Pontiac G8 Forum: G8 Forums - G8Board.com
Pontiac G8 Forum: G8 Forums - G8Board.com (https://www.g8board.com/forums/)
-   Suspension / Brakes (https://www.g8board.com/forums/7-suspension-brakes/)
-   -   Police brake pads, stock brakes (https://www.g8board.com/forums/7-suspension-brakes/283727-police-brake-pads-stock-brakes.html)
Turboner 04-30-2019 11:40 AM
Just quickly looking to improve performance of the stock brakes. Cruising Rock Auto i noticed bendix fleetmetloc and police specific brake pads. Does anyone have experience running these? I only care about performance and dust/rotor wear is not really a concern.
Current pads are ok, but car doesn't stop well, and ive changed the rotors so all calipers and sliders have been looked at.
GTRenegade911 05-01-2019 08:33 AM
Subscribed. Would like that info as well. I know Raybestos and AC Delco make Police components as well.
whatnext 05-01-2019 11:01 AM
Want to know also. The factory pads never had good initial bite.
Carbotech 1521s are written up here on the forums are so good that you have to change your braking style (for lack of a better term). But a set is over $300 so brake pads better than factory and pocket friendly would be nice.
MIEngineer 05-01-2019 01:06 PM
Police specific pads - police caliper is NOT the same.
Turboner 05-01-2019 02:06 PM
Lol ok so I guess ill be a guinea pig and try them. Ordered!!!
And yes i have stock GT BRAKES and there is a police formula pad from Bendix (rock auto).
I have read that 2014+ caprice ppv has dual piston and giant rotors, sub 2013 caprice has big rotor single piston. Info from rock auto and the internet so I could be wrong.
=D
Turboner 05-01-2019 02:15 PM
1 Attachment(s)
For everyone's reference
GTRenegade911 05-02-2019 06:09 AM
It's guaranteed fitment on RockAuto so I'm confident these pads will fit the G8 stock caliper. They were listed under the G8 GT components as well.
I may go with AC DELCO severe duty rotors + Hawk Pads. If I can get my hands on those damn rotors they are always out of stock.
Anyone heard good or bad things about the S GROOVE design?
executor999 05-02-2019 07:04 AM
Looks like AC Delco also makes a Police Performance front rotor and brake pads too.
GT and GXP
Rear Rotor
18A2662PV
Rear Brake Pads
17D1352MHPV
Rear Brake Pads, Revised Design
17D1352MHPVF1
Severe Duty Rotors
Front Rotor - GXP only
18A2937SD
Rear Rotor - GT and GXP
18A80724SD
GTRenegade911 05-02-2019 08:24 AM
All those parts listed are for the GXP. Does OP have a GT or GXP?
PONY MAN 05-02-2019 09:29 AM
Has the GT
GT Drew 05-02-2019 11:03 AM
Any brake pad brand that has 1351 for ft pads and 1352 in the rear pads part number will fit the stock GT calipers.
Turboner 05-02-2019 03:42 PM
Yes its just a GT. Previous owner I think put low end ceramics. I personally like the feel of semi-mets as well as cleaner rotors 😉
Turboner 05-03-2019 03:19 PM
3 Attachment(s)
Parts arrived
GTRenegade911 05-03-2019 08:58 PM
Tell us how they perform once installed. Maybe they are as good as Hawks...who knows.
Turboner 05-03-2019 09:06 PM
1 Attachment(s)
Not finished yet geeezze
GTRenegade911 05-03-2019 09:47 PM
How old are these rotors?
Turboner 05-03-2019 09:56 PM
Ok so after about a km of driving and bedding; half the pedal pressure starts the abs working. MUCH BETTER THAN WHATEVER CAME WITH THE CAR.
I highly recommend
About a month, why?
IVANG8 05-07-2019 07:18 PM
Upgrade your stock brakes
Use Hawk HPS pads, stainless brake lines and racing rated dot 4 brake fluid and you will be amazed at the difference. You need a scanner to cycle the ABS system to make sure you have replaced all the brake fluid when power bleeding the brake system. I am still using the stock rotors due to low mileage on my G8 GT
Turboner 05-07-2019 08:51 PM
Ive used both HAWK HPS and HP+ on my skyline. HPS are horrible when cold; almost went through a stop sign. HP+ on the other hand are fantastic(but very dusty and noisy); insane bite when cold and worked well on lapping days untill i boiled my DOT4 fluid. I changed to Bosch 5.1 and was fine the following lapping day
G8 got a four corner bleed with Bosch 5.1 the amazing thing is these BENDIX police pad feel identical to the HP+ unfortunately with the brake dust too. Just for fun I went to 180kph and then hard brake to 20kph, twice, no fade. (In Mexico)
Here's the thing
BENDIX:
$120 shipped front AND rear pads
HAWK HP+
$120 front
$120 rear
And bendix has been tested by the police. By all means go for hawk pads, we all know they are great, I just found what i believe is a cheap alternative
inov8rPPV 05-07-2019 10:18 PM
2 Attachment(s)
Originally Posted by Turboner (Post 3678141)
I have read that 2014+ caprice ppv has dual piston and giant rotors, sub 2013 caprice has big rotor single piston. Info from rock auto and the internet so I could be wrong. =D
PPV front brakes - 2011 to 2017 all the same:
- Rotor is 345mm x 30mm
- Caliper is single-piston floating design, uses a high-performance pad with Ferodo HP1000 friction material--same material spec as used on Brembo brakes found on G8 GXP & Chevy SS sedan.
Pad is FMSI D1404 spec.
Standard G8 rotor is 321mm--a good upgrade for G8 is fitting the full PPV front setup, or using the PPV 345 rotors with Brembo calipers from 2016/newer Camaro SS or CTS (calipers for 345mm rotors, direct bolt-on to sedans). For G8, caliper mount bolts require opening 12mm holes in knuckles/spindles to 14mm.
Full details - the key to any brake upgrade is a larger rotor, regardless of caliper design or number of pistons.
More info & photos - Caprice Forum
Photos below show couple of Camaro 345 Brembo (4-piston) calipers with 2 different paint schemes - also available in a Cadillac CTS version, with yet another paint job. These calipers can use either D1001 or D1474A pads, from CTS-V/G8 GXP or SS sedan. Both photos show D1474A pads--with D1001 pad, top surface of caliper is flush for wheel clearance on 18" wheels.
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
