I'm going to be ordering some 17" Weld RT-S wheels for the rear in a few weeks(Ill order the fronts later this summer) and I "think" I've gotten the correct offset for the rear.
I've chosen a 17"x10" with a 44mm offset. What has me worried is that I've seen no one else run this setup. I know the fact that they are expensive may have something to do with it; not to mention that the 17" GTO setup works extremely well and is way cheaper.
Will this offset be correct?
Also, I haven't chosen the tire yet, but I'm leaning towards Hoosier 275/40 Drag Radials.
Also, as far as the fronts are concerned, I've chosen a 17"x5" rim with a 2.2 back spacing. Will I need to run a spacer up front for these?
I think I'm pretty close on the rears, but the fronts....I'm not so sure.
