1 - 11 of 11 Posts
I just ordered mine and every where I have read abut this it says to get them coated. Is it really that beneficial? Is anyone using theres without a coating? If so have you had any issues?
Asking all this because I dont have anyone local to coat it. If I did do a diy coating what would be good to go with?
I plan to coat mine with the VHT header coating. Should help a little but not for sure yet. I might wait and run it without it at first just to see if it does help at all.
Thats what I was thinking is just go get some high temp paint and coat it.
I went with the wrinkle paint to get close to stock looking.
The VHT header coating looks close to stock ill upload some pictures of my headers now that one is coated. The wrinkle black does look good though hmmm. What to choose.
HeapBlaster
what are yall coating the MAF for?
Helps to keep the heat soak out. But if you have a HSRK its a wash.
Discussion Starter · #8 ·
With the vararam where did you guys get the 4" silicone pieces? Oreillys or autozone maybe?
sent you a pm.
Header paint will do nothing, other than change the apprearance. Paint has no heat reflecting qualities. It is not a ceramic thermal barrier like
Jet-hot or the others. If it comes out of a spray can, it's just paint.
anyone looked at the heatsoak differences between the Spectre piece and the hard plastic piece made by PowrMax?
1 - 11 of 11 Posts
