LSA 1/4???
The Yeti is offline
post #3 of 13 (permalink) Old 11-23-2014, 03:07 PM
Going under the theory that this has just started to happen, you could try these things. >>>>> There's a chance it's due to your cabin blower fan causing the squeak (at ignition off time), you could pull the FU9-40A (HVAC/BLWR) fuse in the underhood fuse box (to prevent it from running) to see if anything changes. If no help, you could start the engine with the hood open, and having a friend shut the engine off, *you* could then be in a position to see if it's due to something in the engine compartment.
post #4 of 13 (permalink) Old 11-23-2014, 05:25 PM
Now it's a Party
SpeedRacerX's Avatar
Mine is doing this intermittently too. I'm wondering if it's a belt or pulley or ac compressor. Is your compressor sounding extra loud lately or groaning?
2009 GT, Kooks 1-7/8 Mids, RPM Tune, Borla, Vararam, HSRK, P&P TB, UPR CCan, Mobil 1, Speedhut Gauges, FE3, Whiteline, Pedders, Summer MRR on 255/295, Winter Beyern on 245, CTS-V Fr Brembos, SS Rotors, Akebono Pads, Rolled/Pulled Fndrs, BMR Sways, Spohn Links & Arms, Sprt Pedals, Pont Shifter, Camaro Trans Pan, Pont Mats, Glove Box Light, MSM Lower Grills, CF Tail, GXP Diff, VG Fin, 20% Tint, 6000K HIDs, LED Fogs, GrafxWerks, Black Trim/Mirrors/Grills, Diffusr Lens/Amber Lens/Lowr Tails Tint
SpeedRacerX is offline
post #5 of 13 (permalink) Old 11-23-2014, 06:42 PM Thread Starter
Don't believe it's quite loud enough to catch with audio. Will try the fuse suggestion, although already had someone listen with hood open, and definitely sounds like on the driver side, whereas the cabin blower is on the passenger side. We'll see, thanks.
TAMan is offline
post #6 of 13 (permalink) Old 11-23-2014, 10:02 PM
Matt G8 Dude's Avatar
Mine has been making the high pitch noise since the day I purchased it. I don't know what is causing the noise but after a minute of the car being turned off it eventually stops.
The best way I could describe the noise is it's like the high pitch sound some of the old tube TV's would make when they were turned on and you had the audio muted.
Never really thought of it as a problem.
Matt G8 Dude is offline
post #7 of 13 (permalink) Old 11-24-2014, 08:12 AM Thread Starter
That is something different, but I know what you are talking about. That has something to do with the car computer or whatever once car is off. This is just a brief noise as the key turns to off position.
TAMan is offline
post #8 of 13 (permalink) Old 11-24-2014, 08:37 AM
Pull your "accessory delay" relay fuse, see if that changes anything.
"Opinions expressed are solely my own and do not express the views or opinions of my employer."
2009 G8 GT - Self Built - Kooks 1 7/8" LT, Catted connection Pipes, Corsa Cat Back Exhaust, VCM OTR, LS7 MAF, Custom Cam w/ DoD Delete, Ferrea L92 Hollow Stem Intake Valves, PSI 1511ML Valve Springs, LS7 Lifters, Cometic .040" Head Gaskets, Cloyes Hex-a-Just timing gear, 7.350" Comp Cams Magnum Pushrods, Flycut Pistons, 11.45:1 Compression, HP/TQ TBD, Pat G tuned.
G8One2 is offline
post #9 of 13 (permalink) Old 11-24-2014, 10:43 AM
sounds like tpms Sensors
gmpontiacguy is offline
post #10 of 13 (permalink) Old 11-24-2014, 01:05 PM
Yeah, mine does it too. I think it's whining about being stuck in the garage when it wants to be out playing on the road.
Gone but not forgotten: 2009 Pontiac G8 GT, White Hot, Premium, Sport. Tune is "Down Under" by Men At Work.
WhiteHotG8GT is offline
post #11 of 13 (permalink) Old 11-29-2014, 09:16 AM
Thawk's Avatar
That is the trans control module, TCM, it makes a high pitched noise, its inside the trans, ans is normal, some are louder than others
2009.5 G8 GT Maverick Silver;Sport/Prem. SunRoof. Nav kit, Vararam,Holden badge kit,Kooks 1 7/8" Headers, VMS Tuned
2009 White Hot G8 GT;Onyx/Red,Sport/Prem,SunRoof, Nav kit,Holden badges,VMS Tuned,Kooks 1 7/8 Headers, Maggie TVS1900, Injection is Great but i love being Blown !
2001 Trans Am WS6 NBM/Camel, 6Spd 21K Miles
2001 G/P GT
When The People Finally Lead,The Leaders Will Follow
Thawk is offline
post #12 of 13 (permalink) Old 02-28-2015, 07:53 AM
It's the Throttle Body that you're describing. 100% sure. If the car is just sitting around it will do it too. And the center caps will click. This car is always begging for attention.
2008 Pontiac G8 | LY7 V6 | 6L50 AT Conversion | 3.45 LSD Rear Differential | Panther Black Metallic | GT Tail Lamps | Red Leather Seats | GXP Rear Diffuser
1957 Oldsmobile 98 | 371 Rocket V8 | J2 3x2 Tri Power| Jetaway Dual Coupling Hydra-Matic | Sierra Gold | Magnaflow Dual Exhaust | Autronic Eye
kgenesse is offline
post #13 of 13 (permalink) Old 03-01-2015, 01:24 PM
G8 Redux's Avatar
also consider that the fuel pump will depressurize the system when the car is shut off
Panther Black 09
~20% tint, GXP Diffuser, Costar Bluetooth, K&N Intake~
G8 Redux is offline
