2009 steering wheel audio controls broke - Pontiac G8 Forum: G8 Forums - G8Board.com
  • 1 Post By move-over
post #1 of 5 (permalink) Old 04-13-2019, 08:02 PM Thread Starter
Hello,
Ever since my 09 was shipped across the ocean to Guam, my steering wheel audio controls are all screwy. Every turn of the wheel adjusts the volume and seeks up and down my presets. Has anyone experienced anything similar or know of a solution? Thank you so much!
GuamG8 is offline
post #2 of 5 (permalink) Old 04-13-2019, 09:20 PM
Does this mean, everything else that the steering wheel controls are supposed to do or asked to do, works correctly ? If you were to just sit in the car an turn on the radio, both scroll wheels work as they should ( left wheel preset select change an the right wheel up/down volume + mute when pressed ? If both wheels feel good when put in to use, it sounds like you may be forced to remove the steering wheel to verify the condition of the wire runs thru the wheel. If that seems to be OK, it could be a problem with the coiled wire loom within the steering column (clock spring)
post #3 of 5 (permalink) Old 04-13-2019, 09:29 PM Thread Starter
Yes everything works perfect while the the car is running and I'm not turning. The controls do as they are intended to do. Only upon turning the wheel do I experience these issues. Music and calls are no longer possible until fixed. Thank you for the reply.
GuamG8 is offline
post #4 of 5 (permalink) Old 04-13-2019, 10:12 PM
Mine did that when the clockspring went bad. I have a thread from a few years ago.
2009 SRM GT - Premium, Sport, Sunroof - HSV triple gauges and trim, HSV Supersport Red/Black Steering Wheel, GXP rear sway bar, GXP Diffuser, Rotofab, SOLO Axlebacks, Magnaflow Cats, Red Hot shift knob, Autodim mirror, Removed intake cover, Chrome lug nut covers, Infinity door speakers, 10" DVC RF Sub, Switchbacks, Slotted rotors & Braided stainless brake hoses, Cortex tuner
Admin: www.pontiacbonnevilleclub.com
J Wikoff is offline
post #5 of 5 (permalink) Old 04-14-2019, 02:11 PM
out front & pulling away
move-over's Avatar
Hello GuamG8, Good luck with audio control issues. A G8 in Guam is probably the most remote place a G8 is. If you have time /energy post a photo or two. I'd imagine miles won't go up too much.
[SIGPIC][/SIGPIC]2009 GT, WH, SPORT/PREM, W/SUNROOF, CARGO LINER, CUSTOM- FITTED SUNSHADE, SONY GPS. LED REAR LICENSE PLATE LIGHTS. STOCK ENGINE COVER REMOVED. FULL-SIZE FACTORY SPARE W/ PACE PERFORMANCE TIRE-CHANGE KIT, Diode dynamics SL1 led lowbeams, XPEL HEADLIGHT PROTECTORS, CALIFORNIA CUSTOM EXTREMEWEAVE CAR COVER, RACERAMP FLATSTOPPERS, REDLINE ARMREST COVER, LED REVERSE LIGHTS, LED FOGLIGHTS, NO PERFORMANCE MODS FOR NOW. MAYBE SOMEDAY I'LL JUST GET A 480HP CRATE MOTOR FROM GMPERFORMANCE.
move-over is offline
WTB: 09 Silver steering wheel controls for a leather wheel J Wikoff Wanted to Buy / Trade 5 04-19-2016 08:49 PM
Piece broke off sport steering wheel xobrian Appearance / Detailing 8 06-20-2013 08:16 PM
Blaupunkt / Steering Wheel Controls Zekeman2299 Stereo / Electronics 1 07-15-2009 08:21 AM
Steering Wheel Radio Controls GM part number? tosspint Stereo / Electronics 0 05-11-2009 06:10 PM
Steering Wheel Controls Question fatback Stereo / Electronics 1 04-20-2008 08:58 PM
