1 - 7 of 7 Posts
the Ac compressor on my 2008 G8 (LY7) is bad. i'm having trouble finding one for under 700$. are they all that expensive or am i missing something? this is my first G8 so i'm not familiar with the part prices
How was it determined the compressor is bad? Where are you seeing an air conditioner compressor for a Pontiac G8 costing $700? Wherever it is... run don't walk away. By the way, the part number for the compressor is 92265301.
Correct.
It's currently $422.79 on RockAuto (OEM ACDelco). Factor in the 5% discount and you're looking at $409.64 before shipping ($7.99 to my zip code).
Definitely shop around...
It doesn't look like it's hard to get out after unbolting the compressor and the lines. Couple tips if you've never done a compressor...when you bolt the new one on...alternate between the bolts to slowly bring them up to torque to prevent stressing the housing seal and possibly causing a leak. Drain and measure the oil that comes out of the old one. If it's less than 3 oz that comes out...I add 3 oz. If more than 3 oz comes out, add the same amount that came out. Than draw your vacuum on the system and charge.
Did the compressor on my 300zx this winter. It was about 450$ for a kit that came with dryer and expansion valve. Most compressor's run about 400 these days.
Have you ever heard of Amazon??????? For $459 you get the entire installation kit. Rebuilt the compressor can be found for under $200 alone
1 - 7 of 7 Posts
