So I just picked up a 3.45 diff for my V6 and had a question regarding the coupler. I have done some research on. it but haven’t found any positive solution to my problem. Right now the rubber coupler doesn’t mate to the yoke on the 3.45 diff. Do I need to swap yokes? Do I need to get the bigger coupler? Any help would be greatly appreciated.
Thanks for the video. Yah I saw this video but was hoping that maybe someone had another solution to this problem. But from what I have seen and read it seems like this might be my only option.
I'm not familiar with the V6 differential but I did the swap a few weeks ago with my V8 and the coupler had 3 little lips on one side where the bolts go in the differential. I had to lightly hammer them back in so there was no gap. I guess if yours has no way of fitting correctly I bet getting a stock g8 gt rubber coupler would be cheapest and easiest.
Judging by the video it looks the same. I can't guarantee though. Just doing a quick search pulled up that the coupler costs about the same as your shop quoted for the swap.
I have decided I am just going to do it myself. My boss was cool with me using his shop and tools so I'm just going to give'er a go on friday and see if I can get them switched around.
Hey guys! I just swapped a GT 2.92 diff into my V6. I had the exact same issue, it seems they are slightly (I mean 1-2mm) different or the couple shrunk a bit.
I was able to use a punch to line the edge of the rubber coupler bolt sleeve up with the shaft and I used a c clamp to force the sleeve into the flange. A little persuading the bolts and you're in... I've had it on like that for a month now and no issues.
Hope this helps, I know swapping the yokes definatly works though. I just assumed the GT was a direct swap which I didn't realize until the bitch was in with the arms back on it haha.
Let me know if you have anymore questions.
Sent from my Pixel 3 XL using Tapatalk
Related Threads
1.4M posts
40.5K members
Since 2007
