Pontiac G8 Forum: G8 Forums - G8Board.com
Pontiac G8 Forum: G8 Forums - G8Board.com (https://www.g8board.com/forums/)
-   Drivetrain Tech (https://www.g8board.com/forums/6-drivetrain-tech/)
-   -   JRE dipstick with Camaro Trans pan come in (https://www.g8board.com/forums/6-drivetrain-tech/283849-jre-dipstick-camaro-trans-pan-come.html)
Blowerwhore 05-14-2019 07:25 PM
I followed the procedure on filling the transmission fluid, I opened the drain bolt while running in operating temps till fluid slowly started coming out but my JRE dipstick reads nothing on the stick I’m worried. It gets wet only when I slide the stick into tube from residual fluid in the tube from pouring in transmission fluid
lastcall190 05-15-2019 03:49 AM
Easiest way to answer that? Take off the pan, put the dipstick in, and see where it ends up in relation to the level-check port. That will shed some light on this I bet. Sucks to waste all that liquid gold but might as well cover all bases. I suppose you could just CAREFULLY lower the pan with all the fluid in it...
There's a discussion here that might shed some light or raise more questions:
https://www.newcaprice.com/forum/vie...t=821&start=20
-J
Blowerwhore 05-16-2019 08:28 AM
-J
thanks man tons of info in here with that thread. What I came up with... the trans fluid would sit in the dipstick tube at the bends and puddle up and slowly drip down so I would fill some fluid let all the fluid drip down than fire it up and check it. I got it all ironed out. Thanks man
saramoore673 05-16-2019 08:47 AM
Yeah man ... There is a lot of info that is related to the topic but if you have done something wrong, then you must have to go and search for a mechanic for your car.
lastcall190 05-16-2019 09:12 AM
Good to hear, and thanks for updating with what you yourself found.
-J
Blowerwhore 05-16-2019 11:27 AM
show me ... nothing related to pooling of trans fluid in the actual dipstick tube was discussed that I have found. Not my first rodeo bud.
MGMGXP 05-16-2019 02:14 PM
Pretty sure the dipstick is designed to read with the car off and the fluid in the pan. The fill procedure is done with the car running at normal temp, so there is very little fluid in the pan for the dipstick to register.
PONY MAN 05-16-2019 03:03 PM
Disregard post number four it's probably spam.
matts88yj 05-21-2019 01:48 PM
I've been looking to do the same Camaro pan and filter with the JRE dipstick. I take it you needed to add more fluid for it to show full on the dipstick and all is well?
GT Drew 05-29-2019 12:45 PM
Trans fluid is always checked with the engine running. If you at the stock level and it just runs out a bit with the pan bolt out. And you tube is flush with the trans like in the photo. Then you need to shorten the tube a bit so the dipstick goes in farther to reach the fluid
https://cdn.shopify.com/s/files/1/24...g?v=1510838587
Blowerwhore 05-29-2019 01:22 PM
thanks for the heads up. Should be tricky to cut it to be exact
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
