Stall size - Pontiac G8 Forum: G8 Forums - G8Board.com
  • 1 Post By STAGEUP
post #1 of 14 (permalink) Old 06-10-2016, 11:54 AM Thread Starter
Stall size
Anyone using a 3800-4k stall in their g8? I currently have a 3200 yank but I keep wanting a bigger stall.
97camaro383 is offline
post #2 of 14 (permalink) Old 06-10-2016, 01:04 PM
Morris's Avatar
And here I was, asking a buddy just last night if he thought a 3200 too big. Is this going on a DD?
Morris is offline
post #3 of 14 (permalink) Old 06-10-2016, 02:52 PM Thread Starter
Its not a DD, more of a weekend warrior. However, it could very easily be a DD. Most people don't even know its stalled.
My old Trans Am had a yank 3600ss and I always wanted to re-stall it to the 4000ss.
post #4 of 14 (permalink) Old 06-10-2016, 09:14 PM
L_Alvis's Avatar
I also have a 3200 and drive it pretty much daily. MPG didn't take that much of a hit and it doesn't really affect my normal driving style either.
L_Alvis is offline
post #5 of 14 (permalink) Old 06-13-2016, 12:55 PM
Morris's Avatar
thanks for the info guys, I'll probably go with the 3200 then or slightly smaller if I find one.
Morris is offline
post #6 of 14 (permalink) Old 06-14-2016, 10:22 AM Thread Starter
go with the 3200 and you'll be happy.
post #7 of 14 (permalink) Old 06-14-2016, 10:23 AM Thread Starter
I'm really surprised nobody has info on larger stalls for the g8s.
post #8 of 14 (permalink) Old 04-10-2019, 08:31 PM
PerDiemG8's Avatar
Any updates on guys with bigger stalls? Currently looking for more info on the bigger stalls
PerDiemG8 is offline
post #9 of 14 (permalink) Old 04-11-2019, 09:25 AM
I've dealt with MANY different stall speeds and converters in 6l80/90s. I wouldn't go any higher than a tight 3600, or a loose 3200. The biggest challenge I've seen for a DD 6l80/90 car is trying to keep the transmission cool enough to where it won't kill itself with high transmission temps. You can probably get away with a loose 3600 in a race car, but that's it. I would stay away from a loose 3600 or 4000 in a DD G8. You're going to lose reliability, and might lose trap speed if you don't buy a multi disk converter that you can lock up.
Keep your stalls at 2800-3200 in you daily driver 6l80/90. You'll be much happier. If you feel like you need more power down low, get some 3.29s, or a cam with a lower power curve.
Jova007200 likes this.
PBM G8 GXP M6-Self flex fuel tune,OBX LTs, Kooks A/B, Monster clutch, 3.45 gear,LSA S/C, cam, fuel system, stock block and stock heads, 12 PSI.
Best e.t 10.41/ best mph 138.7 Half Mile: 168.3 mph
2007 TBSS-Self tune, bolt ons [email protected], 1,560 D.A
1991 GMC Syclone- Self tune/catback [email protected], 4,200ft D.A
https://www.youtube.com/channel/UC0o...xsBDzFImcyBfeA
post #10 of 14 (permalink) Old 04-11-2019, 10:15 AM
PerDiemG8's Avatar
Ok thanks I have a small enough cam for the stock converter but you can tell it would be happier with a stall and I also have a 3.45 Camaro diff to put in. Still stay in the 2800-3200 range? I’m not to savvy on auto cars I’ve always had manuals so it’s pretty new to me.
post #11 of 14 (permalink) Old 04-11-2019, 11:15 AM
With the engine having a smaller cam, installing a higher stall is only going to shorten your power band. Unless you have a multi disk converter where you can lock it up, and extend your gear.
post #12 of 14 (permalink) Old 04-11-2019, 12:24 PM
PerDiemG8's Avatar
Yeah that makes since I appreciate the info.
post #13 of 14 (permalink) Old 04-14-2019, 09:50 PM
Super Moderator
DRUMSBH's Avatar
I run a 4500 speed triple disc in the car. Temps stay under 200f. It's borderline not street able, but doable. It gets driven to work here and there but not a DD at all.
Sent from my LG-LS993 using Tapatalk
08' Pontiac G8 GT PBM
[email protected] Rock Falls Raceway 10-11-14
N/A RCR car.
DRUMSBH is offline
post #14 of 14 (permalink) Old 04-15-2019, 08:33 PM
PerDiemG8's Avatar
Yeah mine is not a daily at all but I drive once or twice a week sometimes skip a week.
