Transmission Fluid differences - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 8 (permalink) Old 05-08-2019, 07:17 PM Thread Starter
Blowerwhore's Avatar
I know I know before I get yelled at for not searching but I did search and I can’t find the answer I’m looking for so basically there are two different Dexron IV versions Part number 88865601 dexron IV 10-9394 and part number 88861037 Dexron IV 10-9243. I am ready to do a transmission fluid change with my Camaro trans pan I haven’t bought fluid yet because I’m confused what do you guys recommend
Blowerwhore is offline
post #2 of 8 (permalink) Old 05-08-2019, 07:36 PM
I believe those simply reference the packaging. You'll notice a few different numbers. Two of them are Quart Size with different bottle designs, and another is a 5qt size (10-9395 and not listed here).
What is important is the Dexron VI chemical name. Castrol's Dexron VI fluid is a good choice as well.
You can search for a list of approved licenses on google. That license will be present on the bottle. It is a J# with 5 digits. For example, J-60318 is one particular license number.....
'09 PSM G8 GT - OPG Intake, DOD-Delete w/ Stage 1C 218/229 .600 Lift 117.5LSA, Kooks 1 7/8 Mids, Solo Axle-Back w/ X-Pipe, SuperPro Bushings (Front and Rear). BMR Sway Bars (Red)
Power: 400HP/392TQ
"If you want to criticize someone else's work, be sure that your own is in order first."
post #3 of 8 (permalink) Old 05-08-2019, 07:49 PM Thread Starter
what I noticed on the bottle one says full synthetic and one doesn’t. So is this true ? What should I get ?
post #4 of 8 (permalink) Old 05-08-2019, 08:22 PM
You're right; I overlooked that.
In all honesty, ATF fluids are designed to last a very long time whether they are blends or full synthetics. If you want to maximize that life then go with the Full Synthetic.
I used Castrol's Dex VI and it is a blend; I've no qualms with that at all.
Power: 400HP/392TQ
post #5 of 8 (permalink) Old 05-08-2019, 09:21 PM Thread Starter
for $3 more I got the full synthetic for the case
post #6 of 8 (permalink) Old 05-14-2019, 10:57 AM
I want to say that are transmission takes synthetic oil. I would not recommend using anything other then that. For one if you just drop your pan there will still be half the fluid inside the trans.
And if you saw a VI(6) series trans fluid listed as not synthetic I'd stay away from that brand. Series VI trans oil is supposed to be only a synthetic oil.
At least that's what I remember when looking into doing trans changes on mine and a friend's 30k ago.
I had bought mine from dealer as they were cheaper then local auto store. But that was 3 years ago.
09 Pontiac G8GT rebadge to a Holden VE SSv
Rotofab, 1-3/4 long tube w/ full KOOKS exhaust. VMS ecm/tcm tune. CTSV brake Upgrade. CTSV wheels 19x9 on all four.
07 350z Nismo, Stillen headers, injen long tube intake. Leather seats.
90 300zxTT Major build est 450hp on low boost, 650hp on high boost. 99 spec front end, have yet to install the wing and tails.
85 Rx7 12a street port with holley 565 est 190hp
keptman is offline
post #7 of 8 (permalink) Old 05-14-2019, 11:05 AM
Just for reference trans oil and the diff oil.
File Type: jpg 15578498048063951259866594688687_1557849850705.jpg (146.8 KB, 17 views)
keptman is offline
post #8 of 8 (permalink) Old 05-14-2019, 02:31 PM
To carry Dexron VI as a label it has to be a Blend or Better.
For Castrol to carry the label of Dexron VI on their Transmission Oil, it means they're using an approved blend according to the license.
Power: 400HP/392TQ
Trans fluid change fluid required? Fast4drss Drivetrain Tech 0 02-03-2014 07:29 PM
Transmission Fluid - Just Hope? ucbedge Drivetrain Tech 47 10-30-2013 10:46 AM
Transmission fluid check question g8ss V6 Engine Tech (LY7) 13 09-04-2009 07:23 AM
Transmission Fluid Change? liquidred Drivetrain Tech 9 03-09-2009 08:46 PM
** Needed ---> Transmission Fluid Cooler Outlet Pipe dmacchia Parts for Sale Archive 0 11-14-2008 02:03 PM
