Strut mounts: centered enough? - Pontiac G8 Forum: G8 Forums - G8Board.com
  • 1 Post By GXP25
  • 1 Post By GXP25
post #1 of 10 (permalink) Old 07-30-2019, 07:27 PM Thread Starter
Slowly gaining acceptance
Jimal's Avatar
Because there are few things in life I like more than taking apart my front suspension again...
I'm chasing a front end clunk over bumps. I'm probably just going to replace the control arms as a maintenance item at almost 130k miles, I'm trying to cover all my bases. The struts and mounts were done by me last year, so I'm not concerned about wear or damage, but I wonder if they're contributing to the noise anyway.
Driver's side
Passenger side
Neither is contacting their respective holes. Is it worth tearing into again to triple-check the clocking of the spring? I have to say the decision not to have a notch in the strut to orient the end of the spring is an odd choice.
Jimal is offline
post #2 of 10 (permalink) Old 07-31-2019, 09:53 AM
Driver's side
Passenger side
What strut mounts are those? Where are your top plates?
post #3 of 10 (permalink) Old 07-31-2019, 09:55 AM Thread Starter
Jimal's Avatar
Superpro Polyelasts.
I removed the top plates to inspect the orientation and take these pictures, per the FAQ.
Jimal is offline
post #4 of 10 (permalink) Old 07-31-2019, 10:07 AM
Makes sense now.
Jimal likes this.
post #5 of 10 (permalink) Old 07-31-2019, 10:31 AM
So to answer your question, they seem to be centered adequately, which would indicate that the upper spring plate arrow is correctly facing the engine bay.
It looks like you have a little positive caster (which is good).
Jimal likes this.
post #6 of 10 (permalink) Old 07-31-2019, 10:42 AM Thread Starter
Jimal's Avatar
That is what I was hoping to hear. I wasn't looking forward to having to pull the struts again in order to reorient things. I already did the drivers side twice after I spun the shaft in the strut and killed the seal the first time around.
Jimal is offline
post #7 of 10 (permalink) Old 08-06-2019, 10:00 AM
G8BLBYU's Avatar
Driver's side
Passenger side
If it helps, I recently had a front end clunk on the driver's side. It turned out to be the lower control arm. Had that replaced (came in two pieces) and no more clunk.
09 PBM G8GT Prem & Sport
PPV Struts
Tein Springs
DBA 4000 Series Slotted T3 Rotors
Hawk Performance Ceramic Brake Pads
GM & Pontiac Badge Delete
V8 6.0 Litre Emblems
Rear Mufflers Deleted (replaced with straight pipes)
01/09/10: Fontana - 13.187 @ 106.67 MPH (DA Corrected - 13.036 @ 107.91)
Mulholland run 4/19/09
G8BLBYU is offline
post #8 of 10 (permalink) Old 08-06-2019, 02:28 PM Thread Starter
Jimal's Avatar
Thanks. I have control arms and outer tie rods sitting in my garage, waiting for me to have time to put them in.
Jimal is offline
post #9 of 10 (permalink) Old 08-07-2019, 02:12 PM
What maker did you go with?
Jeff92se is offline
post #10 of 10 (permalink) Old 08-07-2019, 02:28 PM Thread Starter
Jimal's Avatar
Based on research here, I went with Mevotech. They were better than OEM, but not ridiculously expensive.
Jimal is offline
