Check Engine After Catch Can Install??? - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 7 (permalink) Old 02-14-2014, 12:32 PM Thread Starter
The Right Kind Of Wrong
I installed my oil catch can 2 weeks ago and after the install the check engine light came on. I scanned it recently and these are the codes that came on
P0174
P1071
P0300
Any reason why these would come on after a catch can install?
White 2009 G8 GT 6.0
Current Mods - 20% Window Tint, Roto-Fab Intake, BBK Shorty Headers, Roto-Fab Engine Covers, Corsa Catback Exhaust, Viper 5904 Remote start & Alarm with GPS Smart Start. GXP Rear Diffuser. Custom double din with Pioneer Avic 940 Unit with Folick Controller. Custom Box with JL Audio 8W7, Escort 9500(Red) Radar with Blend mount, 19 inch Flat Black MRR GT7 Wheels, Cross drilled & Slotted Rotors/Ceramic pads.
Future Mods - Cams, Brembro Brakes, Solo High flow Cat
fedcop007 is offline
post #2 of 7 (permalink) Old 02-14-2014, 02:04 PM
Aaron407's Avatar
The first two are lean codes, and the last one is a misfire code. There's likely a vacuum leak at one of the connections. Presuming that you installed the one end to the driver side valve cover rear hose barb and the other end to the intake manifold hose barb near the the MAP sensor and EVAP solenoid, then it's probably a bad connection or a leak at the catch can. If they're all installed and tight, there should be no leakage. However, just to confirm, you aren't trying to use a catch can with a breather, are you?
2009 PBM G8 GT
TVS 1900 Maggie w/2.8" pulley (9-10 PSI), Maximizer LTs, High Flow Cats, LS9 injectors, Rotofab CAI, LC-2 WB, 40A KB BAP, TR6ix plugs, self tuned [250+ flashes], Camaro Paddle Shifters, UPR catch can, 4300k HIDs, Remote Start Heated Seat Control Module , Aeroforce Interceptor Gauge, JBL GTO628's, JL 8w3v3's w/JBL P180.2, Bridgestone RE-11 tires
Aaron407 is offline
post #3 of 7 (permalink) Old 02-14-2014, 11:10 PM
JonRobbinSS's Avatar
Assuming you have a sealed catch can - many people leave the drain in the open position mistakenly.. The screw type is closed when the screw thread is showing the most, opposite what would seem normal.
09 SRM GXP M6 Onyx VIN# 208718
#13 of 1829 GXPs
#2 of 171 SRM GXPs
Consolidated list of Mods to the car
JonRobbinSS is offline
post #4 of 7 (permalink) Old 02-17-2014, 10:35 AM
Car RamRod
todds87ss's Avatar
Good tips, so far. With a lean code, you should be able to HEAR the air sucking in. That will help you track down the leaking location.
You can choose to be anything you want on the internet...why choose to be so stupid!
todds87ss is offline
post #5 of 7 (permalink) Old 02-17-2014, 11:52 AM
HPT Pro Tuner
bluegoat06's Avatar
Interesting codes to be related to the catch can, a leak that big that could cause lean codes should be fairly noticeable in you engine bay. What type of catch can was this ?
and like somebody else said, make sure your drain is fully closed, you should be able to hear the hissing if it was that bad, if this fails, put the stock hose back in the PCV and intake tract, disconnect the battery for about 2 minutes or so, then take her for a drive and see if you can replicate the issue.
2012 Mustang GT, M6, 3.73's, Base/Brembo Package
3" H Pipe/Stock cats, Res!/3" pipes, Magnaflow 14419's AB, UPR Catch Can
HPTuners Pro v2.25 | Street Tuned
2010 Silverado 1500 LT Crew 5.3L
Magnaflow 14619, K&N Drop Filter, Airraid MIT, UPR Catch Can, American Outlaw Deputy 17x9, BFG 285/70/17 TKO, Bilstein 5100's
Hptuners 2.24 Pro / Street Tuned
bluegoat06 is offline
post #6 of 7 (permalink) Old 02-17-2014, 12:50 PM Thread Starter
Problem solved everyone all the lines were tight and finally it was a drain plug that was exposed underneath the catch can that I didn't see lol. I found the screw that came with it to close it cleared the code problem solved. Sometimes it's something so stupid. Thanks for all your help guys
post #7 of 7 (permalink) Old 04-21-2019, 11:12 AM
rockinlespaul's Avatar
This just happened to me also. I'll check for leaks, and the drain plug.
rockinlespaul is online now
