I usually row through them all just because I enjoy it. Occasionally I will do 1-3 as my 2nd has the bump grind.
I guess I drive illegally a lot! Between the tr6060 in the GXP and the T5 in the tbird I do a lot of coasting in neutral as there is about a 5 mile downhill stretch from the beltway back into town. Cars will reach ~ 60 or so (35 speed limit) when shifted to neutral at ~ 30. Have to brake several times to keep under 40.Upshifting, I typically do not use the clutch for 3-4, 4-5 or 5-6.
When I was taught how to drive a manual (a long, long time ago), it was explained to me that it is illegal to coast in neutral and to always be in a gear as realistically possible at all times. With that in mind, I was taught to always downshift which to present time, I still do.
Interesting. While I've been aware of clutchless shifting since the 60's, I'll have to try this on the GXP. Lift throttle/disengage clutch is so instinctive, however, that I have had a hard time speed shifting even when consciously trying to do so.Upshifting, I typically do not use the clutch for 3-4, 4-5 or 5-6. When I was taught how to drive a manual (a long, long time ago), it was explained to me that it is illegal to coast in neutral and to always be in a gear as realistically possible at all times. With that in mind, I was taught to always downshift which to present time, I still do.
