Question about front struts - Pontiac G8 Forum: G8 Forums - G8Board.com
  • 1 Post By whatnext
post #1 of 8 (permalink) Old 04-17-2019, 07:56 PM Thread Starter
gsx_sleeper's Avatar
My new H&R coilovers will be arriving in a few days, I thought I had read that the two large bolts (I think they are 19-22mm) holding the strut assembly are TTY (torque to yield). Hoping they arenít but if they are I will probably replace them 😊
Anyone know for sure?
#902 - 11/27/2008
2009 Stryker Blue GXP A6
11.737 @ 118.09 / 1.765 60'
Roto-Fab CAI / Kooks LT Headers & HF Cats / GXP Mufflers / Yank 3200 / P&P Heads /
Comp Cams 231/239 .617/.624 LSA 113.0 / Meth Injection / Dyno Tune
gsx_sleeper is offline
post #2 of 8 (permalink) Old 04-17-2019, 09:19 PM
Pontiac Crazy
yutzybrian's Avatar
According to the manual the torque is 63 ft-lbs -> 74 ft-lbs -> then 90 degrees, so they are most likely TTY. Reusing them isn't too big of a deal though, if it really was then they'd need to be replaced everytime the shop adjusted your camber with an alignment.
2009.5 G8 GXP SRM 6MT
-Kooks 1-7/8 LT, 3" Solo, RotoFab CAI, Full Zeta II suspension with BCs, Monster LT1-S & Tick Master Cylinder, 3.91 w/ TrueTrac
yutzybrian is offline
post #3 of 8 (permalink) Old 04-18-2019, 07:34 AM
Many of us have replaced struts (years ago) and re-used the bolts without any issues.
post #4 of 8 (permalink) Old 04-18-2019, 10:44 AM
ebg8gt's Avatar
I think it's the nuts that are supposed to be replaced. It's the same with some of them in back.
I reused all of mine. No issues.
2009 PBM GT
DOD-delete, BTR Stage 2 cam, Roto-Fab, BLP Ported Intake and Throttle Body, Kooks 1-7/8 long tubes, XForce Varex Catback, ZL1 Converter, Elite E2 Catch Can, HSRK, Camaro Trans Pan/Filter, GXP Brembos, Cold Case Radiator
Breyton GTS-AV Wheels, 6k HIDs, Holden Steering Wheel and Paddle Shifters, Eibach Springs, 35% Tint
Tuned by Day Tuning
ebg8gt is offline
post #5 of 8 (permalink) Old 04-18-2019, 02:12 PM
Its the bolt which is in tension that is the weak point in any bolted joint. Torque to yield is suppose to bring the bolt to the max load it can take without permanently stretching.
post #6 of 8 (permalink) Old 04-18-2019, 02:56 PM
ebg8gt's Avatar
I understand that, however, there are numerous places in the GM shop manual that say to "discard the nut(s)" and install new ones when working on the suspension, while retaining the original bolt.
For this specific example, it says: "Remove and discard the strut assembly to steering knuckle retaining bolts , nuts, and washers."
So, I was wrong on this one, but nevertheless reused all of them and had no issues.
2009 PBM GT
Tuned by Day Tuning
ebg8gt is offline
post #7 of 8 (permalink) Old 04-19-2019, 07:34 AM
There is nothing in a nut that is more structurally limiting than in the bolt (the bolt will always break first, be it the shaft or threads). So the shop manual says to dump some nuts but not the bolts is interesting. If there was a locking feature on the nuts then I can see where you don't want to re-use it.
post #8 of 8 (permalink) Old 04-19-2019, 07:29 PM Thread Starter
Thank you all for the responses !!
#902 - 11/27/2008
Stock Front Struts TheStevo Wanted to Buy / Trade 1 12-09-2012 02:22 PM
GXP shocks/struts vs. Pedders GSR shocks/struts StBlGT Suspension / Brakes 31 07-07-2012 03:50 AM
wtb oem front struts hayabusa160 Wanted to Buy / Trade 1 03-16-2010 10:59 AM
Air Swoosh from front struts SpyHunter Suspension / Brakes 3 04-30-2009 09:01 PM
Squeaking in the front struts.. johnh Suspension / Brakes 13 02-04-2009 10:48 AM
