1 - 9 of 9 Posts
Hello all, seeking feedback on what things I should be looking to do as my car comes up on 100,xxx miles.
Current mileage: 91,xxx
Mileage per year: 5k-7k
Normal maintenance: oil changes and alignments
Recent maintenance: serpentine belt, wheel bearings, new tires, new lighter fuses, fuel pump relay
This week it didn't turn over. After one failed jump and coughing over $200 to the dealership they said it was a blown fuel pump relay.
It got me thinking, what other maintenance should I be considering before I run into unexpected items?
Routine oil changes with both good quality oil and filter go quite along way. Recommend changing all fluids. A simple drain and refill will suffice as am not a proponent of flushes. Can always reference the owner's manual for scheduled maintenance suggestions. Have the front and rear suspension checked for worn items. Have the struts and strut mounts been replaced? Spark plugs and plug wires? Have a budget (if possible) set aside for unforeseen repairs and makes fixes as deemed necessary or appropriate.
Reactions: BAS G8
One thing I recommend that you DO NOT do. Don't chemically flush you cooling system. I used Prestone radiator flush when changing coolant years ago. Within a few hundred miles the heater core started leaking. $1200 later I had a new heater core. After that I did research and found a small message deep in service manual saying DO NOT use radiator flush. Sorry I don't remember where I found that reference.
Maybe it was just coincidence that flushing the radiator and shorty after that the heater core started leaking.
Discussion Starter · #4 ·
Thanks for the tips. I pulled out the owner's manual and made a check list of items to tackle. Since I am at 91,xxx this year I'll likely wait til next to get the maintenance performed.
Two things that are bothering me, and might as well pose to the forum, is the driver side visor clip is broken and will not latch back into place. Has anyone replaced that piece before? I do not see a screw or anything to detach. Also, the moon roof compartment / dial contraption is making a creaking noise whenever I am on the highway. Anyone tamper with that before as well?
The signs of a 12 year old car...
Discussion Starter · #6 ·
Thanks for the link. Read it once and it's not the most clear solution but I'll have to read it again when I find a few moments.
1. Headliner 92219136 Headliner 92219138 Without sunroof.
2. Sun-Visor 92208714 Sun-visor left Sun-Visor 92208716 Sun-visor, Right
3. Sun-Visor Screw 11570594 Sun-visor Screw, Right
4. Sun-Visor Upper Retainer 22612024 Sun-visor Retainer, Right
5. Sun-Visor Support 13187128 Sun-visor Support, Right
6. Overhead Console 92189673 Without sunroof.
7. Overhead Console 92223695 G8. With sunroof.
8. Reading Lmp Assembly 92172664
9. Grip Handle 92189691
10. Grip Handle Screw 11517072 Grip Handle Bolt
11. Grip Handle Retainer Nut 92172719
12. Grip Handle Spacer 92172717 Grip Handle Spacer 92172718 Rear
I had to fix my driver side visor clip just after my new purchase. Had the dealer do it under warranty, but later learned that when they fixed it, they caused a wire rub to the lighted visor mirror. I then had battery issues for months until that wire rub was located, so be aware if that.
Discussion Starter · #9 ·
Ten4. Still dreading this fix when I return home.
1 - 9 of 9 Posts
