6 speed swap from camaro, with Acadia PCM? - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 2 (permalink) Old 03-08-2013, 09:40 PM Thread Starter
I love my v6 and have been doing mostly suspension upgrades...but been wondering about doing a 6 speed swap for awhile. The 08 Acadia with the same LY7 came with a 6 speed. Any thoughts on if that PCM could be used if the 6 speed from a camaro is used? There probably will be some differences in the wiring that would need worked out...any thoughts? BCM compatibility issues between Acadia and G8?
GJD5 is online now
post #2 of 2 (permalink) Old 03-09-2013, 03:42 PM
The Acadia is a front wheel drive platform, and therefore has no compatability with the RWD Zeta architecture of the G8. The Acadia uses the 6T70 automatic, "T" meaning transversely mounted.
The 6L50, found in the ATS, CTS, STS, SRX, and Camaro is the transmission that bolts up to the LY7 V6 block in a G8. I am actually undergoing this conversion as we speak. Some things are a nightmare, but im working to get it all straightened out. You can see my thread here:
https://www.g8board.com/forums/showthread.php?t=68017
2008 Pontiac G8 | LY7 V6 | 6L50 AT Conversion | 3.45 LSD Rear Differential | Panther Black Metallic | GT Tail Lamps | Red Leather Seats | GXP Rear Diffuser
1957 Oldsmobile 98 | 371 Rocket V8 | J2 3x2 Tri Power| Jetaway Dual Coupling Hydra-Matic | Sierra Gold | Magnaflow Dual Exhaust | Autronic Eye
kgenesse is offline
