G8 GT Howling Noise @ 33-38mph (VIDEO) - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 22 (permalink) Old 01-16-2019, 09:09 AM Thread Starter
bics56's Avatar
My G8 has been making a easily noticeable howling or humming like noise when going about 33-38mph. Once I hit about 39mph it will abruptly stop. It does not matter if I am coasting, accelerating, braking...it seems the only constant is the mph range. I did notice that once I drive a few miles the sound either goes away or is less obvious. I kind of want to assume something with coldness is a factor, it is colder up where I live and I think it is more noticeable now, however I then think how it may have increased since this started a few months ago and maybe it is simply getting progressively worse. I posted a video below, watch the speedometer and you can hear it start around 33mph and abruptly stop at 39mph. I obviously assumed wheel bearing or some sort of differential issue...wanted to post here to see what you guys thought. Any insight would be appreciated.
2008 Ignition Orange GT
Bone Stock
1999 Red WS.6
MTI Lid, Borla Catback
bics56 is offline
post #2 of 22 (permalink) Old 01-16-2019, 10:16 AM
ekt8750's Avatar
A bearing would be a more of a growling sound coming from whichever is the offending wheel is and it would get louder at much higher speeds, it would never drop out.
2009 SRM G8 GT w/ Premium Package
Current Mods:
Solo Axle Back Exhaust w 3.5 Tips + GXP Rear Diffuser
Planned Mods:
Replace all incandescent lighting with LED bulbs | Roto Fab CAI | Spyder Black Projector Headlights w/ LED DRL Bar | Holden iQ radio conversion | HSV Steering Wheel | Pypes LT Tri Y Headers
ekt8750 is online now
post #3 of 22 (permalink) Old 01-16-2019, 10:19 AM Thread Starter
bics56's Avatar
Yeah I thought that...so I have it in my head maybe the differential???
Bone Stock
1999 Red WS.6
bics56 is offline
post #4 of 22 (permalink) Old 01-16-2019, 01:23 PM
ebg8gt's Avatar
My guess is torque converter. I believe in stock form it will lock at ~40 (or 39) mph under light load. Would explain the sudden drop out of the sound. And it's coinciding with the drop in RPM.
The converter won't lock at all if the trans is under 105 degrees. Perhaps test this when the car is cold.
2009 PBM GT
Under the Knife Again
Wiseco Pistons, K1 Rods, Johnson Lifters, BLP Keep Hatin' PDS Cam, Roto-Fab, BLP Ported Intake and Throttle Body, Kooks 1-7/8 long tubes, XForce Varex Catback, ZL1 Converter, Camaro Trans Pan/Filter, GXP Brembos
Breyton GTS-AV Wheels, 6k HIDs, Holden Steering Wheel and Paddle Shifters, Eibach Springs, 35% Tint
Tuned by Day Tuning
ebg8gt is offline
post #5 of 22 (permalink) Old 01-16-2019, 01:42 PM
When stating that it happens even when coasting, is the car still in drive ? Thinking (to myself) what might happen if the car was at say 45mph, an you bumped the stick to neutral, foot off the gas, and let the car slow down thru that speed range. If the outcome changes (I wouldn't know why), but others might then have a T/S game plan for you on this.
post #6 of 22 (permalink) Old 01-16-2019, 01:47 PM
Steve R's Avatar
Mine started to make a noise somewhat like that at 35ish and 65ish turned out to be a bad transmission mount.might be be worth checking it out.
ebg8gt likes this.
Steve R is offline
post #7 of 22 (permalink) Old 01-16-2019, 02:36 PM Thread Starter
bics56's Avatar
Ok that is a good idea to try it in neutral. SO what does that tell me if it still does it or doesn't do it then?
Bone Stock
1999 Red WS.6
bics56 is offline
post #8 of 22 (permalink) Old 01-17-2019, 07:13 AM Thread Starter
bics56's Avatar
Ok I put it in neutral and it made no difference, still made the noise at that mph range. It appears the the rpm range has no effect.
Bone Stock
1999 Red WS.6
bics56 is offline
post #9 of 22 (permalink) Old 01-17-2019, 07:25 AM Thread Starter
bics56's Avatar
Did it only appear at certain mph ranges like mine? I have noticed anything at higher speeds.
Bone Stock
1999 Red WS.6
bics56 is offline
post #10 of 22 (permalink) Old 01-17-2019, 11:21 AM
Steve R's Avatar
It appeared in the mid 30s and the mid 60s it was a little louder in the 30s
Steve R is offline
post #11 of 22 (permalink) Old 01-17-2019, 12:27 PM Thread Starter
bics56's Avatar
Does it matter if it was in neutral or not? Mine makes the same exact sound no matter what....RPM have no impact on the sound, only MPH
Bone Stock
1999 Red WS.6
bics56 is offline
post #12 of 22 (permalink) Old 01-17-2019, 04:57 PM
Steve R's Avatar
Only in Gear but mine is an auto so symptoms on a standard my present differently.
Steve R is offline
post #13 of 22 (permalink) Old 01-17-2019, 04:58 PM
Steve R's Avatar
Something I just though of from working on my 6 speed Cobra, a bad Throw-out bearing might make that noise .
Steve R is offline
post #14 of 22 (permalink) Old 01-17-2019, 08:20 PM Thread Starter
bics56's Avatar
Just curious why are we talking about manual transmissions? All G8 GT are automatic transmission
Sent from my Pixel 2 using Tapatalk
Bone Stock
1999 Red WS.6
bics56 is offline
post #15 of 22 (permalink) Old 01-17-2019, 08:45 PM
Steve R's Avatar
[QUOTE=bics56;3668385]Just curious why are we talking about manual transmissions? All G8 GT are automatic transmission
Because old men like me are sometimes forgetful !
bics56 likes this.
Steve R is offline
post #16 of 22 (permalink) Old 01-18-2019, 03:45 PM
Any chance the sound became noticeable around the same time you got that driveshaft center bearing replaced ? Wouldn't think that it would have any chance of causing the sound, Butttt. If it started prior to that, how bout something around the TB ducting/tubing connections, from the cleaning job you performed prior to that ?
post #17 of 22 (permalink) Old 01-18-2019, 04:13 PM
LS2 slut
NU13's Avatar
What sort of tires do you have on the G8? I had a terrible set of Ling Longs on my old car when i picked it up from the car yard. Made a terrible howling noise till i hit about 75kmh (i think thats about 40mph). Put new tires on her and the noise was gone.
HSV 2007 GTS
Suspension
- MRC compliant Pedders Sportsryder lowering springs
Engine
- VCM OTR cold air intake
- VCM 884 forced induction friendly cam
- Uprated springs & rods
- Harrop HTV1900 supercharger
- Defillipo 2.5 extractors and exhaust
- Deleted catalytic converts
- Harman Bros. Racing custom retune
Interior
- G8 designs HVAC and fitting kit
- JVC double din touch screen headunit
- JVC 800w amp
- JVC speakers and crossovers
660hp
NU13 is offline
post #18 of 22 (permalink) Old 01-23-2019, 11:38 AM Thread Starter
bics56's Avatar
I guess the center bearing could be a possibility. I don't recall it starting directly after that was replaced. Also would it matter with it being in neutral? The TB cleaning I doubt is a possibility, it was a while ago and didn't notice it at all until quite sometime afterwards.
I have on my winter tires which are Blizzaks...had them on last year with no issues.
It is weird the sound doesnt start until like 27mph (real faint) for like one second...goes away then comes back at like 33mph and goes away at like 38ish. It is like it is a light switch at those mph. Nothing alters it at all like revving it in neutral, braking, accelerating, etc. It seems like it is strictly that mph range. I have been reading that a transmission mount causes similar issues. I looked and that seems like it is a $30-40 part and easy to change out. Has anyone changed one on these cars?
Bone Stock
1999 Red WS.6
bics56 is offline
post #19 of 22 (permalink) Old 01-23-2019, 12:25 PM
post #20 of 22 (permalink) Old 01-23-2019, 01:35 PM
Does it happen when the car is in manual mode? I have seen AFM cause weird vibrations when the original motor mounts are still installed, an updated mount should address that issue.
2009.1 MGM G8 GT-sport/prem/sunroof
Way too many mods to list!!
wolfman1192 is offline
