Steering wheel off after doff swap? - Pontiac G8 Forum: G8 Forums - G8Board.com
 3Likes
  • 1 Post By GOPHERIT
  • 1 Post By Jova007200
  • 1 Post By stromboli86
post #1 of 6 (permalink) Old 04-07-2019, 06:09 PM Thread Starter
Low society member
I did the 3.27 diff swap and had no need to touch front suspension/ steering components but my steering wheel is now off a bit too the right
when life gives you lemons , kick life in the grapes and get back to making lemonade.
Gettag8 is offline
post #2 of 6 (permalink) Old 04-07-2019, 07:35 PM
Do not really know what is generally disconnected in order to swap out that differential. I wonder, if enough of the rear suspension must be torn down/disconnected to allow for the install, could you accidentally create a rear wheel stagger (fore/aft dimension condition) upon reassembly. If that can/could happen, could that in turn influence how the front steering might react to correct any misalignment from the rear wheels.
Jova007200 likes this.
post #3 of 6 (permalink) Old 04-07-2019, 08:05 PM
Steve R's Avatar
Sounds like rear alignment issue to me as well .
Steve R is offline
post #4 of 6 (permalink) Old 04-08-2019, 07:29 PM Thread Starter
Low society member
Rear alignment doesnt affect steering wheel Though. Idk ill figure it out thanks anways
Gettag8 is offline
post #5 of 6 (permalink) Old 04-08-2019, 07:38 PM
Yes, rear alignment isn't connected to the steering wheel. Though, have you ever seen a car or truck in front of you with the rear end misaligned from the front?
If you removed the subframe to do the work, then reinstalling it using the guide pins should have aligned it within tolerance. The thrust angle (had to look that up because I forgot what it was called) in a case of misalignment to the right would be a positive discrepancy. To correct, your front wheels would need to steer to the same angle.
Your car goes straight, but is slightly off axis and traveling partially sideways.
Go to the shop and get an alignment check and they'll be able to correct it.
There's no way around it. Your rear end isn't aligned with the front end based on what you've said.
Test it in a parking lot. Drive in a straight line (wherever the wheel ends up being). Stop and get out of the car. Your front wheels should be straight. Any deviation should be noticeable.
It must be very slight.......
BMR Sales likes this.
'09 PSM G8 GT - OPG Intake, DOD-Delete w/ Stage 1C 218/229 .600 Lift 117.5LSA, Kooks 1 7/8 Mids, Solo Axle-Back w/ X-Pipe, SuperPro Bushings (Front and Rear). BMR Sway Bars (Red)
Power: 400HP/392TQ
"If you want to criticize someone else's work, be sure that your own is in order first."
post #6 of 6 (permalink) Old 04-13-2019, 07:52 PM
The vehicle will need a 4 wheel alignment. Front wheel alignment is based off of rear wheel straightness. When doing an alignment you must always do the rear adjustments first, once those are straight, then the true readings for the front are indicated.
If the wheel was straight before, chances are the machine will SAY the front is incorrect as well as the rear, but once the rear is corrected first there is a good chance the front numbers will move back to straight without even touching them.
And whether dropping the craddle or just unbolting a few control arms, once the tension on the arms and bushings are released by the bolts, things shift. The proper way to tighten suspension is to have load on the arm and bushing before fully tightening. Most dont do it because its a real pain on the ground!
Sent from my SM-G892A using Tapatalk
2009 Pontiac G8 GT
2009 Chevy Cobalt SS
1986 Buick Grand National
stromboli86 is offline
Steering Wheel Swap.. Custom Wrapped/Threaded GXP Wheel & Shift Knob LSX G8 Appearance / Detailing 18 12-28-2012 11:11 AM
FS: G8 GT Leather Black Steering Wheel, Steering Wheel Silver Inserts & Sidemarkers DJ_JonnyV Parts for Sale Archive 18 02-01-2011 10:58 PM
After turning off AFM would you get less performance after a long period of time??? desertg8 V8 Engine Tech (L76/LS3) 7 11-05-2009 09:50 PM
Steering Wheel Swap rolm4 Appearance / Detailing 2 03-12-2009 10:02 AM
Sport Pkg. Steering wheel vs. standard steering wheel pharden Lounge 17 03-11-2008 10:45 AM
