3.27 gear swap - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 9 (permalink) Old 07-24-2019, 08:23 AM Thread Starter
3.27 gear swap
Considering a 3.27 gear swap, looking for advice and suggestions. From searching, looks like I need a 2010-2015 Camaro SS Automatic. Also I am going to need a tune. Thinking either to go to a local tuner and just have them edit that one part (cheap), or maybe a Livernois mail order 91 tune (expensive). No other mods except exhaust, none planned either. 89k miles and engine sounds healthy, but if I ever have a DoD failure I'll either just replace them with the newer lifters or go nuclear and swap in a crate LS3.
Is there anything I have to replace to get the Camaro diff to work? I don't want to upgrade any bushings while in there because I'm an NVH engineer and I hate NVH! Leave me with my sloppy rubber and my wheel hop, this is just a DD. I know I have to remove the rear knuckles to get the axles out- can do it without loosening any of the eccentric alignment bolts and get out without needing an alignment?
earlingy is offline
post #2 of 9 (permalink) Old 07-24-2019, 11:56 AM
slnecker's Avatar
I switched to the 3.27 years ago, if I had to do it over I would have gone with the 3.45 because I ended up going heads/cam etc but I do like the upgrade overall. You are correct 10-15 Camaro auto. Pat G is also a good option for a mail order tune, call a few and pick whomever you are most comfortable with.
I didn't replace any of the bushings and did not get an alignment. It was pretty straight forward from what I remember, I think it only took a few hours in the garage.
Good luck with the swap.
2009 MSM Sport/Premium, Kooks 1 7/8 Mids, Solo Mach Unbalanced, ,Vararam w/HSRK, RCR Drag Sportsman cam, ported heads/intake/TB, Yank SS3200, Pat G tune, 3.27, Elite Engineering catch can, UDP
slnecker is offline
post #3 of 9 (permalink) Old 07-24-2019, 12:02 PM
L78steve's Avatar
Its not a big deal to do. Remove the yoke and let hang with the shaft attached, First mark all the positions of the mount bolt washers with a sharpie for alignment purposes, pull the e-brake cables and sensor wires. The axles will require a good tug to dislodge the snap ring inside the diff. When I did mine it did not effect the alignment but it depends on how careful you are with your markings.
09 G8GT, LR,
70 Nova SS L78
"Knowledge Is Good"
Emil Fabor
L78steve is offline
post #4 of 9 (permalink) Old 07-24-2019, 03:31 PM
Two sources for the posi kits. Jannetty Racing or Camaro Central both sell posi kits with the Ford spring to pre-load the clutches. I like the Camaro central ones.
As for the diff bushings. before you install the diff. Fill the bushings voids with 3M windshield urethane. limits the movement without harshness.
'09 PBM GT. #2 Kook's Mids, Solo Mach balanced, SCT X4 Tuner. LED H/lamps, Tail lamps and Interior
GT Drew is online now
post #5 of 9 (permalink) Old 07-24-2019, 10:45 PM
Dousail2's Avatar
Ditto, If you are daily driving the car the 3.27 wakes it up on the street, but if you are looking for improved 1/4 mile times I actually ran slower after the swap as the 2.92's were making it through the 1/4 in the top of 3rd gear and the shift to 4th with the 3.27 actually lost me about a tenth of a second. DA and 60 foots were almost identical for the comparison runs. If looking for 1/4 mile improvement go to the 3.45.
Ken's 2009.1 Pontiac G8 GT Pacific Slate Metallic -Premium
Rotofab CAI, Kook's 1 3/4 LTs, HF Cats, 3" X-pipe, GXP Mufflers, PLX WB O2 & Aeroforce gauges
Rick C Manifold/TB/LS3 valves/Little Lunati/Tune, BTR Spring kit, many appearance mods
VMR Solar Rain V701 Staggered 19x9.5+50 & 19x8.5+35, Hankook V12 285/35 & 255/40
Stoptech, HPS, 12.27 sec 114.6 mph 1/4, 1.96 60ft
Put Jesus Christ in the drivers seat
Dousail2 is offline
post #6 of 9 (permalink) Old 07-25-2019, 08:34 AM Thread Starter
Yeah it would only be to make the car a little peppier. I've never been on a drag strip in my life! Only the occasional red light race
earlingy is offline
post #7 of 9 (permalink) Old 07-25-2019, 11:32 AM
L78steve's Avatar
Big difference in durability also.
09 G8GT, LR,
70 Nova SS L78
"Knowledge Is Good"
Emil Fabor
L78steve is offline
post #8 of 9 (permalink) Old 07-25-2019, 12:03 PM
every village has one
tchr49's Avatar
So easy a 70 yr old with jack stands can do it
e85 Surprise Package
tchr49 is offline
post #9 of 9 (permalink) Old Today, 01:40 PM
KW Baraka's Avatar
Originally Posted by earlingy View Post
Considering a 3.27 gear swap, looking for advice and suggestions.......
I have a complete 6K mile pumpkin out of my 2014 Chevy SS.
PM me if interested.
KW
1995 Impala SS --- Heads/Cam LS3 Conversion - 450/400 HP/TQ to the wheels - Race Results Pending
1996 Impala SS --- 398ci Solid Roller LT4
2014 Chevy SS --- 429ci LS3 - Post Break-in Dyno and Race Results Pending
KW Baraka is online now
