The danger of the DOD system is that they are the old weak lifters. And the trays wear the regular lifters can turn and tear off the roller and wipe out the cam. Then there is the DOD lifters. If your oil pressure is too low when it tries to engage. The pin doesn’t properly release and you have the lifter collapse. The two sources that cause that is either the original LVOM leaking, #2 cam bearing worn and bleeding off pressure, or the oil pick up O ring is leaking air into the system which lowers the oil pressure. DOD delete is the cheap way to fix most of the problems. I’m going to fix the problems AND keep DOD.
GenV engines like the LT4 have DOD. The new DOD lifters can handle .551” cams and the updates LVOM are sealed and riveted together so they don’t leak. Lastly the pump O ring. They wear out faster because of the single bolt retainer. It does allow some movement through vibration over time. When the O ring gets older, that vibration cracks and causes the ring to leak. A two bolt retainer fixes the movement.
