Having some issues with the 175 Amp fuse under the hood. The fuse casing is riveted and doesn’t appear the fuse is serviceable. Goes from the left fender under the engine over to fuse box. I peeled all the tape off and the fuse is inside a rivited case. Every once and a while I have to jiggle it to get everything power up. when I loose power I tested each side of the fuse and it’s definitely a problem in the fuse. Thanks,
